1958 rear tail light seal
lafireeasymedic
lafireeasymedic is offline
PostPosted: Thu Dec 24, 2015 2:17 pm    Post subject: 1958 rear tail light seal Reply with quote
I need the tail light seals that fit between the body and the chrome tail light. I believe the part number is 141-945-177 or 141-945-177A. I haven't been able to locate either new or used. Help!
sancho58
sancho58 is offline
PostPosted: Thu Dec 24, 2015 2:38 pm    Post subject: Re: 1958 rear tail light seal Reply with quote
I ordered mine from KGPR in Ventura about 4 months ago
lafireeasymedic
PostPosted: Sat Dec 26, 2015 11:11 pm    Post subject: Re: 1958 rear tail light seal Reply with quote
thanks, I found some!
lafireeasymedic
PostPosted: Fri Jan 01, 2016 3:55 pm    Post subject: Re: 1958 rear tail light seal Reply with quote
I still need help! What does the 2 additional screw holes in the body ajacent to the tail light lens attach to? Pictures or illustrations would be great. I have searched and could not find any info. Thanks again.
VeloMikey
VeloMikey is offline
PostPosted: Fri Jan 01, 2016 4:38 pm    Post subject: Re: 1958 rear tail light seal Reply with quote
What year is your car? Post a photo of the tail light opening.
'58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748
52 deelux
52 deelux is offline
PostPosted: Sat Jan 02, 2016 3:44 am    Post subject: Re: 1958 rear tail light seal Reply with quote
The two holes you refer to are for the up to mid '57 bulb housing. These use festoon type bulbs . If you have later bulb housing with bayonet bulbs these holes become redundant.
52 BD Deluxe
57 Ghia golde
54 Ragtop
52 deelux
PostPosted: Sat Jan 02, 2016 3:50 am    Post subject: Re: 1958 rear tail light seal Reply with quote
52 BD Deluxe
57 Ghia golde
54 Ragtop
lafireeasymedic
PostPosted: Sat Jan 02, 2016 6:06 pm    Post subject: Re: 1958 rear tail light seal Reply with quote
Thanks guys, for your help! The bulb holders that I have are the bayonette style. Now after 30 yrs of disassembly, I hope I can find the proper tail light lens screws. Anyone have the part numbers? My car is a 1958 coupe.
sputnick60
sputnick60 is offline
PostPosted: Sat Jan 02, 2016 6:28 pm    Post subject: Re: 1958 rear tail light seal Reply with quote
looking at my parts book….
reflector is held with 141 945 181 screw, cheese head - bulb holder up to chassis No. 1 708 049 qty=4
lens cover is held in with 141 945 185 Screw, countersunk raised head -Rim up to chassis 1 708 049 Qty = 4
My parts book only shows the Lowlight tail-light with the festoon bulbs.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
52 deelux
PostPosted: Sun Jan 03, 2016 1:02 pm    Post subject: Re: 1958 rear tail light seal Reply with quote
M4x20mm should be fine.
Slotted raised countersunk.
Easy to get in stainless steel, although the originals are plated brass.
52 BD Deluxe
57 Ghia golde
54 Ragtop
