Russ Samba Member
Joined: January 12, 2003 Posts: 1560 Location: Langley B.C.
Posted: Thu Jun 23, 2016 7:45 am Post subject: Does anybody make a rear axle nut cover? |
Hi there
does anybody know if some one makes rear axle cover, before I try machining one up.
I am running 944 spares (like the Porsche outlaws on my 65)
in the fronts I chromed the dust covers to match the polished wheel.
for the back I tried a chrome axle nut and it just didn't cut it.
you can see my front wheel with the chromed cap
and the next picture id not great but it shows just a black nut on the rear
thanks for any help
Russ
_________________ Cruiser pedals for sale (see my ad's)
55 hardtop finally finished
65 beetle done:) |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Thu Jun 23, 2016 7:57 am Post subject: Re: does anybody make a rear axle nut cover? |
I've seen one outlaw 356 with the covers made out of an old muffin tin found at the second hand store
or measure the hole size and look for a press in cover. I sourced some for mine on ebay. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked  |
Russ Samba Member
Posted: Thu Jun 23, 2016 8:28 am Post subject: Re: does anybody make a rear axle nut cover? |
60ragtop wrote: |
or measure the hole size and look for a press in cover. I sourced some for mine on ebay. |
ok thanks i'll see what I can find
do you have pics of yours on? _________________ Cruiser pedals for sale (see my ad's)
65 beetle done:) |
Posted: Thu Jun 23, 2016 9:45 am Post subject: Re: does anybody make a rear axle nut cover? |
tasb wrote: |
sb001 wrote: |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Thu Jun 23, 2016 4:30 pm Post subject: Re: does anybody make a rear axle nut cover? |
That cover begs to be spun from stainless steel sheet and polished....or die-stamped... _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Keith Samba Member
Joined: August 15, 2005 Posts: 3632 Location: Brodheadsville, PA
Posted: Fri Jun 24, 2016 5:58 am Post subject: Re: does anybody make a rear axle nut cover? |
They make covers for the rear axle bolt on motorcycles. Search eBay and you might find what you need in the correct 36mm size. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11160 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri Jun 24, 2016 6:02 am Post subject: Re: does anybody make a rear axle nut cover? |
^ ha Keith.. ya...just beat me to it..
Think.. 2 wheels and chrome...
Lots of motorcycle dress parts are simple nut covers..
Harley 36mm nut covers..
http://www.ebay.com/itm/Drag-Specialties-Hotop-Des...mp;vxp=mtr
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Russ Samba Member
Posted: Fri Jun 24, 2016 7:22 am Post subject: Re: does anybody make a rear axle nut cover? |
Dr OnHolliday wrote: |
That cover begs to be spun from stainless steel sheet and polished....or die-stamped... |
I kind of agree with you, we have lids spun for us from a shop but I'm pretty sure they won't just do a small job for me. I was going to use aluminum out of a solid bar that flares in behind the wheel
but for a quick fix I may look in to bike parts.
I had no idea they used a 36mm thanks guys that's perfect _________________ Cruiser pedals for sale (see my ad's)
65 beetle done:) |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1026 Location: South Florida
Posted: Fri Jun 24, 2016 11:01 am Post subject: Re: Does anybody make a rear axle nut cover? |
Stop in at any major truckstop along most any interstate highway, and you'll probably find what I found: The cheapy chrome lugnut covers for 18 wheelers fit the VW rear axel nut perfectly (and their bumper bolt covers fit VW lug bolts as well). You probably can't read the price tag on the one I'm holding in this pic, it's 59ยข
Scott65Beetle Samba Member
Posted: Fri Jun 24, 2016 11:51 am Post subject: Re: Does anybody make a rear axle nut cover? |
^Ken,I'm kind of in the same boat,followed your link and 'Oh I think not". A wee bit pricey mate. |
Posted: Fri Jun 24, 2016 2:06 pm Post subject: Re: Does anybody make a rear axle nut cover? |
Scott65Beetle wrote: |
There are cheaper alternatives... now that you know what to look for..
Use a chrome easter eggs... well half of one..
The Dorman help line at most parts houses hav dust caps that WILL work
http://www.dormanproducts.com/gsearch.aspx?type=keyword&origin=keyword&q=dust+cap
Specifically http://www.dormanproducts.com/p-1477-13976.aspx?origin=keyword
Just use some high strength RTV , let cure and done..
Plus Exactly as tunes mentioned..
Semi trucks also have BIG NUTS and truckers love chrome too.
I was raised in a trucking family with... big nuts..... ... I even added truck lug caps to my caps..
Russ Samba Member
Posted: Fri Jun 24, 2016 4:52 pm Post subject: Re: Does anybody make a rear axle nut cover? |
the semi ones may almost be perfect
awesome thanks _________________ Cruiser pedals for sale (see my ad's)
65 beetle done:) |
