Where is the cool diagram someone made for the WBX engine?
IdahoDoug
IdahoDoug is offline
PostPosted: Fri Jun 12, 2015 9:29 pm    Post subject: Where is the cool diagram someone made for the WBX engine? Reply with quote
Someone made a cool diagram of the WBX, showing the firing order, engine rotation, timing info and a couple other things useful on the side of the road. Anyone have a link to it? If I recall correctly, it showed a line drawing view of the engine from above, identifying cylinder #1, etc.
I wanted to print and laminate a copy and attach it to the top of the engine cover in a clear slip cover. Under the stress of a roadside breakdown, that info can be important. I was going to add routine engine info like NAPA part numbers for belts, oil filter, spark plugs, fuel filter, air filter and a bunch of other stuff for a quick reference guide.
Thanks!
msewalson
msewalson is offline
PostPosted: Fri Jun 12, 2015 9:37 pm    Post subject: Reply with quote
MODERATOR NOTE: The images below showing the Distributor rotation as counter clockwise is WRONG!!!!!
When the engine runs, the Distributor rotates Clockwise!
1432
Is this it? I think I pulled it off of Ben's site.
Matt
87 Syncro w/EJ22
syncrodoka
syncrodoka is offline
PostPosted: Fri Jun 12, 2015 10:09 pm    Post subject: Reply with quote
Timwhy's
Pete000's
Steve M.
Steve M. is offline
PostPosted: Sat Jun 13, 2015 4:27 am    Post subject: Reply with quote
That can't be right...who's got an engine that clean and shiney?😆
note that it is an air cooled, I forget if the notches on pulley are the same.
IdahoDoug
PostPosted: Sat Jun 13, 2015 8:31 am    Post subject: Reply with quote
True! The block looks gold anodized!!
Those are good ones. Seems like there was another with some other useful WBX trivia on it..?
riceye
riceye is offline
PostPosted: Sat Jun 13, 2015 9:04 am    Post subject: Reply with quote
Ben has lots of great pics and drawings on his awesome website.
www.benplace.com/vw2.htm
'87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig
kamzcab86
kamzcab86 is offline
PostPosted: Sat Jun 13, 2015 10:07 am    Post subject: Reply with quote
2016 Golf GTI S
delta9007
delta9007 is offline
PostPosted: Sat Jun 13, 2015 11:13 am    Post subject: Reply with quote
I'm confused. MS shows an aircooled with the distributor turning anti-clockwise and Kamz shows it going clockwise.
'89 2wd, 4spd, 2.1 Westfalia.
syncrodoka
PostPosted: Sat Jun 13, 2015 11:44 am    Post subject: Reply with quote
Aircooled cars have the same firing order. That aircooled picture shows the crankshaft being turned backwards for some reason. The only time that makes sense to do is when you are adjusting the valves and you don't want to go from side to side but if you start on the 4/3 side rather than starting at the top of the firing order it isn't a issue.
Merian
Merian is offline
PostPosted: Sat Jun 13, 2015 12:01 pm    Post subject: Reply with quote
dwell, not dwel
syncrodoka
PostPosted: Sat Jun 13, 2015 12:10 pm    Post subject: Reply with quote
Merian wrote:
dwell, not dwel
Yeah, he fixed it. I just posted the wrong image
buspor63
buspor63 is offline
PostPosted: Sat Jun 13, 2015 8:46 pm    Post subject: Reply with quote
Any number of those would make great T shirt art hint hint
Imagine that, theres not an "h" in either Westfalia or Syncro?
dhaavers
dhaavers is offline
PostPosted: Thu Jun 25, 2015 11:52 am    Post subject: Reply with quote
x2
I'll take a timwhy on black in L...???
Cool
"The WonderVan"
atomatom
atomatom is offline
PostPosted: Thu Jun 25, 2015 4:11 pm    Post subject: Reply with quote
yeah, but you have to print it upside down, so you can look down at it.
84 Vanagon Westy, 1.9L, California raised but defected to Canada.
dhaavers
dhaavers is offline
PostPosted: Thu Jun 25, 2015 4:13 pm    Post subject: Reply with quote
Laughing Laughing Laughing
"The WonderVan"
