Wout Samba Member
Joined: November 05, 2008 Posts: 90 Location: Belgium
Posted: Sat Oct 10, 2015 1:26 pm Post subject: |
Some new arrivals.
gr
Wout _________________ Aircooled vw's for life! |
garrett.fell Samba Member
Posted: Sun Nov 01, 2015 7:32 am Post subject: |
kai wrote: |
My Hazet wall mounted tool display board, found at Hessisch Oldendorf 2013:
not 100% complete, but most of the hard to find tools are there! |
What are the big "ring pliers" in the upper right hand corner used for? I believe they are Hazet 526. I just picked up a pair of these, but cannot determine their use. I was originally thinking they were for the big snap-rings that hold the axles / fulcrum plates in a VW transmission. |
Dutch79 Samba Member
Joined: October 21, 2013 Posts: 70 Location: Nederland
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Thu Nov 12, 2015 10:49 am Post subject: 610 |
Hazet Wrench 610 18/19mm
Tcash Samba Member
Posted: Thu Nov 12, 2015 10:53 am Post subject: 1821-2 |
NOS Hazet 1821-2 Pliers small A
Tcash Samba Member
Posted: Thu Nov 12, 2015 10:59 am Post subject: Hazet Wrench Holder for the 450 Wrench |
Hazet Wrench Holder. "For the 450 Wrench" is what the ad said.
composite Samba Member
Joined: August 11, 2011 Posts: 39 Location: Queensland
Posted: Sun Dec 06, 2015 4:48 pm Post subject: Re: Hazet 760 differences |
mikeandkirsti wrote: |
FRK wrote: |
760 - Locking Pliers & 1850-6 - Pliers
I came across similar 760 pliers with handle bars quite close to each other. It appears that the 760 design was changed about 1960 to this style and earlier ones have handle bars considerably farther apart. Can anyone confirm this or were the pliers just a bit different from batch to batch?
Here is a picture of my pliers:
They are in very good shape, obviously not bent and the bolt is not worn at all.
Early label seems to have pliers with handles farther apart:
a later label (1962?) has the handles closer to each other:
The later version of 760 with large HAZET lettering (post 1965) again has the handles more apart as does 760-3 like the earlier versions.
Comments please. |
Don't know about this but I grab a couple of tools from my kits. One with the "L" and one without. Will need to check out some of my other ones as well.
Wout Samba Member
Posted: Sat Dec 19, 2015 2:41 am Post subject: Re: Hazet Tools w/photos |
Maybe this helps?
Some of mine, pré 65 and after
gr
easy e Samba Member
Joined: May 28, 2008 Posts: 3939 Location: 1 hr north of Santa Barbara
Posted: Sun Jan 10, 2016 12:55 pm Post subject: Re: Hazet Tools w/photos |
I picked up this Hazet Tourist yesterday... I think it's 52-55... because it has a single ended large box-end, 7x8 small wrench, felt (not flock)
Edit 1/18/2016:
With some help from mikeandkirsti... I'll be getting the correct 760 pliers for this kit with the "L" line under the Hazet brand.
Here's some info Mikael shared:
Your kit is from about 1954 to 1955. The short stubby screwdriver and 7X8 and 10X12 wrenches were introduced for 1953 when the Zwitter came out. 1952 tools have 7X9 and 10 mm and 14 mm wrenches and only two screwdrivers.
The 12 mm wrench cannot be used in an earlier Split as there are no 12 mm nuts or bolts used. That makes your kit definitely 1953 or newer. I think that these kits became more common around 1954-55 when exports to the US picked up speed.
In late 1955 the 764 spark plug wrench was made longer to 113 mm, I think yours is still 111 mm making it mid 1955 or earlier. I think that the felt was dropped by early 1956 too. You have the wrong 760 pliers (much newer) but rest of the tools seem correct.
_________________ aka: Evan
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35820 Location: Conejo Valley, CA
Posted: Sun Jan 10, 2016 2:54 pm Post subject: |
Those are probably missing the return spring that goes between the lower two "tits" on the inside of the handles. |
lite Samba Member
Posted: Sat Jan 23, 2016 3:58 pm Post subject: Re: Hazet Tools w/photos |
Hi.
Im New to this forum and i did it just because of this thread as i see there's alot of info on the old Hazet Tools.
I see @paal is looking for info on a key, long time ago, did you get what you need? else i might be able to help you.
Picked up a 100 if i'm correct, for 50's or early 60's. Bit ruff but Nice.
Not sure what value, if any, on these?
Got it With a socket wrench (916), some pipes and that's about it.
I'll see if i post Pictures of the rest, if ther's any life to this thread  |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71468 Location: Phoenix 602
lite Samba Member
Posted: Sun Jan 24, 2016 1:07 am Post subject: Re: Hazet Tools w/photos |
Great.
I'm all New to Hazet Tools, this is my first "set" of vintage Hazets. I have other vintage Tools, but not hazet, dont know if ther's another thread you think i should post Pictures of my vintage torches and stuff?
Anyhow, I'll snap some Pictures of the inside of the cabinet and the Tools i got. After a ebay search and looking through info on this site i see some of these Things are quite valuable
I got these from an "estate sale" (if that is the correct term).
Pictures will come. If requested, i'll post some of my other reasent findings.
Sorry that my English is a bit faulty, Im from Norway and my spell check has failed :p |
Wout Samba Member
Posted: Sun Jan 24, 2016 11:38 am Post subject: Re: Hazet Tools w/photos |
Welcome!
Nice score on your 100 cabinet!
Most expensive and difficult part is now to fill it with the right tools ...
good luck!
gr
lite Samba Member
Posted: Wed Jan 27, 2016 3:44 am Post subject: Re: Hazet Tools w/photos |
Thanks for the reply on my previous post
Here are a few pictures on the inside, sorry I didn't empty it first of the non hazet tools I have in there now.
A bit rust inside, but not to bad I think
Anyhow I find it a bit to big for where I have it, so not sure if I might sell it and buy something else.
Was offered an old "assistant" (the bigger one with 4 rooms) plus about 200 euros for it, but I'm not sure what it's worth? I cant find another one like it for sale, and I saw one earlier advertised for 690 pound if I don't remember wrong. Can anyone estimate a price on this thing?
Not sure if I'm going to let it go thoug, but the assistant and money is a bit tempting as I can have good use of that assistant But in the next year I'm going to redo the "hobby room" in the house and if I change the plans a bit ther will be room for the 100, I think .... hmm... Hard to know what to doo, but It cannot sit wher it's at now forever .
Then there is one more question to you guys (and girsl?), I found this vise with the hazet tools I got, but I do not know if it's an hazet? It does not have any markings as I can find, but then again it's small and used. anyone?
Thankyou.
And I would really appreciate any feedback on value of the 100  |
Tcash Samba Member
Posted: Fri Feb 05, 2016 1:53 pm Post subject: Hazet 1/4" socket set 850 and 854 |
Tcash Samba Member
Posted: Fri Feb 05, 2016 1:54 pm Post subject: Hazet #772 lug wrench |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22659 Location: Escondido CA
Posted: Fri Feb 05, 2016 8:07 pm Post subject: Re: Hazet Tools w/photos |
Who was making the repop Hazet Stools that fit into the Assistent? I need one and failed to order it a month or so ago.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Tcash Samba Member
Posted: Tue Feb 09, 2016 7:54 am Post subject: Hazet 764 |
Hazet 764 Spark plug wrench
kahmie Samba Member
Joined: September 19, 2014 Posts: 4 Location: Germany
Posted: Wed Apr 06, 2016 3:37 am Post subject: Hazet 100 |
@ lite:
too bad that a previous owner had damaged the doors. Probably to open the drawers to be able, without the doors unfold far enough.
In this state, it will perhaps be worth € 200.
@ all:
I could not find this Hazet-box in any catalog. It is probably a "Hazet 1000". Does anyone know the correct content?
Thanks and greetings from southern Germany,
Kahmie |
