Strange engine compartment seal
thom
thom is offline
PostPosted: Wed Nov 22, 2006 9:09 am    Post subject: Strange engine compartment seal Reply with quote
I bought what I was told was an NOS engine compartment seal. It is an engine compartment seal, but what is it for? I've never seen anything like this before
It's composed of two matching pieces, which overlap in the middle.
The dimensions are correct for my engine compartment.
This is for my '56 ghia, but the ghia guys didn't know.
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
Eric&Barb
Eric&Barb is offline
PostPosted: Wed Nov 22, 2006 6:41 pm    Post subject: Reply with quote
Hi Thom,
VERY COOL.
If we are reading the part number correctly that is 111 813 707. Which is described in the 1960s parts manual as "Weatherstrip - Engine cover plate, rear (larger lips).
Boy, wish someone would repro those!
In Stereo, Where Available!
thom
thom is offline
PostPosted: Wed Nov 22, 2006 6:49 pm    Post subject: Reply with quote
In my umpteen years of VW's, I've never seen one of these.
What's the point of the bigger lips? Is this some sort of Angelina Joliet seal?
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
Eric&Barb
PostPosted: Wed Nov 22, 2006 7:25 pm    Post subject: Reply with quote
Hi Thom,
Just better sealing.
The next step up was metal frameworks that bolted to the body, and engine tin. Between the body and engine tin was rubber seal that was anchored by the frameworks.
RareAir
RareAir is offline
PostPosted: Wed Nov 22, 2006 7:52 pm    Post subject: Reply with quote
More of a Steven Tyler lip seal Wink
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
thom
thom is offline
PostPosted: Wed Nov 22, 2006 8:54 pm    Post subject: Reply with quote
You've got your fantasies, I've got mine, everybody's happy, right?
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
RareAir
RareAir is offline
PostPosted: Wed Nov 22, 2006 11:10 pm    Post subject: Reply with quote
Then you may want to spell your fantasy girl's name correctly. Wink
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
thom
thom is offline
PostPosted: Sun Nov 26, 2006 7:10 pm    Post subject: Reply with quote
Here it is installed
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
Rome
Rome is offline
PostPosted: Mon Nov 27, 2006 9:04 am    Post subject: Reply with quote
Thanks for the excellent photos.
I wonder... your photo of it installed... could it be a 'service fix" seal, for installing a later, non-H apron onto a '60 and earlier Beetle which still has a 36hp engine? The later apron, being lower, positions the sealing rubber slightly further rearward, so that there would be an open gap between the stock rubber seal and the 36hp rear breastplate. Such a seal would bridge that gap. If VW discontinued stocking the "H" rear apron and only offered the later style, this big lip seal could very well be the solution to keep the engine compartment cooling.
I also have never seen one like this. At first I thought it was an early Bus seal since those had removable rear aprons, but then the p/n would've started with 211 or so.
Wolfsburg Classics
Banned
Wolfsburg Classics is offline
PostPosted: Sat May 30, 2015 10:48 pm    Post subject: Reply with quote
Digging up this old post.
Does anyone else have thoughts on what this seal is? I have the very same seal here,it has the Triangular FISCO logo like alot of the other earlier seals.
Is it split bus designed to make it easier with the removeable rear apron??
Love to know more.
virtanen
virtanen is offline
PostPosted: Sat May 30, 2015 11:06 pm    Post subject: Reply with quote
My quess: if placed a later rear apron for a car with 25/36hp engine, then there is a bigger cap between engine and apron.
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
Snort
Snort is offline
PostPosted: Sun May 31, 2015 6:43 am    Post subject: Reply with quote
Or perhaps it superceded the longer rear tin used for Standard Beetles.
Wolfsburg Classics
Banned
PostPosted: Sun May 31, 2015 9:19 pm    Post subject: Reply with quote
Not sure but the part number features in both the Type 1 Beetle and Type 2 Bus parts books.
Remains a mystery, would be interesting to see how Thom's engine fitted in and if he retained 36hp etc.
