Need help removing front shift rod
millinario
millinario is offline
PostPosted: Mon Jul 13, 2015 4:34 pm    Post subject: Need help removing front shift rod Reply with quote
Massive noob here....
My shifter and stop plate were toast so I have replacements.
Trying to replace my front shifter rod, but I can't get the old one out. I have searched quite hard but can't find a decent 'How To' anywhere.
Removed grub screw from the front coupler (also had one screw missing), it wasn't an 8mm square head screw and had no hole for the safety wire. Btw, anyone seen a coupler like this, looks nothing like anything I've seen during my internet searches:
Do I need to do the same at the rear coupler? Even then I don't see how either of the rods will come out?
This plate at the front of the cup of the front shift rod stops it sliding out:
How do I get this sucker out folks?!
FWIW I think I left her in neutral when I removed the shifter. Mistake?
Ran When Parked
Ran When Parked is offline
PostPosted: Mon Jul 13, 2015 4:49 pm    Post subject: noob too Reply with quote
I am a noob too (but have seen this asked a lot).
Many ways to tackle this job. Some better than others. Hopefully, I am responding with the right solutions to ur issue.
http://www.thesamba.com/vw/forum/viewtopic.php?t=602951
http://www.thesamba.com/vw/forum/viewtopic.php?t=475806
http://www.thesamba.com/vw/forum/viewtopic.php?t=213089
Saying this in a friendly philosophical way, this topic made me think "it is stuff like this that made the gods go quiet". Meaning, folks that have been answering this question for 20 plus years must be tired of it and remain silent....
OK, enough B.S. from me tonight!!! Good luck!!!!
Edit: is a summary thread for this issue on the Split Bus FAQ?
millinario
PostPosted: Mon Jul 13, 2015 6:25 pm    Post subject: Re: noob too Reply with quote
OK, thanks, helpful links. Embarassed
So when I get this front coupler off the front shifter rod can be removed by pulling back towards the engine? This is the part I'm having trouble getting my head around.
Not that I could find, I did check there first, honest.
millinario
PostPosted: Mon Jul 13, 2015 7:33 pm    Post subject: Reply with quote
Thanks again for the nudge Sh*tBird, has improved my search skills no end.
Found this image in the gallery
I have the early type coupler on my 74 bus, good to know.
Ran When Parked
PostPosted: Mon Jul 13, 2015 8:48 pm    Post subject: Re: noob too Reply with quote
Maybe it will get it's own thread/listing in the FAQ one day...
When I removed mine, I had everything under the cab floor unhooked from the shift rod and the coupling was the only thing holding up removal. When the coupling lost its grip, it allowed the shift rod to slide forward and it was free. I just moved it out from under the bus and then removed the rest of the coupling that was still on the front shift rod.
That coupling acted like a "Chinese Finger Trap" with screws:
Hope that makes sense, I am really sleepy.
easy e
easy e is offline
PostPosted: Mon Jul 13, 2015 9:33 pm    Post subject: Reply with quote
Love that ^^ visual
Front might need to be cut... carefully.
Rear... I think maybe someone has had success changing rear shift rod bushing with transmission in... but from what I recall.... need trans out.
aka: Evan
PostPosted: Mon Jul 13, 2015 11:18 pm    Post subject: Re: noob too Reply with quote
Saw this post, the thread below is now in the Bus FAQ:
Thank you
peterxxl
peterxxl is offline
PostPosted: Tue Jul 14, 2015 7:56 am    Post subject: Reply with quote
easy e wrote:
Love that ^^ visual
That's what I did.
Hi! I am Peter from Czech Republic...
Bringing VW news en Español to your doorstep since 2009!
* 1961 Panel - my 1st VW - bought near Mexico City - traded for:
* 1959 Kombi - stored in Philly for now
Read my story here:
* Part 1 - Mexico City to Philadelphia
* Part 2 - Philadelphia to Europe - in progress
sub-hatchtim
sub-hatchtim is offline
PostPosted: Tue Jul 14, 2015 6:14 pm    Post subject: Reply with quote
cut it and replace it
use anti seize on install
http://www.bustoration.com/Shift-Rod-Coupler--62-2-4_p_246.html
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
KevinAlbrecht
Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota > Babcock Ranch
KevinAlbrecht is offline
PostPosted: Tue Jul 14, 2015 8:05 pm    Post subject: Reply with quote
don't forget to order the screws!
Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
My '66 after the crash.
Click to view image
Stocknazi
Stocknazi is offline
PostPosted: Tue Jul 14, 2015 8:10 pm    Post subject: Reply with quote
Heat usually does the job getting the coupler apart. Heat the coupler and screws until they are glowing red then cool quickly with cold water.
You may have to repeat the process a few times.
Most of the time a propane torch works, but I have had a couple that required a little more heat from an oxy/act torch.
You can lay wet rags on the floor above the coupler and the heater tube underneeth. Don't melt your choke or fuel tap cable sheeth if you have one.
If the screws are broken off, you will have to cut it like in the pic above.
WANTED:
Thomas Jefferson
millinario
PostPosted: Thu Jul 16, 2015 9:31 am    Post subject: Reply with quote
Gonna try the heat route later this week.....damn real life getting in the way of imporant kombi work for now. If I get no joy I'll be forced to cut the coupler.
Screws are out thankfully (one was actually missing).
Appreciate all the repsonses. Will update.
iamdonquixote
iamdonquixote is offline
PostPosted: Thu Jul 16, 2015 8:29 pm    Post subject: Reply with quote
Heat, heat heat.
Heat the coupler until it is very cherry red and twist the rod back and forth with a good set of vice grips ( if the front of the rod is not connected to the shifter ).
crukab
Samba Chef
crukab is offline
PostPosted: Fri Jul 17, 2015 3:54 am    Post subject: Reply with quote
iamdonquixote wrote:
Heat, heat heat.
Yes ^^^^^^^^^^^^^^^^^^^
That worked for me, every time.
Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon
millinario
PostPosted: Mon Jul 20, 2015 1:42 pm    Post subject: Reply with quote
ajdfhifgwodldbfsjgflahl.....it feels like the coupler and the middle shift rod have been welded togethor. As it's 'above' the coupler (between coupler and the floor of the bus) I can't see any weld, but it certaily feels that way when I run my finger up there.
KevinAlbrecht
PostPosted: Mon Jul 20, 2015 2:19 pm    Post subject: Reply with quote
Here is the extent of hacking required to remove mine:
Don't let that fucker beat you.
Kevin Albrecht
1963 Panel
Click to view image
crofty
Judas of the North
crofty is offline
PostPosted: Mon Jul 20, 2015 2:44 pm    Post subject: Reply with quote
And wire them up when you are done tightening them!
HamburgerBrad wrote:
Fiatdude
Fiatdude is offline
PostPosted: Mon Jul 20, 2015 3:58 pm    Post subject: Reply with quote
World's Greatest Penetrating fluid
50% ATF and 50% Acetone ---- ---- ! BILLION times better than any thing else -- -- Squirt it once or twice every 2 hours first day-- next day ,,, a miracle
Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch
millinario
PostPosted: Mon Jul 27, 2015 8:00 am    Post subject: Reply with quote
Man this is bugging me, still can't get the middle shift rod out! More advice needed please. Sad
This all started because I had ridiculous slop when changing gears (the gear stick was doing a 180 and 3-4th were very hard to find). Upon inspection the shift plate was cracked and the pin/ball of the gear stick was horribly worn. I ordered both new. They arrived with a new front shift rod too (turns out the gear stick and front linkage didn't belong in my Kombi).
So....I ended up cutting the front shift rod with my grinder to within an inch of the coupler in the hope I would be able to slide the middle shift rod forward and out (heating/cooling the coupler mulitple times had no effect...I suspected it's been welded in place).
No joy. Is my only play now to cut the coupler? I'm going to measure later after work, but I can't believe that removing that extra 3 inches or so of metal will allow the rod to slide forward and out. The tube housing the rod doesn't seem short enough to allow it to 'drop' enough.
I really want the rod out so I clean out and grease that tubing under the bus. I guess I could forget that, cut the coupler, get a replacement and join things up again.
Edit: also found that the middle shift rod has been cut and welded by PO too. Maybe it's the wrong part or PO had it cut to remove it??!!
BarryL Premium Member
BarryL is offline
PostPosted: Mon Jul 27, 2015 9:40 am    Post subject: Reply with quote
When you say 'middle rod" you are talking the one the lays in the belly running down that hollow tube? That rod can only be pulled all the way out from the rear after pulling the transaxle.
