Don66bus Samba Member
Posted: Wed Oct 15, 2014 3:56 pm Post subject: Bubble wrap R-value |
Clara,
You are correct. When you have a bare, hot, metal surface, and you put insulation against it (bubble wrap, old carpet, cardboard), you are not going to feel the heat as much. The first increment of insulation is the most important. Foil bubble wrap is about R1. So is an enclosed air space (more or less), such as the space between the interior panel and the body. If you want to increase the comfort of a bus in cold or heat, add insulation. The higher the R-value, the less the heat loss. Bubble wrap has the lowest R-value of any product you can buy. That may still be enough for your needs. |
matt94gt Samba Member
Joined: April 29, 2014 Posts: 245 Location: Victoria BC, Canada
Posted: Wed Oct 15, 2014 6:00 pm Post subject: Re: Bubble wrap R-value |
| Don66bus wrote: |
Clara,
Yeah thats my worry as I camp in the bus. Im still going to see how this styrospan works out, its a true R5. _________________ 72' Sunroof Bus - Kansas Beige
http://www.vw-mplate.com/mplate-21257.htm
Build thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7257521 |
Clara  Samba Member
Posted: Wed Oct 15, 2014 11:06 pm Post subject: Re: Bubble wrap R-value |
| Don66bus wrote: |
Clara,
Don,
Not feeling the heat (or cold) as much is pretty much the point of insulating.
If the shiny bubble wrap is R1, it is a huge difference. Maybe it works differently in a VW bus than under concrete. ???
You are correct, the first layer was the most noticeable difference. I then added a second layer and then the ceiling panels. These layers were not sandwiched tightly against each other, or even glued to the roof. There was some air space in between each layer.
I guess I could take pics of a thermometer to compare temps, but haven't bothered.
This is one method; it worked well for me so I've used it again. I'm sure there are others that work well also.
I have camped in cold, even freezing weather. Often in a damp climate.
I would not recommend carpet or cardboard for insulating your bus, as they hold moisture. |
Thin Metal Samba Member
Posted: Sat Oct 18, 2014 10:48 pm Post subject: Bubble Wrap Home Depot |
| Home Depot does not stock the bubble wrap as in the past but you can however order it from them online. |
Clara  Samba Member
Posted: Sun Oct 19, 2014 7:56 am Post subject: |
from VW technical bulletin:
esde Samba Member
Joined: October 20, 2007 Posts: 6370 Location: central rust belt
Posted: Sun Oct 19, 2014 9:55 am Post subject: Re: Bubble Wrap Home Depot |
| Roger H wrote: |
Any HVAC supply sells it for insulating metal duct work. |
Clara  Samba Member
Posted: Sun Oct 19, 2014 12:15 pm Post subject: |
[quote="matt94gt"]
| Clara wrote: |
Wow that's crazy what's expansit, looks similar to what I put in. Any stories about it? |
It looks like a hard foam that can be cut with a hacksaw blade. That technical bulletin is from from 1959. Here is the previous page, which says the 'Expansit' insulating boards are 30mm thick.
It also says you can protect your cargo floor against corrosion with 'bituminous paint', which sounds a lot like roofing tar.
Posted: Sun Oct 19, 2014 3:13 pm Post subject: |
[quote="Clara"]
| matt94gt wrote: |
| Clara wrote: |
Cool thanks for posting this, I also am putting 3M undercoating on the floors, so its pretty much as if I followed those instructions without knowing.  _________________ 72' Sunroof Bus - Kansas Beige
Build thread:
fwitiw Samba Member
Posted: Thu Apr 02, 2015 8:15 pm Post subject: |
Matt94gt... How'd it go? Squeaky? Now that its spring, have you camped? Thanks for sharing! _________________ 77 Westy 2.0
78 Transporter (no engine yet!)
71 Beetle |
