crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10398 Location: Orbiting San Diego
Posted: Tue Mar 15, 2016 9:38 am Post subject: Re: Hard start relay for Auto w/cruise |
The conflict between factory cruise/auto and an added start relay has nothing to do with whether the start relay is added up front or in the back. The conflict will be there in either case.
Mark |
fxr Samba Member
Joined: December 07, 2014 Posts: 2658 Location: Bay area CA
Posted: Tue Mar 15, 2016 9:50 am Post subject: Re: Hard start relay for Auto w/cruise |
Unless the auto has a different ignition switch then replacing the 'start position' contacts with relay contacts cannot cause any conflict. _________________ Jim Crowther
Vespa GTS 300 |
Terry Kay Banned
Posted: Tue Mar 15, 2016 9:59 am Post subject: Re: Hard start relay for Auto w/cruise |
No difference in the switch regardless what trans, with or without cruise. _________________ T.K. |
Posted: Tue Mar 15, 2016 10:00 am Post subject: Re: Hard start relay for Auto w/cruise |
That depends on how you wire it in, not whether the relay is in the front or the back.
Mark
fxr wrote: |
Unless the auto has a different ignition switch then replacing the 'start position' contacts with relay contacts cannot cause any conflict. |
fxr Samba Member
Posted: Tue Mar 15, 2016 11:07 am Post subject: Re: Hard start relay for Auto w/cruise |
crazyvwvanman wrote: |
Mark
fxr wrote: |
Of course - my point was that on an auto you should still be able to use a relay to hugely reduce the current that the ignition contacts have to endure. The onrush current of the solenoid is pretty big, and it's no wonder the ignition switch contacts eventually arc/go high res/fail and cause hard starting. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Tue Mar 15, 2016 12:43 pm Post subject: Re: Hard start relay for Auto w/cruise |
The relay kit uses a much shorter wiring path in addition to bypassing the dash switch so you get benefit from the higher voltage at the solenoid too.
The issue isn't auto tranny, it is the way VW implemented cruise on auto tranny vans. It is the auto version of the cruise that creates the conflict. No cruise, no conflict with the cruise.
The conflict has nothing to do with the high current side of the relay or the relay contacts. The conflict is on the relay coil side.
Mark |
fxr Samba Member
Posted: Tue Mar 15, 2016 5:12 pm Post subject: Re: Hard start relay for Auto w/cruise |
I repeat - there's no reason why you can't use a relay to bypass the ignition switch contacts - just to protect them, nothing else.
You may have misunderstood my point. _________________ Jim Crowther
Vespa GTS 300 |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1173 Location: SF Bay area, CA
Posted: Wed Mar 16, 2016 7:27 am Post subject: Re: Hard start relay for Auto w/cruise |
Mark,
I'm in touch with Jay Brown and have sent him your suggestion to review. I truly appreciate everyone's comments.
Craig _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
Timwhy Samba Member
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15386 Location: Syracuse, NY
Posted: Wed Nov 08, 2017 10:03 pm Post subject: Re: Hard start relay for Auto w/cruise |
Tim it's just a standard 30amp relay.
but it's the cruise control relay that interfers with the automatic hard start relay installation. if you connect it like normal it'll trigger and lock the starter in the On position..
I'm not sure exactly how you need to bypass/disable the rely.. ie. if the wire gets snipped or connected.. have to do a little more research..
I'd be very interested in your old CC bits (control unit/wire harness/stalk swap/vac pump) even planning a VW trip to maine this next summer..
lets talk..
Dan
Timwhy wrote: |
I would like to add this relay too my TinTop, but have a question on what type and amperage relay are we to use?
My TinTop came with cruise control but it doesn't work and would like to eliminate it at the same time when
adding the relay. |
Abscate wrote: |
Timwhy Samba Member
Posted: Thu Nov 09, 2017 8:08 am Post subject: Re: Hard start relay for Auto w/cruise |
Tim I'd have to dig up the wiring diagram again.
but in the AT with CC, The Cruise relay is more of an ignition interrupt so you can't set the cruise in Neutral (iirc).
but the Cruise relay back feeds the starter trigger wire (energized when cranking) in a traditional hot start relay install. and causes the relay to keep the starter on when you release the key. making really ugly contact with the ring gear on the now running engine.
again this is a quick as I recall..
I'm sure the CC relay can be "defeated" to allow install of a hot start relay.
as mentioned , I don't know if it requires removing the relay, cutting the wire to it or joining the wire to it.. _________________
Abscate wrote: |
Cody2289 Samba Member
Posted: Wed May 29, 2024 4:08 pm Post subject: Re: Hard start relay for Auto w/cruise |
Did anyone ever figure this out? Whether simply removing the cruise relay would allow a hard start relay? My cruise doesn’t work anyway |
jlrftype7 Samba Member
Posted: Wed May 29, 2024 5:07 pm Post subject: Re: Hard start relay for Auto w/cruise |
Cody2289 wrote: |
What about a diode installed to prevent back feeding of the Cruise Relay. Just spit balling here without a wiring diagram in front of me.  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Sun Jun 29, 2025 11:09 am Post subject: Re: Hard start relay for Auto w/cruise |
Does anyone know where I can get a look at the Hard Start Relay Kit wiring diagram? Mine's from the original Jay Brown (thanks, Jay!!) and I'm having an unrelated starter issue. Want to know what I'm looking at under there before going out. I see Uniworks now has the rights, etc for this product but they don't provide a diagram (completely understandable, of course). Anyone out there willing to PM it to me to keep it out of the public domain, etc? Thank you in advance.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Sun Jun 29, 2025 2:04 pm Post subject: Re: Hard start relay for Auto w/cruise |
Nmind. Cleaned up the connections and she starts fine. Argh. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
