torchmonkey Samba Member
Posted: Mon Nov 24, 2014 12:04 pm Post subject: Red dust in distributor cap/ no start |
Van has intermittently not started for the past few months, probably once a week. Always got itself running though. Today it just refused to start so I had a look around the engine and after checking plugs, fuel flow, etc... I checked the distributor on a whim. The inside of it was completely covered in a fine red dust. I blew it out and sprayed some contact cleaner in a few areas and it started right up. Any idea what this dust was??? _________________ 1983 1/2 Westfalia |
greggearhead Samba Member
Joined: June 20, 2004 Posts: 579 Location: Colorado Springs, CO
Posted: Mon Nov 24, 2014 12:26 pm Post subject: |
I've seen a number of bad distributor caps on Vanagons lately. Like 4 of them within 2 months, that had the center spring-loaded electrode start to disintegrate or similar. Caps and rotors are cheap - good time for maintenance, order two of ea an throw one set in the glovebox. _________________ 1972 Porsche 911E Hot Rod (3.4 Turbo)
1973 VW 412
1979 Audi Fox GTI
2002 Eurovan
Period Lights, VW & Porsche wheels and Recaro/Scheel Seats for sale
https://www.facebook.com/greggearhead
http://greggearhead.com/soco-swap---september-vw-swap-meet.html |
Merian Samba Member
Posted: Mon Nov 24, 2014 1:54 pm Post subject: Re: Red dust in distributor cap/ no start |
torchmonkey wrote: |
Any idea what this dust was??? |
It is almost certainly Chinese drywall dust, which is what cheap dist. caps are made from. |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3456 Location: OR & CA (Oregon/California)
Posted: Mon Nov 24, 2014 1:58 pm Post subject: |
without a pic of the cap it will be hard to tell..
my guess it's the red dust is from the plastic cap... via friction of some sort... |
Mr Brown Samba Member
Joined: January 30, 2006 Posts: 161 Location: Somewhere In Canada
Posted: Mon Nov 24, 2014 6:40 pm Post subject: |
I had this when all the shim washers on the distributor shaft departed. The rotor rubbed the cap as it pushed too far up due to all the play in the distributor shaft. |
Jon_slider Samba Member
Posted: Tue Nov 25, 2014 10:54 am Post subject: |
Mr Brown wrote: |
I had this when all the shim washers on the distributor shaft departed |
Super helpful post! Much Respect. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Posted: Tue Nov 25, 2014 1:15 pm Post subject: |
Thanks for the replies. I'll look more closely at the distributor over the holiday weekend. I didn't get a pic before cleaning as I was in a major rush to get it started and get my butt to work. _________________ 1983 1/2 Westfalia |
Posted: Tue Mar 24, 2015 6:03 pm Post subject: |
Been having some slight hesitation issues the past two days and decided to open the distributor, this is what I found. I'm pretty confident it's rust dust from somewhere in there. Just a side note: until the van warms up there is a squeaky sound coming from the engine, haven't looked into that but I'll bet it's coming from the the dizzy too.
borninabus  Samba R&D Dept.
Joined: May 18, 2006 Posts: 4723 Location: Arizona Highways
Posted: Tue Mar 24, 2015 6:47 pm Post subject: |
that orange dust is called "rust". _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Tue Mar 24, 2015 7:12 pm Post subject: |
Wonder if the vent in the body of the dist is plugged causing condensation? |
Posted: Wed Mar 25, 2015 7:26 am Post subject: |
Hmm? There is a vent in the distributor? You mean that rectangular gap at the edge of the cap? If you look closely that rust is blowing out of the dist. and onto the surrounding hoses and wires form that "gap". _________________ 1983 1/2 Westfalia |
Posted: Wed Mar 25, 2015 7:33 am Post subject: |
I would suggest finding another distributor and installing it. You could pull that one apart, but I would guess that there is considerable wear on multiple parts. How much side to side and up and down play is there to the shaft? These distributors need to be lubed occasionally to prevent something like this from happening. You can buy kits that contain the thrust washers or you can buy generic washers from McMaster Carr or others, but if the bushings are shot or the shafts are worn you would just be wasting your time.
Would be nice to see pictures of it torn down though if you go that route. |
Posted: Wed Mar 25, 2015 2:08 pm Post subject: |
Hmm? There is a vent in the distributor? You mean that rectangular gap at the edge of the cap? If you look closely that rust is blowing out of the dist. and onto the surrounding hoses and wires form that "gap". |
Maybe not on yours but under the main body near the outer edge there is a small plug, approx. 7mm with a fine screen. |
Joined: April 27, 2002 Posts: 6744 Location: Pentwater, Michigan
Posted: Wed Mar 25, 2015 4:41 pm Post subject: |
On those later dual port distributors the ozone vent is on the bottom facing side of the housing and rust will not easily pass into or out of that vent. _________________ Roads Scholar
Member# 2059 |
