djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 856 Location: clearwater,florida
Posted: Sat Jun 20, 2015 1:17 pm Post subject: |
Does not look as bad as I would expect. Do you feel the same or no? Thanks for sharing. _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
Merian Samba Member
Posted: Sat Jun 20, 2015 1:37 pm Post subject: |
shows why coating is a bad idea
- what is the function of the slot? |
Posted: Sat Jun 20, 2015 1:51 pm Post subject: |
If you look at the bottom of your tank you will see a protruding circle in the center.
That circle is where the fuel is both sucked out of the tank and returned to the tank.
When your fuel level is low. It no longer floods the intake screen. It still gets sucked in the edges of the screen but also seeps under the plate into the intake well.
I cut away the cover of this circle inside the tank, where the two plastic filter screens are fastened.
The cover is spot welded in four spots, in between the spot welds are the slots that let fuel drain into the pump pickup area.
Bottom of my new Tank.....
Inside of my new tank. Much simpler, notice that there are no filter screens.
The pick up and return hoses still feed into the circular well but just enter through slots cut into the square sheet metal cover plate.
The new Slots are much bigger and easy to see. The bigger openings are needed due to the lack of the plastic intake filter screens.
There are still baffles to reduce sloshing.
Is it better? Probably not but certainly cheaper to build!
Ghia
Vanagon
Beetle
Merian Samba Member
Posted: Sat Jun 20, 2015 2:38 pm Post subject: |
if I follow you correctly the OE tank allows unfiltered fuel to flow out - esp. when the level is low
is that right???
why would someone design it that way? |
Posted: Sat Jun 20, 2015 4:03 pm Post subject: |
| The question is how to do on the road repairs when the fuel pump starts to cavitate in the middle of nowhere. |
VanShrugs Samba Member
Joined: May 06, 2011 Posts: 39 Location: Vancouver Island
Posted: Sat Jun 20, 2015 6:57 pm Post subject: |
Thanks Dave, for the fine photos of an OEM 2wd fuel tank.
Gotta love Vw engineering and attention to detail.
The outgoing and return fuel from/into the tank is filtered.
The gaps left for a very empty tank.. understandable, at least to this dolt.
Last time I checked with a Vw Dealer in Canada ~ 2004.
An OEM tank (like in the photos) retailed for around $650 Canadian-$. As many on Samba will know, the aftermarket tanks do not contain/have the 2-filter baskets. Cannot fault the aftermarket though. For the cost of a replacement tank today.
Save your original tank if possible!
If rusted internally? So sad. Few treatments, that I'm aware of, will treat the rust without harming the 2 filter baskets.
An acid etch with phosphate follow-up might slow the rust but, what will these two chemicals do to the filter-basket plastics?
VanShrugs |
tjet Samba Member
Posted: Sat Jun 20, 2015 7:14 pm Post subject: |
IMO, you really don't want a filter in the gas tank.
It looks like you could swap the feed line with the return line if for some reason you had a no-flow situation |
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Sat Jun 20, 2015 7:24 pm Post subject: |
The "brand new" (but 12 years old) replacement tank that came with my van was more like the OEM than the replacement you peered into. It also had a little more space between the circular depression and the sheetmetal cover.
This was especially exasperating for me, because whoever shipped the tank to the PO added pink foam peanuts to the box, which entered the tank through the grommet openings. I spent over an hour trying to retrieve them using a vacuum, gravity, coat hanger wire, anything I could think of. At least one peanut made it into the space between the depression and the cover, and so I had to assume that gas was either going to dissolve it quickly, or not at all ( I suppose I could have tested that).
Also, a couple small pieces of plastic came out. Maybe the tank was mishandled, I have no idea.
No matter. That tank lasted only a few miles before the charcoal canister hose that I purposefully plugged (to keep out junk during my Subaru swap), caused the tank to implode.
tjet Samba Member
Posted: Sat Jun 20, 2015 7:37 pm Post subject: |
| djkeev wrote: |
| tjet wrote: |
| IMO, you really don't want a filter in the gas tank |
I Think that the average Modern Fuel Injected new car makers feel otherwise.......
I am hard pressed to think of a modern car without an in tank filter / pump.
(Though my test sample spectrum Is rather limited)
I do agree though, given the option, I'd rather have an in line replaceable fuel filter and an unscreened fuel tank feed.
Dave |
I agree on the in-line filter...This is the sump on my new gas tank. I'm only using 1 port, & the other is plugged (non-vw project)
Posted: Sat Jun 20, 2015 8:01 pm Post subject: |
| VanShrugs wrote: |
VanShrugs |
I disagree.
Honestly, after seeing how clogged my fuel feed screen is on the lower sides, I now advocate tossing that old tank and that one get a cheap replacement that hasn't any filters in the tank. ..........
Ghia
Vanagon
Beetle
Posted: Sat Jun 20, 2015 9:50 pm Post subject: |
Dave,
Given your observations, I do agree.
The usual, do not assume! As I did here.
An OEM tank with fixed filter baskets [meaning non-replicable]
have a limited life.
Better to have a (replaceable) filter-sock over a fuel [in-tank] pump or filter before and/or after the main fuel pump.
The point here is replaceable when requirred.
VS |
Snort Samba Member
Joined: April 02, 2005 Posts: 1976 Location: Seattle, WA
Posted: Sun Jun 21, 2015 5:22 am Post subject: |
I appreciate what you're doing here but I don't buy the visual light test you are doing on that filter unless you are using that light show to demonstrate a flow problem that you confirmed by some other test with fuel not able to flow through that lower screen section. By your reasoning the fuel would only flow through the top part of the orange screen and when the fuel level got below the top it stopped flowing. Was this actually happening to you?
Remember those baby bottle nipple commercials? They often used animations to try to convince you that there was a problem with old fashioned nipples so that you would rush out and buy their nipple for twice as much money, using that baby screaming as a guilt factor, you bad bad parent. Your light test seems more like that baby cartoon trying to demonstrate a problem where possibly none exists. |
Posted: Sun Jun 21, 2015 5:43 am Post subject: |
| Snort wrote: |
Nope, no confirmed problem for I've never driven this car with this tank installed.
So,
When you look at my inlet screen photo it begs to be asked how you think fuel with this screen would get to the fuel pickup well at the rapid pace that a 300 liter per hour pumping rate would require once the fuel level dropped below the top screen.
I haven't any flow rate tests..... Sorry.
The light behind the filter screen is a visual aid I used in an attempt to clearly show how clogged the screen is.
How would you photographically show something being clogged?
Please enlighten me.
Are you saying that you don't think it is clogged?
I fail to grasp your point here.....
Let's say I purchased a used car....... Without ever turning the key I Decide to rebuild the engine. (Not out of the realm of reality for I've actually done this)
When I pull the oil pan I find a spun rod bearing.
Should I reassemble it and do an oil pressure test to verify that there is a problem while the engine is running or can I Simply assume that the bearing is actually bad and that it will exhibit the classic signs of a bad rod bearing when running?
Ghia
Vanagon
Beetle
Posted: Sun Jun 21, 2015 7:34 am Post subject: |
Well.......
I got to wondering, how pourous is that filter screen?
I cannot scientifically measure the volume that passes through but I can by simple observation SEE what passes through.
I cut out one of the filter screens and using duct tape strengthened the edges and formed it into a slight bowl shape.
I know that the adhesive on the tape has a very short half life in gasoline so this is a one shot deal.
I wondered if the screen has a residue from sitting that gas will cut away?
Anyway, I placed my bowl over a small shot glass and then using a straw and finger over the open end siphon transferred some fuel (Shell E85, oxygenated, unleaded regular) to the filter bowl.
What did it do?
It filled the bowl and then slowly.... Ever so painfully slowly seeped through the screen, not unlike water seeps through coffee grounds to make coffee.
Rube Goldberg flow test results?
Fail!
Even if one were to suck fuel through this membrane, it would be hard going.
Ghia
Vanagon
Beetle
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1960 Location: anchor pt. alaska
Posted: Sun Jun 21, 2015 7:58 am Post subject: |
| Maybe you could also repeat that rube-ish test with the portion of screen from the top of the pickup too. Though its pretty obvious that screen was loaded up with tank sealer. |
