Parking brake cable tube front seal?
siahjo2
siahjo2 is offline
PostPosted: Fri Apr 10, 2015 5:58 pm    Post subject: Parking brake cable tube front seal? Reply with quote
Anyone know if there is a seal available for the front of the parking cable tubes to keep water out?
Thanks
richparker
richparker is offline
PostPosted: Fri Apr 10, 2015 6:15 pm    Post subject: Reply with quote
Don't think so, What year bus? I would grease the crap out of the cables before installing them. Maybe you could use a handlebar end from a bicycle or some other sort of plug and modify it to work.
Edit: not sure what I was thinking on my first post. The tube is way behind the skid plate. Smile
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab
siahjo2
siahjo2 is offline
PostPosted: Fri Apr 10, 2015 7:04 pm    Post subject: Reply with quote
Its a 79'. The tubes are wide open at the front to let water run in and get trapped at the rear where the rubber /wire guide is at the other end.
Vince Waldon
Vince Waldon is offline
PostPosted: Fri Apr 10, 2015 7:22 pm    Post subject: Reply with quote
I was never able to find a good supplier for OEM seals... and where I live any water in the parking brake tubes would be frozen solid half the year... so I made some out of rubber tubing and zip-ties. So far so good. Smile
Vince Waldon Edmonton Alberta CANADA
1970 baywindow
SGKent Premium Member
SGKent is offline
PostPosted: Fri Apr 10, 2015 7:56 pm    Post subject: Reply with quote
211 721 365 A - very easy to find
I believe these go in backwards sometimes because they split when trying to put the over some cable tubing like a normal seal. They are used for the parking brake and clutch cable. Maybe Colin would know which direction they were originally.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
Wildthings
Wildthings is offline
PostPosted: Fri Apr 10, 2015 9:03 pm    Post subject: Reply with quote
Check out your local motorcycle shop. There is bound to be something on a motorcycle or ATV that will work just fine.
