Splitcase Gearbox help...
PastDown
PastDown is offline
PostPosted: Mon Jun 09, 2014 6:16 am    Post subject: Splitcase Gearbox help... Reply with quote
Hi,
When I purchased my BD, it came with a gearbox, the part number 113.301 101 B Does 113 mean it was a beetle gearbox?
It has the number 2A.... I can get the rest later.
As I understand that there are two gearbox types, the early vertically split case boxes used on the 'crash' and early 1200 vans to the early 50s.
There seems to be NO web-based resource for identifying stock split gearboxes. I find this hard to believe, but I can't find anything, just the beetle box lists.
Thanks for any help.
mandraks
mandraks is offline
PostPosted: Mon Jun 09, 2014 8:01 am    Post subject: Reply with quote
your post in the UK indicates a 1958 manufacture? this would make this not a barndoor bus.
http://www.ssvc.org.uk/phpbb/viewtopic.php?f=6&t=51410
Barndoor production ended in 55. you might want to repost in the regular split to 67 forum for more exposure
regards
Uli
PostPosted: Mon Jun 09, 2014 8:34 am    Post subject: Reply with quote
If your gearbox serial # is 2A1593584 then yes, that is 1958.
The 2A in front does means it's Bus.
Here's an example of a '54 transmission #
PastDown
PastDown is offline
PostPosted: Tue Jun 10, 2014 1:23 am    Post subject: Reply with quote
That's really helpful, Thank you EverettB. I wasn't aware that the 2A relates to split screen. If it was beetle does it start with A, if that's incorrect, do you know the start code for a beetle?
2A1593584 is not my serial number, I'm off around to my unit tonight, so I will get my serial code. Is there somewhere I can check online?
Thanks
Rob
PostPosted: Tue Jun 10, 2014 8:09 am    Post subject: Reply with quote
There is a listing here under rear axle:
http://www.thesamba.com/vw/archives/info/chassisdating.php
Also check the Beetle listing there as it is more complete for month-to-month data.
According to the lists above the "2" prefix stopped at a certain year.
PastDown
PastDown is offline
PostPosted: Tue Jun 10, 2014 12:49 pm    Post subject: Reply with quote
The number is 2A2062018, code on the top is 323977 and the nose cone number is 211.301.211.
Thanks
Rob
PostPosted: Tue Jun 10, 2014 5:16 pm    Post subject: Reply with quote
2A2062018 looks like early '59.
I'm not sure what 323977 is - where is that at? Photo?
The nose cone # is the parts # for the nose - that is a normal split-case Bus nosecone
PastDown
PastDown is offline
PostPosted: Wed Jun 11, 2014 1:14 am    Post subject: Reply with quote
59, that's what I thought.
The number is located on the top of the gearbox.
PostPosted: Wed Jun 11, 2014 8:28 am    Post subject: Reply with quote
It looks like the symbol to the left of that number is the VW recycle symbol so maybe that is a VW-rebuilt unit and the number relates to that.
Capriacci
Capriacci is offline
PostPosted: Wed Jun 11, 2014 12:12 pm    Post subject: Reply with quote
Recycle symbol:
http://www.thesamba.com/vw/forum/viewtopic.php?t=360227&highlight=recycle+symbol
Martin Southwell
Martin Southwell is offline
PostPosted: Tue Sep 09, 2014 3:17 am    Post subject: Non Synchro Gearboxes On Early Type 2? Reply with quote
Could somebody help here please.
I've been offered 4 complete Barn door gearboxes and reduction hubs, but lacking the nose cones, where previous owners have gone the IRS route.
Did early type 2's have non synchro gearboxes, and if so, up until what gearbox/chassis number, or date please?
I could use non synchro boxes on my pre Oct 52 Beetles, and am already using the reduction hubs and drive shafts off one for my 43 Kubel.
djfordmanjack
djfordmanjack is offline
PostPosted: Thu Sep 11, 2014 1:52 am    Post subject: Reply with quote
according to the details section on Tonnys site (barndoor.dk) they started the synchro trans in early 53 with
... synchromesh transmission. At this type only the
1. gear was unsynchronised. It is how it looked from ch. number 20-047017
for reference my July53 Single cab 20-57... has a 20-476.. (synchro)transmission, so obviously the transmission numbers are off the chassis numbers !
54 Oval project
62 Dickholmer, Seeblau L360
bauhaus
bauhaus is offline
PostPosted: Tue Nov 18, 2014 2:36 am    Post subject: Reply with quote
Hi Martin,
Did you buy the barn door gearboxes/axles? Would you like to sell one?
I'm restoring a 44 kubel and looking for a good pair of axles but I'd be interested in a complete gearbox/axle assembly if ones available.
Regards
Nev
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Fri Nov 21, 2014 9:44 pm    Post subject: Reply with quote
I have a trasmission that was in my 57 euro deluxe with the number 2A-149400 So this appears to be from a 53?
I'd very much like to get one closer to December 1956 when my bus was made.
Anyone want to trade ?
Please PM me if you do.
PostPosted: Fri Nov 21, 2014 10:29 pm    Post subject: Reply with quote
I don't have one to trade but out of curiosity:
It is a "smooth case" transmission like this:
nlorntson
Crazy VW Lady
PostPosted: Sat Nov 22, 2014 9:59 am    Post subject: Reply with quote
This is what I have. I'm not sure what you mean by smooth case.
PostPosted: Sat Nov 22, 2014 10:17 am    Post subject: Reply with quote
I agree that is a '53 transmission.
I guess they used what they had on hand since the reduction boxes and nose cone are later pieces.
The earlier transmission casings have less cross-ribbing.
Here's my later NOS case:
A side by side comparison would be better but I no longer have the early '54 transmission pictured above.
nlorntson
Crazy VW Lady
PostPosted: Sat Nov 22, 2014 10:23 am    Post subject: Reply with quote
While taking pictures I found a factory rebuilt stamp and the KD 260937 so that probably explains the later nosecone and RGB.
ulme2004
ulme2004 is offline
PostPosted: Sat Feb 13, 2016 1:56 pm    Post subject: Re: Splitcase Gearbox help... Reply with quote
Hallo, I need help in determination the model-year relation
of my barn find splitcase gearbox.
It seems to fit to a 58 T2 kombi
But is it an earlier gearbox? Which model year exactly?
The number is N 2A 1458901
what means N?
Regards Andreas
ulme2004
ulme2004 is offline
PostPosted: Fri Mar 25, 2016 3:32 am    Post subject: Re: Splitcase Gearbox help... Reply with quote
nobody an idea?
