VW tools
aircooled_cy
aircooled_cy is offline
PostPosted: Tue Jan 27, 2015 12:47 am    Post subject: VW tools Reply with quote
Hi Guys, I have found in a VW garage the below tools. Do you know what they were used for and if they are for VWs ?
Thank you
https://www.dropbox.com/s/1ecb38f087c4chp/IMG_1393.JPG?dl=0
https://www.dropbox.com/s/hktueuagd6ekglc/IMG_1394.JPG?dl=0
Mike Fisher
Mike Fisher is offline
PostPosted: Tue Jan 27, 2015 4:47 am    Post subject: Reply with quote
They are lathes that could be used for measuring/turning camshafts?
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Dr OnHolliday
Dr OnHolliday is offline
PostPosted: Tue Jan 27, 2015 10:26 am    Post subject: Reply with quote
What does the tag say on the first one?
1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust
aeromech
aeromech is offline
PostPosted: Fri Jan 30, 2015 11:45 am    Post subject: Reply with quote
If I were to guess I'd say you chuck up a camshaft in there and rotate it checking to see if it's straight.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
raygreenwood
raygreenwood is offline
PostPosted: Fri Jan 30, 2015 12:12 pm    Post subject: Reply with quote
I have seen pictures of the first tool somewhere being used for checking run out on transmission mainshaft and for chucking a shaft with a clutch disc on it for checking disc run out.
it really could be used for checking runout on any shaft that will fit in it. Ray
cdennisg
cdennisg is offline
PostPosted: Sun Feb 01, 2015 11:09 am    Post subject: Reply with quote
This.
