Kommercial Samba Moderator
Joined: December 28, 2000 Posts: 1195 Location: San Tan Valley, Arizona
Posted: Thu Dec 20, 2012 6:21 pm Post subject: Oil cooler seal identification / which one do I need? Help! |
Ok Just enjoyed a nice oil waterfall on my new motor, once the pressure built up
So let's dicuss oil cooler seals/coolers. Who can identify what goes to what, and maybe Glen will throw this in the FAQ.
Still trying to figure out why mine blow out, please see newest post below
This is the info someone PM'd me- Anyone else?
From left to right
-Tapered flanged is a replacement seal with small 8mm on one side and large 10mm on the other for use when you have a mismatch such as large 10mm passage oil cooler fitted on a small 8mm passage case or a small passage oil cooler fitted on a large oil passage case.
-Thin flanged fit all large 10mm oil passage type 1 cases and large 10mm oil passage coolers including the dog house style. so in theory 70 and newer..
-Thick flanged fit early type 3 small 8mm oil passage. I'm not sure of the year interchange on these. (is this also doghouse only??, what about non doghouse cooler on a type3 case?)
-Tube style, small 8mm diameter, fits all type 1 stock small 8mm oil passage cases and small 8mm oil passage oil coolers. So in theory 69 and older..
Where do the spacers go, seems to be differing opinions on this
Large 10mm diameter oil passage
Small 8mm diameter oil passage
All doghouse coolers are large 10mm diameter passage so you either need the flanged large diameter seal, or the flanged large 10mm to small 8mm tapered seal, depending on the passage size of your case.
2 sets of seals for the 10mm doghouse setup
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20838 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Dec 20, 2012 9:18 pm Post subject: |
I always used the ones that matched the inside diameter of the oil passages in case....
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Sat Dec 22, 2012 11:19 am Post subject: |
I'm running a type 3 case (looks just like my type 1 cases?) with small oil passage and a type 1 oil cooler. Would the seals used be any different then a type 1 oil cooler on a type 1 case? These orange tube type seals didn't hold. I put them on dry, would that effect it?
So I was told to use the thick flanged orange ones. But when I tighten the thick flange seals down they squish out the sides. Do I need spacers? Different seals? or?
Posted: Sat Dec 22, 2012 11:42 am Post subject: |
Found this that basically says use spacers only when going from 8 to 10, non doghouse only. But I am going 8 to 8 non doghouse which is not shown....
Cusser Samba Member
Joined: October 02, 2006 Posts: 33200 Location: Hot Arizona
Posted: Sat Dec 22, 2012 2:39 pm Post subject: |
Kommercial wrote: |
Well, I haven't had a leaky cooler on my two in a zillion years (I now use this http://bugpack.com/index.php?main_page=product_info&cPath=2&products_id=99 on my 1835 with external oil cooler)
Any O-ring, seal, etc., has to squish to make a good seal. But oversquishing/tightening is just as bad. You have to have the oil cooler tighten, and even. I've done these on all sorts of engines decades ago, and I always felt more comfortable with seals with flanges. After looking at the photos, I think the orange ones with the flanges would be best for you, and they must squish some. You need to look and see if spacers would help keep this level/even when you tighten. You can re-use the new ones you just tried and got shaky with because the squished, they're not 20 years old and heat-set !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sun Dec 23, 2012 12:46 pm Post subject: |
Just removed and stripped the motor and lightly greased the tube type oil seals and put it back in. (put them in dry last time). Niagra falls again! What am I missing here? The seals stuck up about a 1/16-1/8" out of the case just like the other motor I just tore down that didn't leak. The oil cooler is a stock 1600. I looked at some other oil coolers I have and the pressings in the bottom of the cooler were sharper as opposed to the one I'm using but other then that I don't see a difference. I can feel the seals touching before I torque it down. Anyone?
If I use a flange type seal, the oil cooler would never touch the case in this instance and then how would I be able to properly torque or maintain torque?? As I said I tried them but they were distorted and gushed out the sides of the oil cooler when tight, definetly not right.
Will an issue with the relief valve cause the seals to "blow" by just turning it over?? It hasn't even started yet. |
Posted: Mon Dec 24, 2012 2:52 pm Post subject: |
Motor stripped again ready for plan Z. Any ideas? I blew through the cooler (as well as solvent soaked it for days before) so being plugged is not the issue..... blew through the case passages as well. Found some taller non flanged seals in an old motor. Still plyable, guess I'll try those... |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Mon Dec 24, 2012 4:35 pm Post subject: |
Okay my pesos worth....drop them and a magnet will pick them up.
When doing engines in Calif The small black seals were for the early 36/40hp engines.
The THICK T3 seals were for the T3 case and T3 oil cooler and adding the copper washer to the two bolts and top stud......NO leaks.
Then there was the early cooler to the later case needing the GREEN step seal as I called them.....went up or down as the need arose....did work.
The later case and newer oil cooler used the orange/red color seal that fit either way and I would use the copper washer to keep from Squishing the seal (learned that the hard way).
The case hole did not matter as to size as long as the seal dropped in snug w/o moving around.....use the three copper washers and it was a GO.
The seals should NEVER be Squished as the evidence shows the results.
(VW mechanic/engine builder/parts house owner of 28yrs) |
Scorcho Samba Member
Joined: May 04, 2012 Posts: 396 Location: Chicago, IL
Posted: Sun Jul 31, 2016 9:17 pm Post subject: Re: Oil cooler seal identification / which one do I need? Help! |
Trying to see if my oil cooler is leaking because I over tightened it (most likely) or because I used the wrong ones.
What's lead me to believe that I used the right seals is that they didn't leak at all until I drove it on a hot day for about 4 hours. No leaks before that.
Some pictures I took while installing the oil cooler originally. Wish I would have taken one of the case but that should come soon |
Brian Samba Moderator
Posted: Sun Jul 31, 2016 9:33 pm Post subject: Re: Oil cooler seal identification / which one do I need? Help! |
Do you have a caliper? My eyecrometer says it's about 9mm. You need to make sure you have the proper seals on your case. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Mon Aug 01, 2016 6:56 pm Post subject: Re: Oil cooler seal identification / which one do I need? Help! |
So in essence we are measure the diameter of the holes in the oil cooler the holes in the case and putting the seal that matches it on either side correct?
Like if my holes in case measure 8 and the holes in my oil cooler have a diameter of 10 I would put a seal that matches with those diameters? |
Posted: Mon Aug 01, 2016 7:43 pm Post subject: Re: Oil cooler seal identification / which one do I need? Help! |
Where exactly do the washers go. I am putting the seals that go from 8mm(engine case) to 10mm(non doghouse oil cooler) wondering if I should put spacers based on the diagram above but not sure exactly where they go |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Mon Aug 01, 2016 7:50 pm Post subject: Re: Oil cooler seal identification / which one do I need? Help! |
Scorcho wrote: |
You are doing the top left diagram from above, no spacers, if the tab on the cooler is bent, straighten it first, then snug it down evenly _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Posted: Mon Aug 01, 2016 7:54 pm Post subject: Re: Oil cooler seal identification / which one do I need? Help! |
Ok awesome didn't notice the little logos on the diagram to indicate what cars!! Now it makes complete sense thanks a lot! |
onehappykombi Samba Member
Posted: Fri Jun 03, 2022 12:48 pm Post subject: Re: Oil cooler seal identification / which one do I need? Help! |
Very helpful information, thank you
I think my issue is not covered here:
My bus has what I believe to be a Type 3 case due to engine number starting with U0.
I don’t know what the “D” o the “15” mean on the engine part number.
The oil cooler passages are mismatched, one is 8mm and the other is 10mm.
The previous owner had installed 8mm seals on both holes.
Is it ok to run this case in a Bus or should I just get one with both 10mm and 10mm?
If I use this case, should I use one 10mm seal and one 8mm seal?
Thank you!! _________________ '56 Early Split & '69 Early Bay
Overlanding the USA
Camper special engine build |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7511 Location: Houston, Texas
txoval Samba Member
Joined: January 23, 2004 Posts: 3849 Location: The Woodlands, TX
Posted: Fri Jun 03, 2022 4:18 pm Post subject: Re: Oil cooler seal identification / which one do I need? Help! |
The green are to transition from 10mm to 8mm ports.
Example: 36hp case with aftermarket cooler |
Posted: Fri Jun 03, 2022 4:24 pm Post subject: Re: Oil cooler seal identification / which one do I need? Help! |
In my case I have different size holes
Would it be ok to put an 8 to 10 mm in the small hole and a 10 to 10mm in the big hole? Not sure if widths are the same _________________ '56 Early Split & '69 Early Bay
Overlanding the USA
volksworld Samba Member
Joined: November 26, 2011 Posts: 2580 Location: formerly NY currently NC
Posted: Fri Jun 03, 2022 6:40 pm Post subject: Re: Oil cooler seal identification / which one do I need? Help! |
think we have an optical illusion here...yes obviously the hole for the 2 oil passages are different sizes...but it looks to me that the shoulders for the holes where the cooler seals fit are the same size...you need to measure them to verify that...if they are the same you do not need 2 different seals...if you are using the offset adapter for a doghouse cooler you just need the normal red seals...verify that the block hole shoulder is the same diameter as the second step in the cooler adapter...you havent shown enough of the engine but i do not believe you have a type III block...the casting number you show on the side is 211 (bus)...the font of that engine # does not appear to be original VW...it was probably stamped on there by a rebuilder...type III engine numbers arent even in that location as they would be hidden by the fan housing...they are stamped onto the TOP of the block parallel to the case seam near the fuel pump
Posted: Fri Jun 03, 2022 6:41 pm Post subject: Re: Oil cooler seal identification / which one do I need? Help! |
volksworld wrote: |
think we have an optical illusion here...yes obviously the hole for the 2 oil passages are different sizes...but it looks to me that the shoulders for the holes where the cooler seals fit are the same size...you need to measure them to verify that...if they are the same you do not need 2 different seals...if you are using the offset adapter for a doghouse cooler you just need the normal red seals...i |
I measured and they’re different _________________ '56 Early Split & '69 Early Bay
Overlanding the USA
