physast Samba Member
Posted: Mon Oct 20, 2014 5:20 pm Post subject: vanagon aftermarket fuel tank options |
I have searched, but I am not satisfied..
I am looking to get a new vanagon fuel tank for my 91 westy. Prices at the regular vendors are different which make me believe that the tanks may also be from a different vendor.
Van-Cafe: $164.00 (pictured in silver)
Gowesty: $239.95 (pictured in silver)
Busdepot: $159.95 (pictured in black)
I have read that they are all from the same manufacture, but with the variance in price this can't be true, or can it?
I have also seen them on ebay for about $100
I commonly see these listed as part number VW3C (spectra?)
Anyone know if they are all the same? One better than the other? Are all the regular vendors selling the same tank?
Thanks. _________________ 1967 L633 VW beetle (currently being restored...slowly)
1991 Orly Blue Vanaru 2.5L |
bluebus86 Banned
Posted: Mon Oct 20, 2014 5:46 pm Post subject: |
call each vendor your interested in, ask the following
Where is the tank made?
What company makes and/or imports this tank?
Are there any markings or labels on the tank that may indicate manufacturer?
Once you get answers to these questions from the source, the folks that really know or can find out by simply looking in their own stock room, you will have your answer. I doubt a member here has personal knowledge of what tanks all three vendors currently have for sale. Keep in mind a vendor may sell a different manufacturers part form time to time, all depend on what the distributors have at a given time.
so ask the folks that sell the tanks, and you will be unlikely to get false or outdated information.
a price spread like you quote is normal, even for the same product. I just looked on line for some antifreeze, priced from $12.47 to $18.99 for the same stuff, same brands, same gallon jug, nearly the same price spread you see for the gas tanks. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
kamzcab86 Samba Moderator
Posted: Mon Oct 20, 2014 10:53 pm Post subject: Re: vanagon aftermarket fuel tank options |
| physast wrote: |
Rock Auto shows...
1)- Color: Silver
- Manufacturer: Spectra
- Part number: VW3C (VW part #251201075AH)
- Included: Lock ring kit
- Capacity: 16 gallons
- Dimensions: 32-1/2 "x 28-3/8" x 9-5/8"
- Price: $136.79
- In stock: 2 remaining
- Additional info: Innovative engineering, manufacturing technology and quality control ensure that Spectra Premium fuel tanks meet or exceed the performance of the original equipment they replace.
Unit is designed to OE fit, form and function requirements accomplished by leveraging OE fuel system design expertise
Lock ring included with each tank to reduce installation time and to ensure a complete repair
Made with corrosion resistant, OE approved, Ni Terne steel for durability
Unit is leak tested after production to ensure product in free from fuel and / or evaporative leaks
Each new fuel tank is road tested to ensure real world performance and to verify that each design meets our high standards for quality
Engineered to stringent tolerances based on our Canadian engineers' in-depth knowledge of the OE part it's designed to replace
Fit tested on the very same vehicle application for which it was developed verifying first-hand that the design fits properly and can be easily installed
Packaged with double-layered foam wrap and heavy-gauge corrugated board to ensure product quality at installation
SPECTRA PREMIUM / COOLING DEPOT Warranty Information: Fuel tanks, fuel tank straps, and oil pans - three years.
2)- Color: not shown
- Manufacturer: Platinum Pro
- Part number: FTK01022
- Price: $112.79
- In stock: 3 remaining
- Additional info: Platinum Pro Fuel Tanks and Fuel Delivery Parts are a cost effective quality replacement to OE/Aftermarket Parts.
Lock Ring/O-ring Kits included to speed installation time
All Tanks are painted to inhibit rust and corrosion
Direct Replacement to OE for proper fit every time
Every fuel tank is leak tested twice before packaging
PLATINUM PRO Warranty Information: Fuel tanks, fuel tank straps, and oil pans - 3 year warranty.
Spectra is considered the "OE" replacement for most water-cooled-era VW's. _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Posted: Tue Oct 21, 2014 4:45 am Post subject: |
I found some more info and it seems that the spectra tank is rated highly and most do not have issues with them.
I ended up just ordering from Van-Cafe. They have proven to be a great source of information and very helpful so far in my money pit adventure. It seems they have installed many tanks and they found one that works for them. It looks like a spectra tank from the images, but I will let you know when I get it. _________________ 1967 L633 VW beetle (currently being restored...slowly)
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1125 Location: over by 'der
Posted: Tue Oct 21, 2014 2:31 pm Post subject: |
i used the van cafe 12mm outlet one in mine. easy install and it doesn't leak a bit anywhere. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
madspaniard Samba Member
Posted: Tue Oct 21, 2014 2:39 pm Post subject: |
mine is from VanCafe too.
I remember reading some people reporting what it feels like less internal baffles in some of these aftermarket tanks, which makes the fuel slush around more compared to the OEM tank. Haven't noticed that with mine. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
SCM Samba Member
Joined: January 26, 2011 Posts: 3478 Location: Bozeman MT
Posted: Tue Oct 21, 2014 2:49 pm Post subject: |
| madspaniard wrote: |
I remember reading some people reporting what it feels like less internal baffles in some of these aftermarket tanks, which makes the fuel slush around more compared to the OEM tank. Haven't noticed that with mine. |
I don't feel sloshing but I do notice my fuel gage changing position with the pitch of the vehicle (points to more full when going downhill, less full going uphill). I didn't pay attention to whether I had that behavior before putting in the new tank. I did notice a lack of pre-filter screen in the tank but don't remember paying attention to baffles. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19092 Location: Retired South Florida
Posted: Tue Oct 21, 2014 5:29 pm Post subject: |
| I have an original tank and the fuel needle is all over the map especially when I get down to a 1/4 tank. I watch it, but always reset my odometer when I fill up. I trust that more. |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1520 Location: Wisconsin
Posted: Tue Oct 21, 2014 6:21 pm Post subject: |
Yes, the stock tanks indeed allow fuel to slosh around inside and throw off the gauge when on a grade.
I had ample opportunity to observe this on our recent month-long roadtrip through the Rockies and Cascades ... |
Posted: Fri Nov 07, 2014 5:59 pm Post subject: |
The tank from van-cafe fit like a glove and seemed well made. I painted the top and put bedliner on the bottom for protection. _________________ 1967 L633 VW beetle (currently being restored...slowly)
