no fire to coil
gabchbum
gabchbum is offline
PostPosted: Sun Dec 07, 2014 5:55 pm    Post subject: no fire to coil Reply with quote
we just replaced the 1600cc type 2 engine in the 1971 bus. the starter turns fine,but the engine wont fire. i have fire to the coil,but none from the coil. i replaced the coil and still got no fire.... i believe the electronic ignition leads could have been swapped on the coil(black on positive and red on negative). i just dont see why it would still turn over if i fried the electronic ignition. im looking for any help or suggestions
Tcash
Tcash is offline
PostPosted: Sun Dec 07, 2014 6:35 pm    Post subject: Electronic Module Testing Reply with quote
Stupid question. Did you put the rotor back in?
If you hooked it up backward. It may have fried the Module.
gabchbum
gabchbum is offline
PostPosted: Sun Dec 07, 2014 6:43 pm    Post subject: Reply with quote
everything is in place as it should be and the distributor wires are on tight. if the electronic ignition is fried,would it block or suppress power from the coil?
Tcash
Tcash is offline
PostPosted: Sun Dec 07, 2014 6:46 pm    Post subject: Reply with quote
Yes it would. Run the test in the picture, to test the module.
Good Luck
Abscate
Abscate is offline
PostPosted: Sun Dec 07, 2014 6:49 pm    Post subject: Reply with quote
Frying the electronic ignition module won't have any effect on the starting system which cranks the engine. These are independent systems.
Tcash
Tcash is offline
PostPosted: Sun Dec 07, 2014 7:24 pm    Post subject: Reply with quote
dugfresh
dugfresh is offline
PostPosted: Sun Dec 07, 2014 7:44 pm    Post subject: Reply with quote
Don't you mean "The Starter System"?
78 Riviera
http://flic.kr/s/aHsjDRJPa1
Tcash
Tcash is offline
PostPosted: Sun Dec 07, 2014 7:48 pm    Post subject: Re: no fire to coil Reply with quote
gabchbum
gabchbum is offline
PostPosted: Sun Dec 07, 2014 8:11 pm    Post subject: Reply with quote
12.3 volts when i go across the ignition with a volt meter
Abscate
Abscate is offline
PostPosted: Sun Dec 07, 2014 8:27 pm    Post subject: Reply with quote
Addresses question...
Tcash
Tcash is offline
PostPosted: Sun Dec 07, 2014 8:56 pm    Post subject: Reply with quote
You have 12.3 volts where?
#15 positive side of the coil?
Do you have a set of points and condenser that you can install?
