Christopholi Samba Member
Joined: May 16, 2011 Posts: 267 Location: Vancouver, BC, CANADA
Posted: Mon Feb 18, 2013 1:58 pm Post subject: |
I just put in some Allure Traffic Master "African Wood". I filled the floor channels with plywood, then more plywood as a subfloor, then installed right over top of that. Sadly, one box - 24 sq.ft. - is not quite enough to do a non-kitchen floorspace all the way under the rear seats. I need about 1/3 of a piece to finish. I also need to come up with something to protect the leading edge. At this point, I am at about $85 all in.
I did not do any sound proofing, and it is a bit louder than with the carpet and underlay that was there before. Not too bad, though. I plan on getting a big mat to keep the kids' muddy boots off, and to use as a camping mat outside the door in summer. This stuff seems to be pretty durable, and it was super easy to install.
_________________ 1988 Tintop Wolfsburg Special Edition - "Meatloaf"
RMW 2.5 Subaru, SubaruGears 5MT 4.44 w/LSD, Coast Mountain Hightop |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15415 Location: Syracuse, NY
Posted: Mon Feb 18, 2013 2:22 pm Post subject: |
it's funny because we put a $20 discounted bundle of flooring in Mom's van once and she bought a $35 carpet to protect it
having a few vans in the family and project stages i always walk past the discounted portion of the flooring isle for the loose matched 2 boxes @ $10ea.
I'm more frugal than fussy. _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
Atadloco Samba Member
Joined: July 13, 2012 Posts: 257 Location: New Hampshire
Posted: Mon Feb 18, 2013 3:08 pm Post subject: |
I was in my barn looking for something else and came across one box of 12mm hickory. Put it in on a whim and kept it..
alijonny Samba Member
Joined: November 01, 2007 Posts: 328 Location: Des Plaines, IL
Posted: Thu Sep 12, 2013 3:03 pm Post subject: |
Bringing up an older thread, I am interested in going with Bamboo floor in my Syncro. When I asked the flooring guy at home depot about it, he said the Bamboo will swell up like crazy once the humidity and moisture hit it. How does Bamboo survive while growing in the water??
Anyway, does anyone have any more long term experience with real bamboo vs laminate? I would like the real thing. I always feel that the laminate is a cheap work around for the real thing. |
Posted: Thu Sep 12, 2013 3:04 pm Post subject: |
akyrie Samba Member
Joined: March 24, 2010 Posts: 519 Location: Driftless, Wisco
Posted: Thu Sep 12, 2013 3:17 pm Post subject: |
Alijonny, I am not a flooring guy, but I installed my wood flooring on a subfloor with an 1/8" gap around the edge for swelling. I don't see why bamboo would be any different than another flooring. usually there is a specific gap you should consider specific to each type of floor. Check the packaging for the gap that you need. Don't le that sales person guide you wrong, bamboo it and let us see the picture. I am sure it will be great.
I tried ABS glueing the floor down and applying pressure, but one stupid board came up and I ended up screwing and countersinking the floor to the subfloor. I've installed the same floor re-using the same floor into 3 different van's now.
1st van
3rd van
_________________ Although I got a funny message from the Porsche guys, it read, "what a mighty ship that you must sail"
....has anyone else received that?
82 AHU DK, 1950's Puch-black |
outdoornate65 Samba Member
Joined: September 29, 2012 Posts: 161 Location: SE burbs of Denver, Colorado
Posted: Tue Dec 24, 2013 12:05 am Post subject: Considering wood flooring in 1984 Westy |
I've got a 1984 Wolfsburg Westy with tracks for the middle-row seat. I have the seat but never use it in the van.
Wondering how many folks have covered the middle seat tracks and if you regret it down the road?
Thanks,
Nate _________________ 1984 Westfalia Wolfsburg "Nana" |
1621 Samba Member
Posted: Tue Dec 24, 2013 2:31 am Post subject: Re: Considering wood flooring in 1984 Westy |
| outdoornate65 wrote: |
Thanks,
Nate |
You can see what I did on the top of page four of this thread. While I did install a rear facing jump seat instead, I have zero regrets about pulling the tracks. You might find it easier to work around them, or simply remove them altogether. _________________ '85 Westy |
dachary Samba Member
Joined: September 21, 2013 Posts: 130 Location: Boston
Posted: Mon Mar 24, 2014 1:48 pm Post subject: |
Add us to the club! Finally got around to installing our Pergo on Saturday. We found a plywood subfloor already present, so we just added a layer of underlayment/moisture barrier, and then put down the Pergo XP. Left it floating with a gap for expansion all around, except where we'll install a new edge piece, as the original no longer fits.
pergo_floor by CorporateRunaways, on Flickr _________________ '82 Diesel Westy w/Adventurewagen High Top |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17389 Location: Brookeville, MD
Posted: Fri Sep 26, 2014 5:15 pm Post subject: |
I was asked by a sambanite to post how I did the pergo on top of the seat tracks. These pics explain what I did. Basically I made it so I could remove the center section and expose the seat tracks for when I install the single or double seat. The pergo is laid directly on the stock grey floor. The outer two sections are held in place by one flush screw each.
_________________ Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3688 Location: Dartmouth, Mass.
TopBud Samba Member
Joined: February 28, 2004 Posts: 1202 Location: Flagstaff AZ
Posted: Fri Sep 26, 2014 10:21 pm Post subject: |
Dobryan,, Thanks so much. That is an excellent idea. I am going to try to do the same. I do not have the plywood and grey flooring, so I'll try to come up with something. Great job. I do not want to get rid of my middle seat, but I just got a jumpseat to play around with the idea. Thanks _________________ 86 bostig syncro tin top
66 convertible Karmann Ghia |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 608 Location: Scappoose, OR / Oakland, CA
Posted: Wed Oct 15, 2014 2:45 pm Post subject: |
Just installed bamboo in the '86 Weekender yesterday. The install was pretty easy, I used the original floor as a template for bolt holes/cutouts. The only real issue I had is that my flooring was thicker than stock- something to watch out for! _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
OhBetty Samba Member
Joined: August 23, 2014 Posts: 80 Location: Salt Lake City
Posted: Fri Feb 27, 2015 12:36 am Post subject: |
| Awesome posts. Thanks guy. Any idea about what the square footage is to do everything here? (Have the cabinets out, currently, and wouldn't mind covering the whole thing. |
Posted: Fri Feb 27, 2015 6:58 am Post subject: |
I'm not sure the cabinets will fit correctly if you laminate underneath them.
| BordoRico wrote: |
| Abscate wrote: |
Posted: Fri Feb 27, 2015 11:06 am Post subject: |
| danfromsyr wrote: |
| BordoRico wrote: |
Hey, thanks Dan. Appreciate the response. Is it not feasible that they could fit in a similar way to the current (stock) flooring as a template for trim and holes?
Admittedly, I'm a total newb at this... But thought that I had seen similar projects in here.
Many thanks!
Austin |
scooterick86 Samba Member
Joined: August 11, 2014 Posts: 17 Location: league city, TX
Posted: Sat Feb 28, 2015 7:47 am Post subject: |
greebly Samba Member
Joined: August 27, 2009 Posts: 973 Location: Here and now
Posted: Sat Feb 28, 2015 2:49 pm Post subject: |
Custom threshold I made for the laminate floor. The leading edge will fit neatly under the existing aluminum threshold.
Now I am going to have to get the wire wheel out and buff the OEM threshold so that it looks good enough to fit with the new threshold. |
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Wed Mar 11, 2015 4:37 pm Post subject: |
Heres mine following the blacked/tinted theme I have going. Its a plastic snap together flooring from Home Depot Allure is the brand.
Tossed in a sew fine charcoal 9 piece kit while I was at it.
Posted: Wed Mar 11, 2015 4:38 pm Post subject: |
Dbl post oops
