AceDanger Samba Member
Joined: December 19, 2010 Posts: 5 Location: Corvallis, OR
Posted: Wed Aug 10, 2011 2:24 pm Post subject: Re: Thread serves it's purpose |
| hforo wrote: |
I'm glad that you found this thread before your van melted down! It's really a shame all the stories I've been hearing about SC lately. Not to make this a SC bashing thread, but there is a lot of evidence here that they absolutely should address.
My 2 cents.
| AceDanger wrote: |
My good friend and I have just spend the last few months completing a 2.2 swap. I came to here today to look for advice on a coolant problem and found this thread, read in a ways and realized we had had the EXACT SAME EXPERIENCE. Tried to fit the pan, hit THAT bolt, called small car, talked to Mao who told us "it's nothing, pull it" and we did. The car has been started and ran to warm 3 times and we can't figure out why the coolant system isn't working, thank god it's not because if it had been we'd have drove off.
Looks like i'll be calling SC and having a word
So if it's any consolation, you're experience just saved me my bus, thanks for posting. |
ok, so. Called small car and talked to them. Looks like a small percentage, not sure how small, nor what the possible year/model it could be, have a hole leading all the way through. In that case, bad news. However, in most models it doesn't go through and you don't need the bolt at all. I called my friend/mechanic who talked to SC the first time back when we were doing the work and he said that Mao told him to stick a pen or screwdriver or something up there to see if it goes through, if not, yhatzee. He had done that and turns out my engine is not one of the ones that that bolt is mandatory for.
In the end, the guys at SC have been AWESOME! but they are a small shop doing something that not a lot of people are doing. They are learning along the way too. When i talked to Mao he brought up the Original thread starters case specifically and said until then he hadn't run into any of this type of ej22 before and now he knows to tell people to check, which it turns out he had told me/us.
Just wanted to clear the air, that is all |
J Charlton  Samba Member
Joined: August 24, 2007 Posts: 1546 Location: The True North Strong and Free
Posted: Wed Aug 10, 2011 3:19 pm Post subject: small car |
I can't speak to the experiences of others, only mine. I was one of the first to use their bell housing on my suby conversion - there were "teething" problems and I was into V3 before it was all resolved. Through it all, I found Brian and Mao to be available, helpful and thorough. Last year in August, I had a clutch pressure plate fail - Mao got me the parts I needed in Amarillo Texas within 24 hrs - back on the road within 48 hours of breakdown - the SC shortened pan fit my 2.5 fine and I have had no issues with it. I'm adding this to the thread because I just got off the phone with SC - the bracket holding my VSS came loose, sensor touched the rotating magnets, sensor is toast - Mao know exactly whyat I needed and its on its way - I'd use their stuff again - I wish they did a complete selection of stuff for diesel conversions - I'd use it. _________________ NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024 |
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Sodo Samba Member
Joined: July 06, 2007 Posts: 10934 Location: Western WA
Posted: Fri Feb 19, 2016 9:55 pm Post subject: Re: Major disaster with Small Car oil pan upgrade ~ HELP!! |
Does anybody know what those two large ports are ABOVE the pickup tube? They are outside the oilpan, blocked with 12mm allen plugs. Are those ports for an oil cooler?
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12438 Location: Santa Cruz, CA
Posted: Fri Feb 19, 2016 9:58 pm Post subject: Re: Major disaster with Small Car oil pan upgrade ~ HELP!! |
| That's the oil pump. |
AKWesty Samba Member
Joined: April 12, 2014 Posts: 680 Location: Haines, Alaska
Posted: Fri Feb 19, 2016 10:43 pm Post subject: Re: Major disaster with Small Car oil pan upgrade ~ HELP!! |
I have been meaning to post these pictures for a while. I had not come across this thread before and could not believe what I was reading. If you get a small car pan and you have an early noninterference EJ22....Do not remove the PLUG! ( unless you have an oil pressure gauge). Seems like a crap shoot
I have a 91 EJ22 and Tom Shiels thermostat housing. Here is the work you can expect when installing your oil pan.
_________________ 84' Westy 2wd
EJ22 - 4spd - Peloquin TBD
GW +1.5 Springs
215/70-16's
www.CatchTheKraken.com
"Never go to Alaska as a young man because you'll never be satisfied with any other place as long as you live." -John Muir |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17385 Location: Brookeville, MD
Sodo Samba Member
Posted: Sat Feb 20, 2016 8:24 am Post subject: Re: Major disaster with Small Car oil pan upgrade ~ HELP!! |
Sorry for off-topic,,,, but I thought this 2011 post was run out. Strange that there could be some engines with a plugged port (inside) and some with just a "dummy plug". And that Smallcar had not yet come across an engines where the plug was a galley plug. Good for AKWesty to clarify that on early non-interference engines you cannot remove that plug. Anyway it looks like some good info has been added since I revived it from dead.
Hoping to catch members who knew stuff about the EJ oiling system, or know of modifications. Has anyone re-plumbed those ports for an oil cooler or additional reservoir? I'm more interested in adding another quart to the engine. I know it's sort of the wrong place to add capacity but just trying to get ideas.
tschroeder0 Samba Member
Joined: April 14, 2008 Posts: 2098 Location: Boulder CO
Posted: Sat Feb 20, 2016 9:02 am Post subject: Re: Major disaster with Small Car oil pan upgrade ~ HELP!! |
Orin- sorry to hear about your experience and you have handled the blasting by the forum members well.
I personally know of three people who have had the exact same fitment issues with the SC pan and one who was told to remove the plug as you were. He did and realized that this was going to be a problem and avoided disaster. But he was told to do it and he is not a seasoned mechanic, hence the phone call in the first place.
Should you have questioned the no oil pressure, of course, can we all make some really dumb mistakes when we are in the thick of something we dont know that much about and have been told to do something by a pro that we think we can trust, absolutely.
when you pay good money for a product you should get good instructions and a product that fits. Small car makes some great products, but my recollection here and personally is that the oil pan has had issues for a long while. |
