Boesen Samba Member
Posted: Tue Nov 18, 2014 5:54 am Post subject: 82 fuel in strange area. |
Looking at a possible purchase of a 82 Westfalia. Looked at it one day and told seller I'd be back the next day to get it running better to test drive. The next day I returned with some sections of vacuum lines. Cleaned rotor and cap fouling up, replaced three small sections of the vacuum lines. Started it up and it ran good and let it idle for 10 minutes as it was 5 degrees outside before I drove it. Headed out for short test drive. Ran great for the 15 minutes I was out. Turn into owners alley two blocks down to head back. In the middle of the turn it bogs down briefly,then idle raises back up, it bogs again and dies. Try to start it again twice. I go around back to engine and smell fuel. Look into engine hatch. See no fuel but can smell it at first. While there I notice inside the oil pressure switch hole behind distributor it looks wet/pooling of liquid. Touched with finger and smell. Yes it's fuel.
Get it pushed back to the sellers house. No fuel in oil. I'm just guessing it's either bad fuel pressure regulator or bad injector. Any thoughts?
Overall condition of Van is great all around and under.Needs tires, new fuel lines, plugs, etc. Typical maintenance. It ran great up to this point.
Some more pics of it in my gallery.
http://www.thesamba.com/vw/forum/album_search.php?search_author=Boesen&show_results=summary _________________ 1979 Westfalia Deluxe http://www.thesamba.com/vw/forum/viewtopic.php?t=474334&highlight=iowa |
Randy in Maine Samba Member
Posted: Tue Nov 18, 2014 7:43 am Post subject: |
My guess woudl be that fuel is leaking from the fuel line at the cold start valve into the oil pressure sender area.
But that is just a guess. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18744 Location: Retired South Florida
Posted: Tue Nov 18, 2014 8:39 am Post subject: |
Ask for some money off and tow it home where you can properly fix it. You will need to replace all the fuel lines anyhow as part of making it road worthy and safe. Looks like a nice van in the picture. |
the joker Samba Member
Posted: Tue Nov 18, 2014 11:45 am Post subject: |
Yes tow it away ask for some $ back
Made that mistake with a ghia years back, got it runnin took it for a test ride, after the ride was going to put a down payment , and return with the cash
The guy was like, " now it's runnin I think I'll keep it" what a dick!
Learn a hard lesson in buying , but I was young  |
