Thick wall 88's Too Thick
satterley_sr
satterley_sr is offline
PostPosted: Fri May 08, 2015 2:06 pm    Post subject: Thick wall 88's Too Thick Reply with quote
Just built a 1679cc for a customer using the aa 88 mm thick wall cylinders.
What a PITA. There was interference between the fins on adjacent cylinders. Installed one cylinder and then could not install the other because it hit the fins on the other cylinder. Grind/try/grind/try, after four times it finally fit.
DDC racing
LivinInnaVWBus
LivinInnaVWBus is offline
PostPosted: Fri May 08, 2015 4:31 pm    Post subject: Reply with quote
Interesting. I've used a few sets of these and the only issue I had was the last cooling fin closest to the case hit one of the center case mating nuts. No big deal and an easy fix with a grinder. Assembling another engine with thick wall 88s as soon as the parts get back from balancing.
surflvr911sc
surflvr911sc is offline
PostPosted: Fri May 08, 2015 4:42 pm    Post subject: Reply with quote
Were these the AA thick wall slip-ins w/ machined heads?
Ryan Williams
'64 VW Sportsmobile "lil' Blue"
TEAM WILLIAMS
gt1953
gt1953 is offline
PostPosted: Fri May 08, 2015 8:14 pm    Post subject: Reply with quote
Wonder if they are number 1 2 3 4.
72 type 1
72 Squareback
esde
esde is offline
PostPosted: Fri May 08, 2015 9:49 pm    Post subject: Reply with quote
Is it possible that the case bores were set too close together when they were done?
58Dub
58Dub is offline
PostPosted: Sat May 09, 2015 2:33 am    Post subject: Reply with quote
so does the head fit?
58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project
satterley_sr
PostPosted: Sat May 09, 2015 7:16 am    Post subject: Reply with quote
Yes these are AA machine in 88's,
If the bores are too close together, then VW did it cause you don't machine them.
yes heads fit engine is together after I ground down one side of the cylinder.
DDC racing
Brian Mathe
Brian Mathe is offline
PostPosted: Sat May 09, 2015 9:50 am    Post subject: Reply with quote
If these are machine in 88's don't you have to "machine" the case to get them in?
59 Kombi
66 Porsche 912
50 split-window
[email protected]
john@aircooled.net is offline
PostPosted: Sat May 09, 2015 10:03 am    Post subject: Reply with quote
This is just part of checking, and fixing, "stuff" that comes up during an engine build.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
satterley_sr
PostPosted: Sat May 09, 2015 10:05 am    Post subject: Reply with quote
http://www.aapistons.com/collections/vw-piston-lin...-90-5-head
DDC racing
58Dub
58Dub is offline
PostPosted: Sat May 09, 2015 10:49 am    Post subject: Reply with quote
I would guess these have the base turned down.
bugguy1967
bugguy1967 is offline
PostPosted: Sat May 09, 2015 1:53 pm    Post subject: Reply with quote
Hmm... I guess it was just extra casting flash. I doubt you did serious mocking up and measuring, or you'd have even bigger complaints about how aftermarket stuff sucks and doesn't fit.
At least you will know for next time to check barrels in the case registers. I check for a different reason. One time, one of the steps inside wasn't cut to the right dimension, and my barrel wouldn't drop all the way down. That held up my estimated build time for my client at the time.
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
satterley_sr
PostPosted: Sat May 09, 2015 3:27 pm    Post subject: Reply with quote
There was not extra casting flash, just letting others know of the situation. I have built probably over 100 engines and not run into his before but this is the first time with the machine in 88's. I think this is something that AA should correct since it is a stock case!
DDC racing
LivinInnaVWBus
PostPosted: Sun May 10, 2015 6:08 am    Post subject: Reply with quote
I don't believe this is a common problem, you probably got a cylinder which skipped the QC line though I've come to expect things like this when dealing with non-OE VW parts. If the engine fell together no one would need engine builders, right?
Brian_e Premium Member
Brian_e is online now
PostPosted: Sun May 10, 2015 12:00 pm    Post subject: Reply with quote
My last two sets did the same thing. 2 minutes each on the bench grinder and they are perfect. No big deal at all.
The TW92's and the 94's always hit the 19mm case nuts also. Another 2 min. each on the bench grinder.
Brian
[email protected]
roy@mofoco.com is offline
PostPosted: Mon May 11, 2015 9:08 am    Post subject: Reply with quote
Brian
Yep, this has been my experience as well.
Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet
Bill Dykes
Bill Dykes is offline
PostPosted: Mon Nov 30, 2015 6:30 pm    Post subject: Re: Thick wall 88's Too Thick Reply with quote
I have the same problem. AA thick wall 88s. Never had this happen before. Getting out the grinder tomorrow.
LivinInnaVWBus
PostPosted: Mon Nov 30, 2015 7:23 pm    Post subject: Re: Thick wall 88's Too Thick Reply with quote
Check out the flash where the two castings halves meet together, you'll need to clear all of that out of the cooling fins as well, they don't line up correctly. A dremel with a cut off wheel works well, it'll take an hour or two.
VWCOOL
VWCOOL is offline
PostPosted: Mon Nov 30, 2015 9:15 pm    Post subject: Re: Thick wall 88's Too Thick Reply with quote
It's not rocket surgery
64delux
64delux is offline
PostPosted: Mon Nov 30, 2015 11:51 pm    Post subject: Re: Thick wall 88's Too Thick Reply with quote
Rocket Science?
Brain Surgery?
M
