Hard start relay for Auto w/cruise
Page: Previous  1, 2
crazyvwvanman
crazyvwvanman is offline
PostPosted: Tue Mar 15, 2016 9:38 am    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
The conflict between factory cruise/auto and an added start relay has nothing to do with whether the start relay is added up front or in the back. The conflict will be there in either case.
Mark
fxr
fxr is offline
PostPosted: Tue Mar 15, 2016 9:50 am    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
Unless the auto has a different ignition switch then replacing the 'start position' contacts with relay contacts cannot cause any conflict.
Jim Crowther
Vespa GTS 300
Terry Kay
Banned
Terry Kay is offline
PostPosted: Tue Mar 15, 2016 9:59 am    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
No difference in the switch regardless what trans, with or without cruise.
T.K.
crazyvwvanman
PostPosted: Tue Mar 15, 2016 10:00 am    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
That depends on how you wire it in, not whether the relay is in the front or the back.
Mark
fxr
fxr is offline
PostPosted: Tue Mar 15, 2016 11:07 am    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
Mark
Of course - my point was that on an auto you should still be able to use a relay to hugely reduce the current that the ignition contacts have to endure. The onrush current of the solenoid is pretty big, and it's no wonder the ignition switch contacts eventually arc/go high res/fail and cause hard starting.
Jim Crowther
Vespa GTS 300
crazyvwvanman
PostPosted: Tue Mar 15, 2016 12:43 pm    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
The relay kit uses a much shorter wiring path in addition to bypassing the dash switch so you get benefit from the higher voltage at the solenoid too.
The issue isn't auto tranny, it is the way VW implemented cruise on auto tranny vans. It is the auto version of the cruise that creates the conflict. No cruise, no conflict with the cruise.
The conflict has nothing to do with the high current side of the relay or the relay contacts. The conflict is on the relay coil side.
Mark
fxr
fxr is offline
PostPosted: Tue Mar 15, 2016 5:12 pm    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
I repeat - there's no reason why you can't use a relay to bypass the ignition switch contacts - just to protect them, nothing else.
You may have misunderstood my point.
Jim Crowther
Vespa GTS 300
cmayna
cmayna is offline
PostPosted: Wed Mar 16, 2016 7:27 am    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
Mark,
I'm in touch with Jay Brown and have sent him your suggestion to review. I truly appreciate everyone's comments.
Craig
'90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig
Timwhy
Timwhy is offline
PostPosted: Wed Nov 08, 2017 3:34 pm    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
I would like to add this relay too my TinTop, but have a question on what type and amperage relay are we to use?
My TinTop came with cruise control but it doesn't work and would like to eliminate it at the same time when
adding the relay.
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
danfromsyr
danfromsyr is offline
PostPosted: Wed Nov 08, 2017 10:03 pm    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
Tim it's just a standard 30amp relay.
but it's the cruise control relay that interfers with the automatic hard start relay installation. if you connect it like normal it'll trigger and lock the starter in the On position..
I'm not sure exactly how you need to bypass/disable the rely.. ie. if the wire gets snipped or connected.. have to do a little more research..
I'd be very interested in your old CC bits (control unit/wire harness/stalk swap/vac pump) even planning a VW trip to maine this next summer..
lets talk.. Wink
Dan
adding the relay.
Abscate wrote:
Timwhy
Timwhy is offline
PostPosted: Thu Nov 09, 2017 7:57 am    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
Thanks Dan. So the 30 amp relay doesn't replace the cruise relay in the fuse box? Can the cruise relay be taken out to add the hard start relay?
'15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
danfromsyr
PostPosted: Thu Nov 09, 2017 8:08 am    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
Tim I'd have to dig up the wiring diagram again.
but in the AT with CC, The Cruise relay is more of an ignition interrupt so you can't set the cruise in Neutral (iirc).
but the Cruise relay back feeds the starter trigger wire (energized when cranking) in a traditional hot start relay install. and causes the relay to keep the starter on when you release the key. making really ugly contact with the ring gear on the now running engine.
again this is a quick as I recall..
I'm sure the CC relay can be "defeated" to allow install of a hot start relay.
as mentioned , I don't know if it requires removing the relay, cutting the wire to it or joining the wire to it..
Abscate wrote:
Cody2289
Cody2289 is offline
PostPosted: Wed May 29, 2024 4:08 pm    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
Did anyone ever figure this out? Whether simply removing the cruise relay would allow a hard start relay? My cruise doesn’t work anyway
jlrftype7
jlrftype7 is offline
PostPosted: Wed May 29, 2024 5:07 pm    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
What about a diode installed to prevent back feeding of the Cruise Relay. Just spit balling here without a wiring diagram in front of me. Smile
‘84 Tin Top - Hilga....Auto
IdahoDoug
IdahoDoug is offline
PostPosted: Sun Jun 29, 2025 11:09 am    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
Does anyone know where I can get a look at the Hard Start Relay Kit wiring diagram? Mine's from the original Jay Brown (thanks, Jay!!) and I'm having an unrelated starter issue. Want to know what I'm looking at under there before going out. I see Uniworks now has the rights, etc for this product but they don't provide a diagram (completely understandable, of course). Anyone out there willing to PM it to me to keep it out of the public domain, etc? Thank you in advance.
Doug
IdahoDoug
PostPosted: Sun Jun 29, 2025 2:04 pm    Post subject: Re: Hard start relay for Auto w/cruise Reply with quote
Nmind. Cleaned up the connections and she starts fine. Argh.
Page: Previous  1, 2
Page 2 of 2
