Who's got a wood floor?
Page: Previous  1, 2, 3 ... 8, 9, 10 ... 12, 13, 14  Next
Christopholi
Christopholi is offline
PostPosted: Mon Feb 18, 2013 1:58 pm    Post subject: Reply with quote
I just put in some Allure Traffic Master "African Wood". I filled the floor channels with plywood, then more plywood as a subfloor, then installed right over top of that. Sadly, one box - 24 sq.ft. - is not quite enough to do a non-kitchen floorspace all the way under the rear seats. I need about 1/3 of a piece to finish. I also need to come up with something to protect the leading edge. At this point, I am at about $85 all in.
I did not do any sound proofing, and it is a bit louder than with the carpet and underlay that was there before. Not too bad, though. I plan on getting a big mat to keep the kids' muddy boots off, and to use as a camping mat outside the door in summer. This stuff seems to be pretty durable, and it was super easy to install.
1988 Tintop Wolfsburg Special Edition - "Meatloaf"
RMW 2.5 Subaru, SubaruGears 5MT 4.44 w/LSD, Coast Mountain Hightop
danfromsyr
danfromsyr is offline
PostPosted: Mon Feb 18, 2013 2:22 pm    Post subject: Reply with quote
it's funny because we put a $20 discounted bundle of flooring in Mom's van once and she bought a $35 carpet to protect it Think
having a few vans in the family and project stages i always walk past the discounted portion of the flooring isle for the loose matched 2 boxes @ $10ea.
I'm more frugal than fussy.
Abscate wrote:
Atadloco
Atadloco is offline
PostPosted: Mon Feb 18, 2013 3:08 pm    Post subject: Reply with quote
I was in my barn looking for something else and came across one box of 12mm hickory. Put it in on a whim and kept it..
alijonny
alijonny is offline
PostPosted: Thu Sep 12, 2013 3:03 pm    Post subject: Reply with quote
Bringing up an older thread, I am interested in going with Bamboo floor in my Syncro. When I asked the flooring guy at home depot about it, he said the Bamboo will swell up like crazy once the humidity and moisture hit it. How does Bamboo survive while growing in the water??
Anyway, does anyone have any more long term experience with real bamboo vs laminate? I would like the real thing. I always feel that the laminate is a cheap work around for the real thing.
alijonny
alijonny is offline
PostPosted: Thu Sep 12, 2013 3:04 pm    Post subject: Reply with quote
akyrie
akyrie is offline
PostPosted: Thu Sep 12, 2013 3:17 pm    Post subject: Reply with quote
Alijonny, I am not a flooring guy, but I installed my wood flooring on a subfloor with an 1/8" gap around the edge for swelling. I don't see why bamboo would be any different than another flooring. usually there is a specific gap you should consider specific to each type of floor. Check the packaging for the gap that you need. Don't le that sales person guide you wrong, bamboo it and let us see the picture. I am sure it will be great.
I tried ABS glueing the floor down and applying pressure, but one stupid board came up and I ended up screwing and countersinking the floor to the subfloor. I've installed the same floor re-using the same floor into 3 different van's now.
1st van
3rd van
Although I got a funny message from the Porsche guys, it read, "what a mighty ship that you must sail"
....has anyone else received that?
82 AHU DK, 1950's Puch-black
outdoornate65
outdoornate65 is offline
PostPosted: Tue Dec 24, 2013 12:05 am    Post subject: Considering wood flooring in 1984 Westy Reply with quote
I've got a 1984 Wolfsburg Westy with tracks for the middle-row seat. I have the seat but never use it in the van.
Wondering how many folks have covered the middle seat tracks and if you regret it down the road?
Thanks,
Nate
1984 Westfalia Wolfsburg "Nana"
1621
1621 is offline
PostPosted: Tue Dec 24, 2013 2:31 am    Post subject: Re: Considering wood flooring in 1984 Westy Reply with quote
Thanks,
Nate
You can see what I did on the top of page four of this thread. While I did install a rear facing jump seat instead, I have zero regrets about pulling the tracks. You might find it easier to work around them, or simply remove them altogether.
'85 Westy
dachary
dachary is offline
PostPosted: Mon Mar 24, 2014 1:48 pm    Post subject: Reply with quote
Add us to the club! Finally got around to installing our Pergo on Saturday. We found a plywood subfloor already present, so we just added a layer of underlayment/moisture barrier, and then put down the Pergo XP. Left it floating with a gap for expansion all around, except where we'll install a new edge piece, as the original no longer fits.
pergo_floor by CorporateRunaways, on Flickr
'82 Diesel Westy w/Adventurewagen High Top
dobryan Premium Member
dobryan is offline
PostPosted: Fri Sep 26, 2014 5:15 pm    Post subject: Reply with quote
I was asked by a sambanite to post how I did the pergo on top of the seat tracks. These pics explain what I did. Basically I made it so I could remove the center section and expose the seat tracks for when I install the single or double seat. The pergo is laid directly on the stock grey floor. The outer two sections are held in place by one flush screw each.
Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
vanagonjr
vanagonjr is offline
PostPosted: Fri Sep 26, 2014 5:21 pm    Post subject: Reply with quote
dobryan wrote:
Awesome great idea! Thanks for documenting that.
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
TopBud
TopBud is offline
PostPosted: Fri Sep 26, 2014 10:21 pm    Post subject: Reply with quote
Dobryan,, Thanks so much. That is an excellent idea. I am going to try to do the same. I do not have the plywood and grey flooring, so I'll try to come up with something. Great job. I do not want to get rid of my middle seat, but I just got a jumpseat to play around with the idea. Thanks
86 bostig syncro tin top
66 convertible Karmann Ghia
ledogboy
ledogboy is offline
PostPosted: Wed Oct 15, 2014 2:45 pm    Post subject: Reply with quote
Just installed bamboo in the '86 Weekender yesterday. The install was pretty easy, I used the original floor as a template for bolt holes/cutouts. The only real issue I had is that my flooring was thicker than stock- something to watch out for!
1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice...
OhBetty
OhBetty is offline
PostPosted: Fri Feb 27, 2015 12:36 am    Post subject: Reply with quote
Awesome posts. Thanks guy. Any idea about what the square footage is to do everything here? (Have the cabinets out, currently, and wouldn't mind covering the whole thing.
danfromsyr
PostPosted: Fri Feb 27, 2015 6:58 am    Post subject: Reply with quote
I'm not sure the cabinets will fit correctly if you laminate underneath them. Think
Abscate wrote:
OhBetty
OhBetty is offline
PostPosted: Fri Feb 27, 2015 11:06 am    Post subject: Reply with quote
Hey, thanks Dan. Appreciate the response. Is it not feasible that they could fit in a similar way to the current (stock) flooring as a template for trim and holes?
Admittedly, I'm a total newb at this... But thought that I had seen similar projects in here.
Many thanks!
Austin
scooterick86
scooterick86 is offline
PostPosted: Sat Feb 28, 2015 7:47 am    Post subject: Reply with quote
greebly
greebly is offline
PostPosted: Sat Feb 28, 2015 2:49 pm    Post subject: Reply with quote
Custom threshold I made for the laminate floor. The leading edge will fit neatly under the existing aluminum threshold.
Now I am going to have to get the wire wheel out and buff the OEM threshold so that it looks good enough to fit with the new threshold.
newfisher
newfisher is offline
PostPosted: Wed Mar 11, 2015 4:37 pm    Post subject: Reply with quote
Heres mine following the blacked/tinted theme I have going. Its a plastic snap together flooring from Home Depot Allure is the brand.
Tossed in a sew fine charcoal 9 piece kit while I was at it.
newfisher
PostPosted: Wed Mar 11, 2015 4:38 pm    Post subject: Reply with quote
Dbl post oops
Page 9 of 14
