Transmission help
Dericksen22
Dericksen22 is offline
PostPosted: Mon May 16, 2016 6:12 pm    Post subject: Transmission help Reply with quote
Hey everyone,
So I am having some serious issues on trying to get info admit a trans axle I got out of a sand rail and trying to put in my bay wind.
The entire ring and pinion sheared CLEAN off and I would like to just rebuild it because I don't have a big budget at all to spend 1500 on a rebuilt one.
Id # is 002.301.103 A
Any help would be greatly appreciated
busdaddy
busdaddy is offline
PostPosted: Mon May 16, 2016 7:21 pm    Post subject: Re: Transmission help Reply with quote
Welcome.
That number is for the casting of the case, you are looking for a flat area with stamped in numbers/letters to ID it, usually on the side between the drain plugs.
A trans that's been blown up in a sand rail is a core IMO, not worth the time to try and fix without serious professional help.
Слава Україні!
skills@eurocarsplus
Samba Peckerhead
PostPosted: Mon May 16, 2016 7:30 pm    Post subject: Re: Transmission help Reply with quote
I agree. cut your losses and buy a used one that can be confirmed good. I bet there is very little useable inside that transmission.
if you can't swing the $$ for one just save up
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
aeromech
aeromech is offline
PostPosted: Mon May 16, 2016 7:33 pm    Post subject: Re: Transmission help Reply with quote
You broke the worst possible part. As others have said its best to start over with your search
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Dericksen22
PostPosted: Mon May 16, 2016 7:46 pm    Post subject: Re: Transmission help Reply with quote
Thanks a lot guys. I appreciate the replys a lot.
Any idea what kind I should go with? Is there an automatic optio. That won't take much fab work that mounts to the original irs?
And where I would find one?
SGKent Premium Member
SGKent is offline
PostPosted: Mon May 16, 2016 10:56 pm    Post subject: Re: Transmission help Reply with quote
geez. I spent close to $4500 rebuilding an 091 to factory spec last year and you are complaining about $1500? It hurts my ears because it is like hearing a 16 year old say "and now after I got my car I have to buy gasoline, oil changes, and insurance? That is really screwed man. Life should be easier."
madmike
madmike is offline
PostPosted: Tue May 17, 2016 3:10 am    Post subject: Re: Transmission help Reply with quote
You spent to much Shocked
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
Tcash
Tcash is offline
PostPosted: Tue May 17, 2016 12:31 pm    Post subject: Re: Transmission help Reply with quote
Any idea what kind I should go with? Is there an automatic option. That won't take much fab work that mounts to the original irs?
vw made a couple automatics for Buses. But from what I understand it is huge pain to adapt from a standard trans to an auto.
Trans seach
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search
These are the numbers you are looking for.
Transmission ID, Codes, Gears and Years
Chances are they will not accept your old trans as a core. So plan to pay the core charge on top of the purchase price.
http://ranchotransaxles.com/vw-transaxles/
http://www.aatransaxle.com/price_list.htm
Good luck
Tcash
SGKent is offline
PostPosted: Tue May 17, 2016 12:39 pm    Post subject: Re: Transmission help Reply with quote
Wrong again Mike. I personally re-manufactured it, and replaced all worn parts while doing it. All bearings are original and not Chinese copies. Most of the rebuilt trans sold are not as good as when new - they are rebuilt to make your budget happy - not re-manufactured to factory specs. This one is like new. If you want a trans re-manufactured to factory specs you will spend very close to $5,000 USD. That is a fact of life. That does not include the cost of tools. As I recall the factory tool set is almost that cost by itself.
Dericksen22
PostPosted: Tue May 17, 2016 5:55 pm    Post subject: Re: Transmission help Reply with quote
Ok guys I finally cleaned it up and found the stamped numbers. Can anyone tell me year make and model of this thing? And what size ratio the ring and pinion is?
CA0832689
skills@eurocarsplus
Samba Peckerhead
PostPosted: Tue May 17, 2016 6:03 pm    Post subject: Re: Transmission help Reply with quote
what year bus? 002 was a common trans.
call Benco....I have been punishing one of his units with lots and lots of power running thru it for over 3K miles. I am happy with it
your run of the mill used box will be in the 3-500 range.
Jake Raby wrote:
Brian wrote:
Dericksen22
PostPosted: Tue May 17, 2016 6:07 pm    Post subject: Re: Transmission help Reply with quote
Skills.....my bus is a 70 but the trans did not come with it. I got the motor and trans out of a buggy.
I An trying too figure out what tranny it is for parts etc....
skills@eurocarsplus
Samba Peckerhead
PostPosted: Tue May 17, 2016 7:10 pm    Post subject: Re: Transmission help Reply with quote
post a picture. it's probably a run of the mill 002....it's nothing special. I have a barn with about 20 of them stacked like wood....they are quite available. from your description, your trans is junk...perhaps the case is useable, but that's probably it. if the R+P are trashed (as you said) there is literally NO value in it.....the money is in that R+P
I hate to sound like a dick or do I? but if you don't have the coin for this bus, STOP, just STOP....you will keep throwing what little you have in these "good deals" and just get burnt. this is decades of experience speaking here...there is NOTHING cheap about owning one of these, trust me
Jake Raby wrote:
Brian wrote:
Tcash
Tcash is offline
PostPosted: Tue May 17, 2016 9:10 pm    Post subject: Re: Transmission help Reply with quote
CA0832689
