Quick and Easy WBX Oil Cooler Seal Replacement
Page: 1, 2, 3  Next
insyncro
Banned
insyncro is offline
PostPosted: Thu Feb 05, 2015 7:19 am    Post subject: Quick and Easy WBX Oil Cooler Seal Replacement Reply with quote
I have read all of the threads on this topic and find many differing experiences, along with some misinformation and advice.
My 91 Syncro L, named Great White by my gfriend Val has been a very trustworthy van this winter.
While out and about during the last storm we spent about 5 hours of exploring and navigating extremely snow covered back roads in my area. The undercarriage was covered with snow and ice so I did not see the tell tail drips coming from the cracked seal in the oil cooler...until the next morning at 6am with a wind chill in the negative teens. Go to fire up GW and heard a sound that you do not want to hear....a pump going dry. I assumed it was the power steering pump, but in fact it was the oil pump and the cooler seal had let loose completely, dropping my engine oil into my driveway Evil or Very Mad
The old style seals are just big Orings and prone to cracking, due to the ability to move when brittle.
The new replacement, purchased from a VW dealer, not a Vanagon vendor is an updated version with little additions to secure it to the cooler and not move during heat cycling.
With all Orings I coat them with Loctite 518 to keep the supple and add a tiny bit of added protection from weeping.
Many have replied to previous posts that the cooling system needs to be drained to replace this seal.
IT DOES NOT Exclamation
Even on a Syncro, with the skid plate in place, this seal can be replaced with just a few tools.
Here is what you need:
Replacement oil
Replacement oil filter
Oil catch can
Roll of paper towels
Nitrile gloves
27mm long socket with extension
T55 Torx socket long version with extension
Jack stands and jack optional.
Here's what to do:
1. drain oil
2. remove filter
3. remove 27mm thin wall nut securing the oil cooler
4. tap the T55 into the threaded oil pipe
5. remove oil pipe
6. replace seal...I did bend the engine tin slightly to allow the cooler to be accessed from the back.
7. replace oil pipe and tighten with the T55 until snug, approx 30 ft/lbs
8. replace thin wall nut and snug also to 30 ft/lbs (Bentley calls for 18 )
9. install new filter filled with new oil.
10. add proper amount of new oil.
11. start engine, idle 30 seconds.
12. check oil level after it settles...add if needed.
DONE Very Happy
This procedure, in my driveway, took 28 minutes from start to finish Exclamation
Idea Thank you Andrew Flint for the T55 tech tip. Idea
dobryan Premium Member
dobryan is offline
PostPosted: Thu Feb 05, 2015 7:27 am    Post subject: Reply with quote
Nice documentation! Very Happy
Dave O
The Western Syncro build
insyncro
Banned
insyncro is offline
PostPosted: Thu Feb 05, 2015 7:29 am    Post subject: Reply with quote
Thanks Wink
I hope it busts the myths of how difficult this job is and helps a few along the way.
danfromsyr
danfromsyr is offline
PostPosted: Thu Feb 05, 2015 7:58 am    Post subject: Reply with quote
this seal has caused many VW engines (that I am personally aware of) catastrophic failure.
this seal is on my New owner must change list, the OEM one is aged and the $4 seal can likely cost you your engine..
I'm actually surprised yours was OEM there Dylan Wink
but thanks for the great write up and we never remember the things that break on the nice days when you didn't have anything or place to be.
this is an item I pad a low $ order with when I order parts, I have a couple in a drawer in my garage..
though few people have a 27mm deep socket in their tools just awaiting this failure prone item.. word for the wise, go buy a cheap harbor freight 27mm or 1-1/16" deep socket for your OhShyt moments fellas..
part info and other horror stories HERE
Abscate wrote:
Syncro Jael
Syncro Jael is offline
PostPosted: Thu Feb 05, 2015 8:06 am    Post subject: Reply with quote
I wish this was posted about a week earlier. I just replaced one and didn't know there was a torx on the inside! I just double nutted to get it off. And never looked closer. Shocked
I enjoy learning on the Samba. Very Happy
1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat)
insyncro
Banned
insyncro is offline
PostPosted: Thu Feb 05, 2015 8:07 am    Post subject: Reply with quote
Dan, this van is new to me as of Oct 014.
It was in a barn for over 10 years.
I will eventually freshen up the entire vehicle, but for now, it runs so well that it has become my winter beast.
I wouldn't try to reseal head gaskets in my driveway, while it is snowing, but felt like going for it where it stopped.
My Buddy Will had a tiltback ready to come and pick it up to be taken to my shop, but currently all 4 bays have full restorations going on and, as I am becoming used too, no room for my vans Wink
Snowing like mad here today and a very slow moving storm, ready to drop its load will be here Sunday - Tuesday.
Looks like we have the snow and the Lombardi trophy here in the East Laughing
Couldn't resist Cool
insyncro
Banned
insyncro is offline
PostPosted: Thu Feb 05, 2015 8:11 am    Post subject: Reply with quote
Andrew Flint gets the credit for the T55.
I have all sorts of cool tools, like an internal pipe wrench, but after reading another thread where it broke clean off inside the tube, I went with the Torx approach.
Ron, I too enjoy learning from some very creative Volks.
dobryan is offline
PostPosted: Thu Feb 05, 2015 8:31 am    Post subject: Reply with quote
Syncro Jael wrote:
I wish this was posted about a week earlier. I just replaced one and didn't know there was a torx on the inside! Very Happy
My impression is that there is not a Torx on the inside. I think the Torx just happens to be a perfect jam fit. (Like pounding a 12mm socket on the outside of a CV bolt head...) Very Happy
Dylan can confirm.... Wink
Dave O
insyncro
Banned
insyncro is offline
PostPosted: Thu Feb 05, 2015 8:39 am    Post subject: Reply with quote
Absolutely correct.
Just snug enough to break the pipe loose and not bugger anything up, inside or out.
I used a Snappy as they are great quality and harder than the pipe.
A few light depressions were made inside the pipe.
I ran a blue shop towel threw it to be sure that no shards were present before reinstalling.
The double nut trick should work too, but watch those thin wall nuts as they can bugger easily...when using a wrench.
That is why I recommend a 27mm long socket, if available.
An EZ Out could also be used but they are very aggressive and may score the inner pipe and take some material with them.
We don't need shards going straight up the pipe and into the engine.
djkeev
djkeev is offline
PostPosted: Thu Feb 05, 2015 10:11 am    Post subject: Reply with quote
Great posts!
Thanks for making this tutorial.....
Applause Applause
Dave
Ghia
Vanagon
Beetle
insyncro
Banned
insyncro is offline
PostPosted: Thu Feb 05, 2015 10:12 am    Post subject: Reply with quote
Thank you.
My pleasure, it was fun.
djkeev
djkeev is offline
PostPosted: Thu Feb 05, 2015 10:18 am    Post subject: Reply with quote
insyncro wrote:
Thank you.
But...... I've found that creating Tutorials takes two - three times longer than just doing the task!
Stop.....take pictures, stop, take pictures, stop take pictures and when done write it all up.
Rolling Eyes
Coming from this having done it perspective...... Thank you thank you thank you!
Dave
Ghia
Vanagon
Beetle
dobryan is offline
PostPosted: Thu Feb 05, 2015 10:26 am    Post subject: Reply with quote
Needs to be in the FAQ's. Very Happy
Dave O
djkeev
djkeev is offline
PostPosted: Thu Feb 05, 2015 10:33 am    Post subject: Reply with quote
Already contacted her about doing so..... FAQ's and Stickies is her domain......
I also put a 27mm (1 1/16") deep socket on my shopping list. Any excuse to buy a tool!
I Have several 1" and I have 1 1/8" for my JCB Hoe lug nuts...... Just need that in between size......
Dave
Ghia
Vanagon
Beetle
insyncro
Banned
insyncro is offline
PostPosted: Thu Feb 05, 2015 10:56 am    Post subject: Reply with quote
IIRC, 27mm long is needed for the radius rod nut both 2wd and Syncro, due to the amount of threads showing.
insyncro
Banned
insyncro is offline
PostPosted: Thu Feb 05, 2015 11:01 am    Post subject: Reply with quote
Another reason I love my BlackBerry and Photobucket.
I just snap pics and they autoload into my bucket and are available as image links for forums such as this.
I take about 40-50 pictures a day so it works well for me.
I am honored if this ends up in the FAQs / Stickies Very Happy
Glad to see a not so good thing turn out positive for me and a few others.
Whatever Great White throws at me next I will be sure to share it.
djkeev
djkeev is offline
PostPosted: Thu Feb 05, 2015 12:09 pm    Post subject: Reply with quote
No grass grows under my feet!
Cool
Ghia
Vanagon
Beetle
insyncro
Banned
insyncro is offline
PostPosted: Thu Feb 05, 2015 12:19 pm    Post subject: Reply with quote
Put it to good use Wink
dhaavers
dhaavers is offline
PostPosted: Thu Feb 05, 2015 8:20 pm    Post subject: Re: Quick and Easy WBX Oil Cooler Seal Replacement Reply with quote
insyncro wrote:
...replace thin wall nut and snug also to 30 ft/lbs (Bentley calls for 18 )
x2...Bentley really missed the mark on that one... Rolling Eyes
Awesome writeup! I just did this last year, but great post - thanks for the T55 tip!
"The WonderVan"
insyncro
Banned
insyncro is offline
PostPosted: Thu Feb 05, 2015 8:23 pm    Post subject: Re: Quick and Easy WBX Oil Cooler Seal Replacement Reply with quote
Thank you.
I saw your posts about going heavier with the wrench and agree Wink
Page: 1, 2, 3  Next
