Spark Plugs burning ok?
teamasr
teamasr is offline
PostPosted: Sun Jul 17, 2016 10:05 pm    Post subject: Spark Plugs burning ok? Reply with quote
What do you guys think of this burn on the plugs? 2017 on dual webers.
Two richer ones are from right side, two leaner ones are on left side. Thinking right side should be leaned out a bit.
Getting pops under acceleration after about 20 min of continuous drive.
jfats808
jfats808 is offline
PostPosted: Sun Jul 17, 2016 10:10 pm    Post subject: Re: Spark Plugs burning ok? Reply with quote
Slightly warm. Id try a Colder plug.
2276 IDA's 86C 11-1 DD
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
Danwvw
Danwvw is offline
Probably it's the lean side that's causing the pops! Mine at 15000 miles: #3 Spark Plug
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
teamasr
teamasr is offline
PostPosted: Mon Jul 18, 2016 9:01 am    Post subject: Re: Spark Plugs burning ok? Reply with quote
Jfats why do you think a colder plug? NGK B5ES are in there now.
Black carbon around base of plug look good?
[email protected]
john@aircooled.net is offline
PostPosted: Mon Jul 18, 2016 9:53 am    Post subject: Re: Spark Plugs burning ok? Reply with quote
I agree, try a NGK "6".
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
jfats808
jfats808 is offline
PostPosted: Mon Jul 18, 2016 9:55 am    Post subject: Re: Spark Plugs burning ok? Reply with quote
The prong strap itself shows how hot (or cold) your plug is by the heat transfer mark on the strap. From the firing end to abouts halfway is considered with in heat range. Too close to the tip is cold, too warm is close to the strap base.
I used to have a saved page on my phone with sites on reading plugs and t -mobile did some upgrade and I can't find it now.
teamasr
teamasr is offline
PostPosted: Mon Jul 18, 2016 11:02 am    Post subject: Re: Spark Plugs burning ok? Reply with quote
Gotcha both...thanks.
Should I do any leaning or fattening on either side giving the difference in color, or just put plugs in and try again before I touch anything else?
[email protected]
PostPosted: Mon Jul 18, 2016 11:50 am    Post subject: Re: Spark Plugs burning ok? Reply with quote
do plugs first.
Trying to read plugs with unleaded fuel is mostly a waste of time. Plugs don't color well with unleaded.
mark tucker
mark tucker is offline
PostPosted: Mon Jul 18, 2016 2:05 pm    Post subject: Re: Spark Plugs burning ok? Reply with quote
I agree wong plug range. pop's are usualy leen condition. check float level's and carb sync.
teamasr
teamasr is offline
PostPosted: Mon Jul 18, 2016 3:22 pm    Post subject: Re: Spark Plugs burning ok? Reply with quote
The owner of my local Napa suggested the B6HS as the old plug seem to be sticking several threads into the cylinder. Thoughts?
gt1953
gt1953 is offline
PostPosted: Mon Jul 18, 2016 3:37 pm    Post subject: Re: Spark Plugs burning ok? Reply with quote
Oh my what an issue you are in now. do you know anything about the heads? You sure don't want to have the plug hitting the cylinder top.
My opinion on the plugs is they are really close to the correct range. With no lead in the fuel anymore the plugs stay clean.
72 type 1
72 Squareback
teamasr
teamasr is offline
PostPosted: Mon Jul 18, 2016 4:07 pm    Post subject: Re: Spark Plugs burning ok? Reply with quote
The old plugs is what came in the motor from Chico Performance. They seem to clear the piston, but you can see several of the threads appearing to be sticking out into the head with the darker build up.
I can either go back to the same long ones one step colder or use these shorter ones.
[email protected]
PostPosted: Mon Jul 18, 2016 4:11 pm    Post subject: Re: Spark Plugs burning ok? Reply with quote
make sure the plugs match the heads.
Also, do not under ANY circumstances, use never-seize. I see some on your plug threads, that is not good in my experience.
mark tucker
PostPosted: Mon Jul 18, 2016 5:35 pm    Post subject: Re: Spark Plugs burning ok? Reply with quote
ditto x4
mcmscott
mcmscott is offline
PostPosted: Mon Jul 18, 2016 5:56 pm    Post subject: Re: Spark Plugs burning ok? Reply with quote
I have used "anti" seize on all alluminum heads since 1984 with zero problems, the only times I have seen problems is when plugs were installed dry. Just currious as why you say not to use it?
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
teamasr
teamasr is offline
PostPosted: Mon Jul 18, 2016 6:21 pm    Post subject: Re: Spark Plugs burning ok? Reply with quote
How can I check if they match the head? I am looking at the old plug and see that at least 3 of the threads have black carbon on them, so assuming they are protruding out. If installed put those plugs in, should I assume they are right, or go shorter?
fes
fes is offline
PostPosted: Mon Jul 18, 2016 6:57 pm    Post subject: Re: Spark Plugs burning ok? Reply with quote
I think the easiest way to see if your heads are for long reach plugs is to take a piece of wire and bend it like a hook, mark with a marker at the top of the plug hole and compare it with the plug itself.
'68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now)
[email protected]
PostPosted: Mon Jul 18, 2016 7:43 pm    Post subject: Re: Spark Plugs burning ok? Reply with quote
I can't even count how many times I've seen mysterious misfires cleared up when it was removed. At least over 100x.
HRVW
HRVW is offline
PostPosted: Mon Jul 18, 2016 8:45 pm    Post subject: Re: Spark Plugs burning ok? Reply with quote
Idea NGK BP6HS or BP7HS (latter in my Turbo bug)
mark tucker
PostPosted: Tue Jul 19, 2016 11:09 am    Post subject: Re: Spark Plugs burning ok? Reply with quote
I would put bosche platinums in it.
