CV Joint Service (Lobro)
Tcash
Tcash is offline
PostPosted: Sat Jan 11, 2014 2:03 pm    Post subject: CV Joint Service (Lobro) Reply with quote
url=http://www.thesamba.com/vw/forum/viewtopic.php?t=581717&highlight=]CV Joint Service (Lobro)[/url]
Note: The Inner cover was not used on the T2 (bus).
archemitis
archemitis is offline
PostPosted: Sat Jan 11, 2014 3:37 pm    Post subject: Reply with quote
Cool! They make it look so sanitary!
1967250s
1967250s is offline
PostPosted: Wed Mar 11, 2015 1:21 am    Post subject: Reply with quote
Where can I get that inner cover for the CV's?
'72 Elm Green Deluxe
Tcash
Tcash is offline
PostPosted: Wed Mar 11, 2015 7:20 am    Post subject: Reply with quote
Inner cover was not used on a bus.
Bleyseng
Bleyseng is offline
PostPosted: Wed Mar 11, 2015 8:28 am    Post subject: Reply with quote
I'd like to get some new inner and outer clamps like in the pics?
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
raygreenwood
raygreenwood is offline
PostPosted: Wed Mar 11, 2015 8:35 am    Post subject: Reply with quote
McMaster Carr sells them for up to 3".
HCL clamping sells a wide variety including double ear, click style, plastic and stainless.
http://www.hcl-clamping.com/Snap-Fit-and-Ear-Clamps-C1?gclid=CKSkptLPoMQCFZI0aQod6zIAmQ
But the best type...if you want to use pinch lamps are the "seamless" type.
Murray corportion sells some. http://www.murraycorp.com/pinch-ear-clamps.html
Ray
Tcash
Tcash is offline
PostPosted: Wed Mar 11, 2015 10:30 am    Post subject: Reply with quote
O O'reilly's
cv+boot+clamp+install
Good Luck
Tcash
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Mar 11, 2015 11:08 am    Post subject: Reply with quote
I think I've seen them on some low-milage early early bays. Let me check and get back...
WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
Tcash
Tcash is offline
PostPosted: Wed Mar 11, 2015 12:42 pm    Post subject: Reply with quote
I have not seen them and they are not listed in the parts manual.
It would be interesting if you found them.
thanks to jerseylooker
Curious
Tcash
airschooled
Air-Schooled
PostPosted: Wed Mar 11, 2015 2:58 pm    Post subject: Reply with quote
Curious
Tcash
I didn't find them, but I read about them here:
http://www.itinerant-air-cooled.com/viewtopic.php?...ps#p177198
I have three four sets of original CVs off various early bays, including my own 80k original 1969 joints. I will look at them and get back to you next time I visit.
Robbie
www.airschooled.com
Amskeptic
Amskeptic is offline
PostPosted: Wed Mar 11, 2015 3:05 pm    Post subject: Reply with quote
asiab3 wrote:
Curious
Tcash
Robbie
I'd like some verification that covers were used until or through 1969. Also, Robbie, on yours, do you see lipped stub axle flanges, like the transmission CV flanges so you could rest the CV inside and get the screws started that much more easily. It was only 2AH (two years past Heinz Nordhoff), so quality still counted in 1969.
Colin 48AH
www.facebook.com/groups/324780910972038/
airschooled
Air-Schooled
PostPosted: Wed Mar 11, 2015 3:24 pm    Post subject: Reply with quote
Amskeptic wrote:
asiab3 wrote:
Curious
Tcash
Robbie
Colin 48AH
Glad you chimed in! I often feel guilty for ripping off your example photographs; my hands are usually too greasy for something as unrelated as pictures during messy operations...
I do have the flanged stub axles. They make installing the CVs much easier and prevent grease-flung messes.
I'll check for caps when I'm at my parents house this weekend. I have mine, two sets form '71 buses, and an original set from a '75 bus. Why, when I ripped off those original German axles for shiny EMPI replacements, I thought I was doing my bus a favor. My how times have changed.
Robbie
www.airschooled.com
Amskeptic
PostPosted: Wed Mar 11, 2015 3:43 pm    Post subject: Reply with quote
I used delicate plastic ties. Easy. Easy on rubber. Easy to install. Plus, you use designer colors, orange for the 914, red for the Karmann Ghia . . .
Colin
hearny13
hearny13 is offline
PostPosted: Mon Jun 08, 2015 5:15 am    Post subject: Reply with quote
I have just schaged oneside on my 1978 2 litre. I used the same brand in the book and the washer supplied was to small to go ver the axel. My guess is because they fit many applications it may be used on other vehicles.
1978 Westfalia Camper
richparker
richparker is offline
PostPosted: Mon Jun 08, 2015 6:24 am    Post subject: Reply with quote
asiab3 wrote:
Curious
Tcash
Robbie
My tourist delivery '68, production date 3/17/68, had the inner covers. I don't think all 4 were there and not 100% sure it they were OG since I am the 3rd owner. But the second owner was not mechanical at all so I suspect they were. I did not reuse them, if I find them I'll post a pic.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab
Wildthings
Wildthings is offline
PostPosted: Mon Jun 08, 2015 7:31 am    Post subject: Reply with quote
The spring washer was eliminated decades ago. Not sure why, but I presume that if one doesn't get the snap ring well seated the spring washer will cause the snap ring to pop out of its groove possibly leading to a failure.
richparker
PostPosted: Tue Jun 09, 2015 4:24 pm    Post subject: Reply with quote
asiab3 wrote:
Amskeptic wrote:
asiab3 wrote:
Curious
Tcash
Robbie
Colin 48AH
Robbie
I could not find my caps, but I'm sure they are around somewhere. I will hunt some more.
Today I was at the VW shop and the mechanic said he believes the caps were used in '68 only buses. He said the CV had a lip machined into them so the cap would fit into the CV and the CV would fit flush on the axle or transaxle.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab
airschooled
Air-Schooled
PostPosted: Tue Jun 09, 2015 4:30 pm    Post subject: Reply with quote
Thanks for the update Rich. Of fourse I forgot to unpack and look at my OG CVs last weekend when I was near them...
Are you using your original CVs that should have the lip in them? It would be cool to see a picture. Or maybe the lip stayed on if it was less expensive to keep the tooling the same for later CVs?
Robbie
www.airschooled.com
richparker
PostPosted: Tue Jun 09, 2015 4:46 pm    Post subject: Reply with quote
Robbie
I am currently running the CVs that came with my bus. I beleve 3 are OG '68s and one is an OG '78. Next service I'll try to remember to take a pic and post it.
We did look a several CVs at the shop, some OG some aftermarket. Non of them had the lip.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab
udidwht
udidwht is offline
PostPosted: Tue Jun 09, 2015 8:49 pm    Post subject: Reply with quote
Colin
I only clamp the wheel side of the joint. I've found that this allows the boot to relieve any unseen stresses during high revolution spinning of the shaft as well as the up/down movement. I now have 17 years since my previous CV refurb and all is well.
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
