Lifting a 2wd
solrankos
solrankos is offline
PostPosted: Wed Sep 16, 2015 2:54 am    Post subject: Lifting a 2wd Reply with quote
Ok i know this might seem ridiculous to some. But i would like to lift my 2wd to be able to fit 16" wheels. mainly cause it looks so damn cool!
After my research i came up with two alternatives.
1. Go Westy lift springs front and back plus upper ball joint spacers.
2. Spring spacers like these http://www.oberschlachter.com/shop/index.php?route..._id=100092
The second alternetive is the cheapest one. But i rellay don't know the pros and cons of the two alternatives. And also, is there something i'm missing?
Would love some help on this one
/Oscar
Jeff's Old Volks Home
Jeff's Old Volks Home is offline
PostPosted: Wed Sep 16, 2015 3:02 am    Post subject: Reply with quote
The GoWesty lift spring will improve the ride quality. They're easy to install. and they're priced decent too.
www.jeffsoldvolkshome.com
2004 Jetta TDi Wagon
2002 Smyth Ute TDi
1990 Vanagon weekender Syncro AAZ
1987 Syncro Doka AAZ...soon to be TDI Smile
2014 DL650ABS Xpedition
1986 Weekender Syncro (Under construction)
1987 Westfalia (Under construction)
1987 Syncro Single cab
vanagonjr
vanagonjr is offline
PostPosted: Wed Sep 16, 2015 3:06 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=636382&highlight=lift
http://www.thesamba.com/vw/forum/viewtopic.php?t=272234
http://www.thesamba.com/vw/forum/viewtopic.php?t=598340&highlight=lift
http://www.thesamba.com/vw/forum/viewtopic.php?t=321336&highlight=lift
http://www.thesamba.com/vw/forum/viewtopic.php?t=569578&highlight=lift
http://www.thesamba.com/vw/forum/viewtopic.php?t=243222&highlight=lift
http://www.thesamba.com/vw/forum/viewtopic.php?t=578224&highlight=lift
unplannedbbq
unplannedbbq is offline
PostPosted: Wed Sep 16, 2015 3:10 am    Post subject: Re: Lifting a 2wd Reply with quote
/Oscar
Welcome to the Samba. Lots of info here on this in many, many threads.
Based on your post, I suggest you look at the Prerunner thread (for us other knuckleheads with lifted 2wd vans) for ideas: http://www.thesamba.com/vw/forum/viewtopic.php?t=389820&highlight=prerunner
Think about your goals in fitting bigger rims. Overall tire size (diameter) is more important than wheel size. (Some folks squeeze 18" wheels with low-profile tires under lowered vans.) Most would not go over 27 or 28 inches with a stock gas engine and transaxle.
Be sure to read through the "ultimate" wheel and tire threads in the FAQ section at the top of the forum.
Use the search w/ "2wd lift" or "lifted 2wd" to find hundreds of other threads on topic, with a wide variety of lifting strategies and consequences.
'86 x-1wd, now w/ 2wd! Wolfsburg Weekender
"However not an ideal swap unless it was all you had and you needed to escape some distopian 3rd world country." - Mongoswede
solrankos
PostPosted: Wed Sep 16, 2015 3:50 am    Post subject: Reply with quote
Ok. Thanks for the quick replies. I will do some searching before i post the nex time Razz thanks!
vanagonjr
PostPosted: Wed Sep 16, 2015 9:13 am    Post subject: Reply with quote
Note there are (At least) 3 ways to search. Often, I find searching via Goolge, MUCH better than the TheSamba search engines, but I give those a try sometimes.
The 2 Samba ones are:
Type the tetm in the "search this forum" box towards the upper right after you are in the Vanagon forum. You can click within title, yet it returns thread in which the term is not in the title?!
The other is choose Forum then the Search and that works a bit better.
Hope that helps.
newfisher
newfisher is offline
PostPosted: Wed Sep 16, 2015 9:34 am    Post subject: Reply with quote
The 4th is once you are in the particular forum and enter the word or words in the search window, click the " title" box a d it will filter the specific word in the title of the thread...ie " lift " a d you wont get a thousand threads on interior mods that someone posted a sentence with that word buried 30 pages down.
tjet
tjet is offline
PostPosted: Wed Sep 16, 2015 1:48 pm    Post subject: Reply with quote
That's the company were I bought my 35mm lift kit from on my Syncro. Great customer service.
Here's how it looks on a Syncro with 215-75R15 tires & the kit below..
70coupyel
70coupyel is offline
PostPosted: Wed Sep 16, 2015 2:03 pm    Post subject: Reply with quote
A lot of folks around here do not understand about putting the right key words in the title. Plus in some build threads are some very good info about different parts of the build that you are looking for.
Bottom line it takes a lot time sometimes to become a better educated consumer. Think of it this way, 3 plus hours of time is time well spent. This is the internet. Info is not handed to you.
TheAndante wrote:
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc.
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer
