bwaz Samba Member
Posted: Sun Jul 26, 2015 9:27 am Post subject: Installing sliding door track cover on a 72? |
Any tips to getting the slider door cover back on, on a 72 bus? It's got the long piece that has the adjusting screw at the front. I've tried to put the cover and the rod thing together, or just the cover on top, but without success. Any tips? |
Joined: January 01, 2007 Posts: 17852 Location: sticksville, ct.
Posted: Sun Jul 26, 2015 9:49 am Post subject: |
it's a pain in the ass if the retainer clips are gone. keep messing with it, you'll get it _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
bwaz Samba Member
Posted: Sun Jul 26, 2015 10:29 am Post subject: |
Retainer clips? This is the piece i'm working on.
(not my photo) |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Sun Jul 26, 2015 11:02 am Post subject: |
bwaz Samba Member
Posted: Sun Jul 26, 2015 11:30 am Post subject: |
Thanks for those links Tcash, but unfortunately those are all great at disassembly, but not re-assembly. the video magically has the cover back on, but neglected to give the magic words to make that happen  |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52797 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jul 26, 2015 11:31 am Post subject: |
Ah yes, that diabolical locking strip, VW ditched it on later models, no doubt to speed up the production line.
I've had some luck using a couple wide putty knives or those really wide ones for wallpaper, shove them in first so they guide the cover into the slot.
Worst case scenario is leave it out, you won't miss it, the cover stays put with just the end screws nicely. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
bwaz Samba Member
Posted: Sun Jul 26, 2015 11:46 am Post subject: |
Tried it without. but seems a little sloppy. will give it another shot. don't feel too bad spending the day in the garage with the rainy weekend. |
Posted: Sun Jul 26, 2015 11:56 am Post subject: |
right above the notch where you remove the roller assy, there is a notch in that rippled track. iirc, there are 3 of those notches that held spring like retainers. they pinched the lock strip tight to the track so you can just slide the cover on.
I don't think anyone knows they exist, as 99% of the time they are long gone. _________________
Jake Raby wrote: |
Brian wrote: |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3255 Location: Left of everywhere
Posted: Sun Jul 26, 2015 8:41 pm Post subject: |
skills@eurocarsplus wrote: |
I don't think anyone knows they exist, as 99% of the time they are long gone. |
I sure didn't . I just did this last week I was using little pieces of cardboard to try to wedge the strip to the track. I had to leave it for a day and come back to it because it was frustrating. Make sure the adjustment screw is as loose as you can get it.
I have a question . The screw that goes into the body at the end track cover. I can't see any threads in there but it looks too big for a metal screw. What type of screw is supposed to be used there. |
Tcash Samba Member
Posted: Sun Jul 26, 2015 9:19 pm Post subject: |
thanks to jersylooker
bwaz Samba Member
Posted: Mon Jul 27, 2015 8:12 am Post subject: |
Got it. In the end, it worked best as a two man job (person) so that we could start at one end, while the other person held the other end and three pieces together. I tried the retainer (clamping strip) by itself then tried to slide the cover and seal in... without luck, then tried to put the cover in the track and slide the retainer in from underneath... without luck. The way we got it to work was to have the whole assembly put together as it would live in the track, and slide it in as a complete unit. Once in, I could add the end screw fairly easily by the door opening, and the two screws underneath. (after I drilled out and tapped the broken one at the front!)
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13491 Location: West Coast, USA
Posted: Mon Jul 27, 2015 9:18 am Post subject: |
bwaz wrote: |
The way we got it to work was to have the whole assembly put together as it would live in the track, and slide it in as a complete unit. |
This is the easiest way I've figured it. With the seal and everything, right? Some plastic-safe grease on the chassis side of the seal/strip helps it maintain it's posture relative to the cover and clamp strip.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
bwaz Samba Member
Posted: Mon Jul 27, 2015 10:11 am Post subject: |
Yep, everything squeezed together and drop it in. I thought about trying to put some sort of sealer/glue to hold the seal to the cover, but that would have been the next attempt. Lining up the clamp strip took a bit of time to see that it was lined up correctly with the track for it to drop in from above, while angling it a bit to allow the tab under the cover to get around the slider mechanism. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42568 Location: at the beach
Posted: Mon Jul 27, 2015 11:47 am Post subject: |
it has been a long time since my 1977 does not have that but the 1971 did. Try a longer bolt to push it back then use the bolt pull it forward to catch the rail, and replace with the correct bolt. I think that is how I got it once when it was fighting me. I do remember that it was easier when Linda helped with the process than by myself. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
VWSunny72 Samba Member
Posted: Fri May 13, 2016 11:48 pm Post subject: Re: Installing sliding door track cover on a 72? |
I used this MacGuyver process to get the rail cover into the channel of the locking strip on my 72. Basically, I put some strong pink yarn (courtesy of my daughter) around the locking strip in a few places. My father pulled the string to widen the channel between the locking stip and the chassis while I worked the cover in from back to front. Similar to others, the wooden block and rubber mallet were my friend. I pulled the yarn out before tightening that hidden screw that forces the seal to the chassis. Oh, and don't forget to loosen that screw all the way, just before it falls out before you start...you'll figure out how/why that works like that. Fairly over-engineered for so such a simple thing.
_________________ ------------------------
I am owned by a 1972 Westy named Sunny. She has a 1979 2.0L engine w/ dual Weber IDF 40s. |
WithTheFlow Samba Member
Joined: March 04, 2016 Posts: 197 Location: Wisconsin
Posted: Thu Jul 06, 2023 5:37 am Post subject: |
What does 19 do?
_________________ The fastest thing you can do is slow down.
“The secret is here in the present. If you pay attention to the present, you can improve upon it. And, if you improve on the present, what comes later will also be better."
-- The Alchemist” |
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 2113 Location: Huntington, WV for now
Scrumblero Samba Member
Joined: September 13, 2023 Posts: 21 Location: contado de contra costa
Posted: Wed Sep 27, 2023 10:46 am Post subject: Re: Installing sliding door track cover on a 72? |
I am trying to get this back on today. Does it need to be installed slightly forward and then slid back for the screw tab to go under the latch block on the front of the rail? Mine has been repaired at the front edge, so bending it to get the tab over is probably not an option without having to repaint it.  |
Posted: Wed Sep 27, 2023 1:30 pm Post subject: Re: Installing sliding door track cover on a 72? |
Never mind... I got it I just had to do some light trimming on the tab to get it to slide by
Scrumblero wrote: |
soissisc Samba Member
Joined: April 04, 2007 Posts: 742 Location: Western Pennsylvania
Posted: Thu Jul 17, 2025 2:19 pm Post subject: Re: Installing sliding door track cover on a 72? |
I know this is an old thread, but I got mine back together pretty easily. I loosened the screw on 19 and pushed rearward, until it gave the most clearance, and then carefully slid just the cover in place between 19 and the body, and then slid the seal in between the body and the cover. Then I tightened up the screw that pulled 19 into clamping position.
My 19 was pretty rust free and 2 of the 3 little clips were still there believe it or not.
I did have to bend that tab underneath on the front of the cover out a little bit to get it over the stop block on the body, but it easily just flexed back into the correct position so the screw from underneath could get started and tighten it down the rest of the way.
Now what holds that driver side cover on there so tight?!? _________________ Mark
68 Westy
92 Jetta (oh it is retired)
99 Eurovan
05 NBC
06 Audi A3
72 Westy (I am going to fix it up) |
