What would cause timing surges and no throttle response...
Page: 1, 2, 3  Next
sb001
sb001 is online now
PostPosted: Wed Sep 09, 2015 9:36 pm    Post subject: What would cause timing surges and no throttle response... Reply with quote
..besides a vacuum leak?
I have tried and tried to get my engine running right since I reinstalled it a few weeks ago, but something is really wrong. At idle speed it constantly surges up about 200-300 RPMs then drops back down, sometimes stalling out. Timing surges with it so it is impossible to set timing, and when I do keep it running and try to drive it there is just about zero throttle response when I hit the gas. Almost like the distributor is completely sticking.
I have tried to think of everything that could be causing this- as mentioned my first thought was a vacuum leak. I sprayed everywhere with carb cleaner, and even disconnected all autostick-related vacuum hoses from the system and plugged all open ports before trying to set timing again, but still same problems. The other reason I disconnected all the autsotick hoses was because when I remove the electrical lead to the AS control valve, idle (and timing) seemed to jump up and stabilize- but only for a minute or so, then it was back to the same issue.
The distributor was cleaned and bench tested when engine was rebuilt so I have trouble thinking that's it, but I'm running out of ideas. The only other thing I can even remotely think of that might cause something like this is the torque converter not being fully seated and affecting crankshaft spin or something weird like that. I've had a couple of local VW club guys look at it and they are as stumped as I am. Any help or ideas would be appreciated, as I am out of ideas. I have a video too that I'll post if I can get it converted to a format that the site will accept..
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
Hnoroian
Hnoroian is offline
PostPosted: Wed Sep 09, 2015 9:58 pm    Post subject: Reply with quote
Restricting carbon built up in exhaust, or sticky Idle solenoid? Maybe your torkconverter is slipping some.
Stupid people do stupid things.
sb001
sb001 is online now
PostPosted: Thu Sep 10, 2015 1:10 am    Post subject: Reply with quote
Maybe-but it seems to repeat at a very regular rate, it will constantly surge for a few seconds, then idle back down for a few seconds, then surge again for a few seconds etc. I don't have an idle solenoid, but I would think a bad one of those would make it shut off completely.
I am beginning to wonder if the mechanical advance on my distributor is bad, it's such a regular interval and vacuum advance should theoretically have no effect at idle, but mechanical advance would... I just read this thread and his issue sounds very similar to mine:
http://www.thesamba.com/vw/forum/viewtopic.php?t=313207&start=0
1600 SP engine
morymob
morymob is offline
PostPosted: Thu Sep 10, 2015 3:26 am    Post subject: Reply with quote
Try another known good dizzy.
Kwig
Kwig is offline
PostPosted: Thu Sep 10, 2015 3:52 am    Post subject: Reply with quote
Look down inside the carburetor and make sure the accelerator pump tube is still attached and pointing down the center. I was having the same problems that you described a few weeks ago, found the accelerator tube pushed against the side of the carburetor. After repositioning it the idle surging went away and throttle response was back to normal.
sb001
sb001 is online now
PostPosted: Thu Sep 10, 2015 4:08 am    Post subject: Reply with quote
Thanks for the suggestion, already checked that though as well as all the gaskets around the carb. Nothing seems amiss there, shoots good amount of fuel down the carb throat when I pull the throttle arm and couldn't find any obvious vacuum leak around the carb. The way it acts when it surges (ALWAYS up to the same point and then back down again, sometimes immediately cutting out-- and at regular intervals) I almost have to think it's distributor related. Also in that thread that I linked above, they tested the distributor by rotating the rotor button and then letting it snap back, and they could move it further after the snap-back, and I am noticing the same issue with mine. It will snap back but then I can move it back around a bit further.
1600 SP engine
Miklo
¡Chale!
Miklo is offline
PostPosted: Thu Sep 10, 2015 6:47 am    Post subject: Reply with quote
X2.
An easy, quick way to totally eliminate one culprit.
There isn't much to a dizzy... A spring probably broke or fell off of a weight.
Miklo
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote:
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche...
TheAmazingDave
TheAmazingDave is offline
PostPosted: Thu Sep 10, 2015 8:43 am    Post subject: Reply with quote
If you're running points, try another condenser too, for shits 'n grins. I've seen some funky-running Bugs due to a condenser gone awry. One of them was "brand new" Chinese.
Just call me Big D. (formerly xBigDx408x)
TheAmazingDave.net
Deutschland Dubs 2015 at Presidio Trust
sb001
sb001 is online now
PostPosted: Thu Sep 10, 2015 3:01 pm    Post subject: Reply with quote
Maybe not, but I've never taken one apart before. Is there a good distributor disassembly thread on here to reference, I see the one recently posted but as that person did not actually take his mechanical advance apart I'm not sure it would help.
1600 SP engine
Mr.Duncan
Mr.Duncan is offline
PostPosted: Fri Sep 11, 2015 6:36 am    Post subject: Reply with quote
Sorry, dropped my phone down the stairs at work and my screen is shattered. Please contact me on here, or email.
Distributor was fine after I cleaned it up, and tested it in our Baja bug at the shop, but could have had a spring come loose in shipping.
Remove the condenser (important, keep the screw that holds the condenser grommet bracket with the same one, its a short screw, if you put a longer screw in there the distributor advance will hit it internally and lock it up.
, then inside, remove the vacuum can arm c-clip, and the two vacuum can screws, you will notice one of the vacuum can screws into the points plate grounding wire. Keep track of that.
Remove the vac can.
Now its time to remove the points plate.
Remove the two flat head screws that hold the arm clips that hold the cap down.
Now the points plate can be removed.
Check inside and make sure both springs are still attached to the advance mechanism, should look just like the below photo. Please note, the bottom spring in the photo appears to be "slightly" loose. This is normal.
http://www.thesamba.com/vw/forum/viewtopic.php?p=6701795
(Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
johnnypan
johnnypan is offline
PostPosted: Fri Sep 11, 2015 9:20 am    Post subject: Reply with quote
or just turn the distributor rotor by hand and see if it snaps back..if it doesnt,then do above^^^
sb001
sb001 is online now
PostPosted: Fri Sep 11, 2015 10:33 am    Post subject: Reply with quote
Remove the vac can.
Thanks man, I'll give it a shot!
As noted above I tried this, and it snaps back most of the way but I can still turn it a bit more with my fingers, it doesn't snap back to a completely stopped point.
1600 SP engine
sb001
sb001 is online now
PostPosted: Fri Sep 11, 2015 6:07 pm    Post subject: Reply with quote
OK, before I go any further taking this distributor apart, can someone tell me if this is normal:
Lots of slop on the bottom dog drive, you can see it crooked, it can move up and down a bit as well as side to side, is that normal? When I push it upward then it seems to hold in place and I can't move it side to side anymore, but it sure seems to be loose and drop back down easily to the position it is in in the photo. Also there is no pin or anything in that hole (is there supposed to be?)
Thanks
1600 SP engine
sb001
sb001 is online now
PostPosted: Fri Sep 11, 2015 6:21 pm    Post subject: Reply with quote
Video:
Notice that toward the end of the video I can push upward on the dog drive and it seems to lock into place (I can't wiggle it then.) But then I can pull it back down easily and it wiggles again.
1600 SP engine
Miklo
¡Chale!
Miklo is offline
PostPosted: Sat Sep 12, 2015 8:18 am    Post subject: Reply with quote
Have you had a chance to try this?
Miklo
'55 Type1 "Ozma"
sb001
sb001 is online now
PostPosted: Sat Sep 12, 2015 7:23 pm    Post subject: Reply with quote
No, because despite the commonly accepted philosophy on here, no one in the local VW club in my area who said they would help me out over the past 3-4 days (including borrowing another distributor to test) seem to bother to follow through on their promises.
1600 SP engine
vamram Premium Member
vamram is offline
PostPosted: Sat Sep 12, 2015 7:50 pm    Post subject: Reply with quote
Zoiks. You pissed some folks off if that's the case. Around here, v-dubbers will drive 50 miles if one of us needs something that another one has. Sheesh. Just buy the freaking Hot Spark unit then and be done w/it. If the problem persists w/the new dizzy, well...hell, I have no frackin' idea, so I'm just going to watch and see what happens.
Click to view image
Save the Supers!!
johnnypan
PostPosted: Sat Sep 12, 2015 8:58 pm    Post subject: Reply with quote
Well Ill be damned,I wonder why?
sb001
sb001 is online now
PostPosted: Sat Sep 12, 2015 9:39 pm    Post subject: Reply with quote
Nope that's not it. Don't have any delusions, I don't even hardly know any of these people. I've been to 2 of their meets. Guy running the show a) reneged on his deal with me to sell me some engine parts awhile back that I had responded to his craigslist ad for, shrugging it off that he "just decided to keep them instead" the first time I ever met him. Then reneged on his offer to help me rebuild and install the top end this time around. Now, when I post on their page that I was needing some help getting this problem solved, more posts of "sure we'll help you get it running" and "I have a distributor I'll let you borrow to see if that's the problem" go never followed through on. If there's one thing I can't stand-- more than any insults or the way I've been unfairly treated on here-- it's people who don't follow through on things and don't seem to care that they didn't. So much for the VW club mantra.
1600 SP engine
sb001
sb001 is online now
PostPosted: Sat Sep 12, 2015 9:42 pm    Post subject: Reply with quote
I didn't piss anyone off. I did absolutely nothing to offend anyone in this group. They just seem to have the philosophy that as long as they POST that they'll help, that's all that they really need to do to look good. And hell, their "inpromptu spontaneous meet today at Andy's Custard" or whatever sure is more important than helping a fellow VWer out- I mean, why wrench around helping someone when you can drive your RUNNING car?
1600 SP engine
Page: 1, 2, 3  Next
