Finding vacuum leaks with smoke (smoke test, tester)
sixer
sixer is offline
PostPosted: Mon Feb 23, 2015 7:28 pm    Post subject: Finding vacuum leaks with smoke (smoke test, tester) Reply with quote
To link to this post copy and paste
Code:
[url=http://www.thesamba.com/vw/forum/viewtopic.php?p=7568752#7568752]Finding vacuum leaks with smoke (smoke test, tester)[/url]
Hi all,
A quick write up for this forum, since I couldn't find it when I was searching earlier. I recently had some vacuum leak woes. I built a smoker to make it easier to find them. Based on this design over in the Vanagon forum: http://www.thesamba.com/vw/forum/viewtopic.php?p=5282178
Parts required:
- Quart paint can
- 1/8" barbed to NPT fitting
- Valve stem
- JB weld, epoxy, something gluey.
Instructions:
1) Drill two holes in the lid, one for the barbed fitting, one for the valve stem.
2) Insert barbed fitting, pot with epoxy or JB weld.
3) Install Valve stem
To use:
1) Hook up a pump to the valve stem (I used a manual bike pump).
2) Hook up a vacuum line from the barbed fitting to a place in the vacuum system.
3) Block S-boot with a beer bottle.
4) Light something on fire in the can. I used a scrap of t-shirt soaked in gas and oil, along with some cardboard.
5) Put the fire out, pop the lid on, start pumping the air pump and look for smoke.
Relevant pictures below:
GoBigEmma wrote:
That's a cool setup! We copied it to check for vacuum leaks, but we used smoke bombs that I used to make as a kid instead of cigarettes: Wrap a ping pong ball in aluminum foil (make sure to wrap it tight or it will burn, but not smoke) and hold a flame under one spot of it until it starts smoking. Produces a whole lot of smoke (like, A LOT), but breathing that stuff in definitely shortens your life by the smell of it, so be careful. Smile
1976 Transporter, Stock 2.0L
http://instagram.com/sixer.bus/
PITApan
PITApan is offline
PostPosted: Mon Feb 23, 2015 7:46 pm    Post subject: Reply with quote
I've always found starter fluid to be very sensitive but I hear unlit propane from your torch works well too. In a few situations I've found leaks with vaseline.
What's the advantage of building a smoker?
sixer
sixer is offline
PostPosted: Mon Feb 23, 2015 7:58 pm    Post subject: Reply with quote
I tried the propane torch trick, it didn't work very well for me. I wasn't a fan of spraying starter fluid on my freshly cleaned and painted engine, so I built the smoker. Worked really well so far for me, and for ~$10 I have a new tool for diagnosing. I'll probably add smoking the vacuum lines to my tune up list just because it's easy to do and keep the FI system happy.
PITApan
PITApan is offline
PostPosted: Mon Feb 23, 2015 8:08 pm    Post subject: Reply with quote
Gotcha.
For $4.00 I got a pack of camels and a rubber hose. Very Happy
SGKent Premium Member
SGKent is offline
PostPosted: Mon Feb 23, 2015 8:36 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=599295&highlight=smoke+cigar
Mal evolent
Mal evolent is offline
PostPosted: Tue Feb 24, 2015 6:52 am    Post subject: Reply with quote
I do the opposite. soap everything, pressurize the air intake to 2 PSI, watch the bubbles.
can't bring myself to fill the engine compartment with propane and generate sparks. downright Darwinian.
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
raygreenwood
raygreenwood is offline
PostPosted: Tue Feb 24, 2015 10:04 am    Post subject: Reply with quote
Smoke and propane are not capable of finding really small/fine vacuum leaks....especially the type that, open up larger with heat expansion and vibration.
Typically these are very thin leaks less than .001" in space ...on items like runner boots and flat intake runner seals etc.
These types of leaks are rarely large by themselves. Its usually several of them creating a cumulative leakage......which fuel injected systems are very sensitive too. Usually finding these types of leaks is the final stage in really fine tuning.
There is usually either not enough airflow through these leaks or not at the time and rpm you are testing.....which is why smoke and propane do not work In these cases.
However smoke and propane work well on cracked hoses, fittings etc.
Solvents like carb cleaner work well on the types of leaks that smoke does not work on because.....its thin enough to get into crevices and highly flammable. However its also hard on paint and coating.
If you have time a very thin machine oil in a dripped bottle for checking seals you suspect can work well. In some cases.....just soap water works well as others have noted.
You need to use soap to break the surface tension or the water so it gets into very narrow leaks. You can also use Jet-Dry for dishwashers. Mixed with water it makes a good leak checking liquid. Ray
SGKent is offline
PostPosted: Wed Sep 16, 2015 7:51 am    Post subject: Reply with quote
windex often will turn up a leak without stripping paint off.
Tcash
Tcash is offline
PostPosted: Wed Sep 16, 2015 9:34 am    Post subject: Reply with quote
This is a great way to do it. Because you are under positive pressure. Leaks that may close up under negative vacuum open up.
For when soap and water won't cut it.
Tire Leak Detectors SPC 35805
Good day
Tcash
meester_jamie
meester_jamie is offline
PostPosted: Tue Dec 08, 2015 8:48 am    Post subject: Re: Finding vacuum leaks with smoke (smoke test, tester) Reply with quote
situation,, engine won't start,, looked like crazy for a vac leak.. can't find it.. blow smoke thru into the intake... and see it coming out under the front wheel !! holy crow.. the vac hose is bust at the brake booster.
Idea I am thinking out loud.. but a bicycle tube , cut to appear to be a hose.. one end stretched over the S boot... and the other end on the smoke source.. lol.. I don't know if you can take a big TOKE on see gar,, and Huff it enough to make it fill the intake system enough to appear thru a leak... but I guess if the leak is right there,, and big enough.. it might just work.. otherwise a vacuum cleaner might add enough blow to make the smoke rise
Idea you tube has plenty of cheap home made cigar smoke machines to let you adapt ..
kkjellquist
kkjellquist is offline
PostPosted: Mon Mar 14, 2016 5:15 am    Post subject: Re: Finding vacuum leaks with smoke (smoke test, tester) Reply with quote
Just a bump for this helpful thread and a big thanks to OP. Built one of these and found 2 small leaks. Tool cost me about $10 to build and I fixed the leaks with $3 in hose clamps! My bus idles better now.
One tip for others, a 12V air mattress pump works perfectly and you can run it right off the battery of course. A completely portable vacuum leak tester Wink
1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/
busmania
busmania is offline
PostPosted: Tue Jun 28, 2016 7:19 am    Post subject: Re: Finding vacuum leaks with smoke (smoke test, tester) Reply with quote
I am about to build this handy contraption but had a few questions.
I assume you look for leaks with the engine OFF? Plug S boot and then introduce the smoke to ANY of the vacuum lines? The smoke will then leak out of wherever the leak is, correct?
Sometimes I have a hard time visualizing things. So thank you!
SGKent is offline
PostPosted: Tue Jun 28, 2016 7:24 am    Post subject: Re: Finding vacuum leaks with smoke (smoke test, tester) Reply with quote
engine off. You are looking where smoke escapes.
Tcash
Tcash is offline
PostPosted: Tue Jun 28, 2016 8:51 am    Post subject: Re: Finding vacuum leaks with smoke (smoke test, tester) Reply with quote
https://www.youtube.com/results?search_query=smoke+test+vacuum+leak
busmania
busmania is offline
PostPosted: Tue Jun 28, 2016 11:58 am    Post subject: Re: Finding vacuum leaks with smoke (smoke test, tester) Reply with quote
As a visual learner, this helps a ton. thank you.
Now when my wife is mad because I'm in the garage "smoking" cigarettes (I quit years ago), i'll point her to the home made red neck smoke machine video.
https://www.youtube.com/watch?v=rumgJ5UBpCw
Thanks again.
GoBigEmma
Location: Currently scattered between Mexico and Illinois
GoBigEmma is offline
PostPosted: Wed Jun 29, 2016 7:09 pm    Post subject: Re: Finding vacuum leaks with smoke (smoke test, tester) Reply with quote
1975 Bus "Big Emma", 1.8 FI, Hydraulic lifters
Interrupting our Pan-American Roadtrip for post-flood repairs: http://www.thesamba.com/vw/forum/viewtopic.php?t=657738
Follow the trip on our blog: http://www.gobigemma.com
ac78
ac78 is offline
PostPosted: Mon Aug 29, 2016 6:02 pm    Post subject: Re: Finding vacuum leaks with smoke (smoke test, tester) Reply with quote
I don't even remember why I'm looking at this thread, but Eureka! Smoke Bombs, Brilliant! I can get those year round in TN. You may not even need to add air pressure with those.Thank you GoBigEmma! I'll have to try it just because...
78 Westy 2.0l hydr. FI
VW Campmobile
For people who believe a family's
car should be it's castle !
Terminatez
Terminatez is offline
PostPosted: Tue Dec 12, 2017 9:03 pm    Post subject: Re: Finding vacuum leaks with smoke (smoke test, tester) Reply with quote
So, how would I do a vacuum test using a smoker when I have carbs?
I'm guessing I can blow the smoke through the hose used for vac to the booster?
What do I need to cap off, and how?
1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote:
I don't think I've ever seen an engine in worse shape.
timvw7476
timvw7476 is offline
PostPosted: Wed Dec 13, 2017 12:48 am    Post subject: Re: Finding vacuum leaks with smoke (smoke test, tester) Reply with quote
Nitrile or latex work gloves work well as blockers on carb intakes,
they tend to snap right over modern throttle bodies but you can tear a palm
shaped piece out of one & use a rubber band or air filter clamp/zip tie
to seal carb throat. If you are running an open breather set up, plug that as well. Booster line is where I usually stuff the smoke.
aeromech
aeromech is offline
PostPosted: Wed Dec 13, 2017 12:48 pm    Post subject: Re: Finding vacuum leaks with smoke (smoke test, tester) Reply with quote
Cap the exhaust pipe too. Remember, when you find the first leak plug it anyway you can and keep going, finding and plugging, until you find ALL the leaks. Don't forget to check around your exhaust system too
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
