Narrowed Type 3 PICS...
Page: Previous  1, 2, 3 ... , 34, 35, 36  Next
Matt120y
Matt120y is offline
PostPosted: Fri Aug 22, 2014 10:49 am    Post subject: Reply with quote
Ok then, I've got dropped spindles to put on it too, but are they nessasary to have? I want to be able to make the car super low for shows etc, but lift it up a little for daily driving, and to keep the cops off me a little!
Bobnotch
Bobnotch is offline
PostPosted: Fri Aug 22, 2014 11:30 am    Post subject: Reply with quote
You don't really need to put them on, but IF you do, take into account that they might help push the tire out toward the fender lip, and could cause a fitment problem with your desired tire and rim choice. Rolling Eyes
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Aug 22, 2014 1:02 pm    Post subject: Reply with quote
You have to buy the wheels first! Then you can test fit/measure & determine what size air-beam 2-4" max to buy. You do want disc brakes on the front, but not the rear so it stops good.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
luckystiff
luckystiff is offline
PostPosted: Fri Aug 22, 2014 5:56 pm    Post subject: Reply with quote
radars i'd say 3-4" narrowed with wide 5 disc set up on drop spindles. my square is 5" with repop sprints and disc brakes on dropped spindles and it actually rubs the inner fenders quite alot with 145/65/15s. i went balljoint set up on my swap mostly because i had a balljoint donor beam for the arms and springpacks. and i for a good deal on a set up CB drop spindles with 5x130 disc(i ran fuchs on my square before the sprints) so i went balljoint. truth be told i can only get 3 or so inches lower than i could with t3 beam. i ran 4 notches down up front before the swap and my ride height now may be 2" lower at the current ride i have set.
DO NOT go more than 4" narrowed if you intend to run shocks which i'm sure you guys have to over there. you could probably squeeze a 4.5 in there but i can tell you my 5" was a pain in the ass with shocktowers.
ITMC
Secret Service
Matt120y
Matt120y is offline
PostPosted: Sat Aug 23, 2014 1:44 am    Post subject: Reply with quote
Cheers for the input fellas. I've got the raiders already, so it's either those, beetle 15" or type 15" wheels.
I'm building the beam myself as I've done a copls of bus ones and beetle ones in the past.
I intend to run shocks, as it will be used a fair bit out on the open roads. Sounds like the disc's are the way to go, and 4" max narrowed by the sounds of it.
OhHerrooo
OhHerrooo is offline
PostPosted: Thu Aug 28, 2014 11:42 am    Post subject: Reply with quote
Lowered my car a bit more. Need smaller rear tires.
'67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
OCT3 - Orange County Type 3's
www.evenkeelsurfshapes.com
ALLWAGONS
ALLWAGONS is offline
PostPosted: Thu Aug 28, 2014 1:09 pm    Post subject: Reply with quote
Look how nice they look without being super narrowed.
type3nut64
type3nut64 is offline
PostPosted: Thu Aug 28, 2014 1:17 pm    Post subject: Reply with quote
Yep!
Deluxe Lowlight Ghia
Deluxe Lowlight Ghia is offline
PostPosted: Thu Aug 28, 2014 10:30 pm    Post subject: Reply with quote
The rear tires look perfect
These vws are cool but the people who own them are far more valuable. Keep friends close they can be taken away overnight.
57 ghia
“57 factory safari 11 window”
59 patina ghia
61 patina Ghia
71 bus
74 thing
75 half bug
OhHerrooo
PostPosted: Fri Aug 29, 2014 3:08 pm    Post subject: Reply with quote
Thanks. They're so close to rubbing, but just barely don't. A slightly less beefy tire might be in order, but they're good for now.
'67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
TMI Products
TMI Products is offline
PostPosted: Fri Aug 29, 2014 4:06 pm    Post subject: Reply with quote
Is the tire close to the fender lip?
I was able to roll my fender and "gently" pull the fender out, gained almost 1 1/2" by doing that.
Mario De Leon
1965 Turbo Mustang Fastback
1966 Type 3 Fastback
VW Division Sales Manager
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX
JWDW
JWDW is offline
PostPosted: Thu Sep 11, 2014 5:23 pm    Post subject: Reply with quote
Bunch of my type 3's
fuhq64
fuhq64 is offline
PostPosted: Thu Sep 11, 2014 9:15 pm    Post subject: Reply with quote
^so that's where all the Notches are hiding...
69 Squareback
Still a n00b
www.instagram.com/fuhq64
marchi
marchi is offline
PostPosted: Fri Sep 12, 2014 6:30 am    Post subject: Reply with quote
colineunson wrote:
3'' narrowed air beam
ummm, SEXY!!!
I drive my VW or I walk
'70 Squareback
'21 Tiguan (daughters)
SOLD Sad
'69 Fastback (Flamer)
Bobnotch
Bobnotch is offline
PostPosted: Fri Sep 12, 2014 9:56 am    Post subject: Reply with quote
I have to agree with fuhq64 though, as that's a nice group you have hiding there. Wink
Where I live, they'd have to be stored inside, or they would rust away (too much rain). Shocked
Tram wrote:
Tram wrote:
eastcoast63
eastcoast63 is offline
PostPosted: Thu Dec 04, 2014 4:19 pm    Post subject: Reply with quote
Love the collection...if you dont mind....do you have short axles in the rear and what tire size please..(Black Notch)...
Ant
Fort Lauderdale, Florida
1967 Standard Microbus
Wide 5 Vintage Volkswagen Club
cgallman
cgallman is offline
PostPosted: Sun Dec 28, 2014 6:36 pm    Post subject: Reply with quote
Brand new here, but Ive had a few squarebacks over the years. I have a chopped 69 squareback now, that I'm working on. I have a set of old school two piece aluminum race wheels that I want to use. The wheels rubbed the calipers so I put spacers on to solve that problem, which now makes the wheels rub the fenders. Any suggestions other than a narrowed beam, or is a narrowed beam my only option? Im in Nor. Ca. who make the best beam packages? I need at least 2 inches to clear everything.
luckystiff
PostPosted: Sun Dec 28, 2014 8:46 pm    Post subject: Reply with quote
russel at Old Speed was doing narrowed type3 control arms. from memory i think they are 1" per side. best bet might be to contact him unless you want to go narrowed beam.
could you "clearance" the calipers and run a thinner spacer to avoid some of the width.
ITMC
Secret Service
cgallman
cgallman is offline
PostPosted: Mon Dec 29, 2014 9:06 pm    Post subject: Reply with quote
Yes i could clearance the calipers, Cut the bolts that hold the wheels together, and run a thinner spacer. I think I would still need a little more room too. Control arms may be the answer. Thanks.
makinbakin
makinbakin is offline
PostPosted: Sun Jan 04, 2015 1:45 pm    Post subject: Reply with quote
OST KÜSTE
Page 35 of 36
