Porsche 912 12V 90 mm generator in a Type 3?
HenrikL
HenrikL is offline
PostPosted: Thu Sep 03, 2015 11:38 am    Post subject: Porsche 912 12V 90 mm generator in a Type 3? Reply with quote
From this thread:
www.thesamba.com/vw/forum/viewtopic.php?t=502713
Erik G wrote:
Could one take a 356 gen, put it on a laithe and mill the front (front of car) end off, then use the type 3 6v end cap? It wouldn't be cheap if you buy all your stuff retail, but I've had good luck getting 356 generators cheap. Keep in mind they are only 25 amp ...
Has anyone tried this? Is it possble to take the "12V parts" from the Porsche generator and put them in the Type 3 6V generator housing?
mackaymanx
mackaymanx is offline
PostPosted: Thu Sep 03, 2015 2:44 pm    Post subject: Reply with quote
You could use the generators from the industrial type 1 motors, 38 amps! We got them here in Australian on air compressors.
I see no reason why you couldn't adapt one but the long section of thread for the pulley would be at the wrong end.
Bobnotch
Bobnotch is offline
PostPosted: Thu Sep 03, 2015 7:44 pm    Post subject: Re: Porsche 912 12V 90 mm generator in a Type 3? Reply with quote
HenrikL wrote:
From this thread:
The person to ask would be Erik, as it sounds like he's done it before (using a Porsche generator). Or, you could locate a 12 V fan shroud, and then convert to a regular 12 volt generator, or even go with an alternator of your choice (use either a T-1 VW or a Mitsubishi forklift alt).
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
notchboy
notchboy is offline
PostPosted: Thu Sep 03, 2015 9:20 pm    Post subject: Reply with quote
notchboy wrote:
Mike Fisher wrote:
jimmynotch had his small 6V generator rebuilt into 12V.
I did as well for the Anthracite notch.
The OG 12v were a service vehicle M Code making them rare as hens teeth. Meant for Police-Fire-Ambulance vehicles. Somewhere, someone took a pic of a 12v gen on a service veh at a show from the 80's. Other than looking over a parts book code, Id of never known.
You can have the 6v one rewound for 12 volts.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
HenrikL
HenrikL is offline
PostPosted: Thu Sep 03, 2015 11:49 pm    Post subject: Reply with quote
Yes, I've got one of those industrial engine generators as well, but didn't know they had a different output than the 912 version.
Somehow I was hoping someone had tried this operation before. I do not want to destroy rare parts experimenting.
HenrikL
HenrikL is offline
PostPosted: Thu Sep 03, 2015 11:51 pm    Post subject: Re: Porsche 912 12V 90 mm generator in a Type 3? Reply with quote
Yes, changing fan shroud would be the obvious thing to do, but I want to keep the modifications to a minimum and everything to look stock.
HenrikL
HenrikL is offline
PostPosted: Thu Sep 03, 2015 11:53 pm    Post subject: Reply with quote
Looked into this option, but it seems that no one does that any more in Sweden. One auto electrics shop said "The guy who knew how to rewound died 20 years ago."..... Smile
gregson1
gregson1 is offline
PostPosted: Fri Sep 04, 2015 5:47 am    Post subject: Reply with quote
Expensive, but here's what you're looking for:
http://www.thesamba.com/vw//classifieds/detail.php?id=1147093
squaretobehip
squaretobehip is offline
PostPosted: Fri Sep 04, 2015 8:56 am    Post subject: Reply with quote
iSP West can have one done for you.
1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
ALLWAGONS
ALLWAGONS is offline
PostPosted: Fri Sep 04, 2015 10:02 am    Post subject: Reply with quote
Yeah!!!!! Applause
Erik G
Erik G is offline
PostPosted: Fri Sep 04, 2015 10:35 am    Post subject: Re: Porsche 912 12V 90 mm generator in a Type 3? Reply with quote
Bobnotch wrote:
HenrikL wrote:
From this thread:
Just to be clear, I never did it - was just being hypothetical
My 63 I prefer to keep it stock
HenrikL
HenrikL is offline
PostPosted: Mon Sep 07, 2015 12:10 am    Post subject: Reply with quote
Very nice, but I'm in Sweden and before that baby is on my doorstep it will have cost me about the same as an engine rebuild.
I also have the 912/industrial engine parts and it is tempting to try to use them.
HenrikL
HenrikL is offline
PostPosted: Fri Jun 30, 2017 12:25 am    Post subject: Re: Porsche 912 12V 90 mm generator in a Type 3? Reply with quote
Someone is now selling the parts for 12V conversion of the 90 mm generator. Type 1 shaft, but I guess that could be cut down to Type 3 length?
http://www.ebay.co.uk/itm/VW-Generator-Dynamo-Rebuild-Kit-12-Volt-Armature-/252942128597
notchboy
notchboy is offline
PostPosted: Fri Jun 30, 2017 3:15 pm    Post subject: Re: Porsche 912 12V 90 mm generator in a Type 3? Reply with quote
Are you still looking to do this change? Laughing
1964 1500 S
HenrikL
HenrikL is offline
PostPosted: Fri Jun 30, 2017 3:41 pm    Post subject: Re: Porsche 912 12V 90 mm generator in a Type 3? Reply with quote
It's only 2 years since I started the thread. My projects progress very slow. Very Happy
ataraxia
ataraxia is offline
PostPosted: Fri Jun 30, 2017 6:48 pm    Post subject: Re: Porsche 912 12V 90 mm generator in a Type 3? Reply with quote
The shop that sells this kit will also sell one for a Type 3 - or at least they told me they would when I called them a couple of years ago. Might be worth asking about if you don't want to do any modifications.
akokarski
akokarski is offline
PostPosted: Fri Jun 30, 2017 8:13 pm    Post subject: Re: Porsche 912 12V 90 mm generator in a Type 3? Reply with quote
T1 armature can be cut to fit into t3 generator. I had this done.
Anton
HenrikL
HenrikL is offline
PostPosted: Sat Jul 01, 2017 9:55 am    Post subject: Re: Porsche 912 12V 90 mm generator in a Type 3? Reply with quote
I did a check on my parts today. The left generator is a Type 1 12V 38A generator. The right is a 1964 6V Type 3 generator.
Note that the threads on the end is shorter on the Type 1 generator. The threads are 16 mm on the Type 3 and 12.5 mm on the Type 1.
This has the consequence that you can only use 4 shims if you want the pulley nut to use all threads on the shaft. Some machining of the pulley or washers may fix this, but for the moment I'm giving up on this solution.
Donnie strickland
Donnie strickland is offline
PostPosted: Sat Jul 01, 2017 10:43 am    Post subject: Re: Porsche 912 12V 90 mm generator in a Type 3? Reply with quote
Keep in mind also, that the Type 3 generator has a hole in the side to allow air from the fan housing to cool the generator. The Type 1 generator does not have that, instead receiving its cooling air through the front end.
How much effect this would have on longevity, I don't know.
71 Elm Green FI A/T Squareback
mackaymanx
PostPosted: Sat Jul 01, 2017 5:18 pm    Post subject: Re: Porsche 912 12V 90 mm generator in a Type 3? Reply with quote
The cooling hole is easy to put in.
[url=http://www.vw-mplate.com/mplate2-18600.png]Click to view image[/URL]
