"Lowered" front shocks...how to remove the lower metal bushing?
misfitnick
misfitnick is offline
PostPosted: Sun Aug 07, 2016 11:27 am    Post subject: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
I recently bought a pair of these shocks...
https://www.jbugs.com/product/9650.html
...to go onto the front end of my 1956 beetle, but they won't fit because of the metal bushing that is installed in the lower end of the shock. This bushing is too small to fit over the shock mount on my lower trailing arms. I have tried to press this bushing out using my arbor press with no luck, it might as well be welded in! So, is there any easy way to get that shock bushing out? Are there any other mods I will need to do in order to mount these shocks? Thanks for the help, gents!
Bruce
Bruce is offline
PostPosted: Sun Aug 07, 2016 12:41 pm    Post subject: Re: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
Don't try to remove the steel collar from the bottom of the shock. Instead, remove the steel collar from the old shock that stuck onto the stud of the control arm.
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Sun Aug 07, 2016 3:39 pm    Post subject: Re: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
here's one way to remove it
Also a chisel and hammer. Sometimes you can find the seam and open it up.
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
williamM
williamM is offline
PostPosted: Sun Aug 07, 2016 4:48 pm    Post subject: Re: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
X2- If confronted we would use an air chisel to run it off the stud- otherwise it stayed No Harm.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
57BLITZ
57BLITZ is offline
PostPosted: Sun Aug 07, 2016 10:24 pm    Post subject: Re: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
misfitnick wrote:
. . . bushing is too small to fit over the shock mount on my lower trailing arms. I have tried to press this bushing out using my arbor press with no luck, it might as well be welded in!
DO NOT press that out of the new shocks!! You will not be able to press the new shock on to the trailing arm.
Like the other folks told ya . . . the old shock left a piece on the trailing arm and ya gotta get it off before you can install the new shocks!
Jesucristo es mi Señor y Salvador!
PostPosted: Sun Aug 07, 2016 11:28 pm    Post subject: Re: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
Why did this remind me of this?
Very Happy
Anyway. sometimes you have to heat up the piece that is left in place or slice it with a dremel
txoval
txoval is offline
PostPosted: Mon Aug 08, 2016 11:19 am    Post subject: Re: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
Yep, usually heat and vise-grips will do the trick...twist it back and forth as it slides off
Snort
Snort is offline
PostPosted: Mon Aug 08, 2016 1:05 pm    Post subject: Re: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
If you have an arc welder, run a short bead of weld on it. That will heat it up and give your pipe wrench or vice grips something to grip when you twist it.
misfitnick
PostPosted: Mon Aug 08, 2016 6:20 pm    Post subject: Re: Reply with quote
Thanks Guys!! I honestly didn't realize that the original shock bushings remained on the lower trailing arms (I thought for some reason that the bushing sleeves were an integral part of the trailing arm that the rubber shock bushing might slide over...). After heating them up with a propane torch and hitting them with my air hammer, they popped right off. Thanks again for everybody that replied to my inquiry, I am in your debt.
tisius
tisius is offline
PostPosted: Fri Aug 19, 2016 12:35 am    Post subject: Re: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
yes those old shock bushings can be a pain in the...like some other stuff you come across on an old VW Crying or Very sad
Glad you managed to get it off. Mounting new shocks will make a huge improvement to handling.
drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
ZENAK
ZENAK is offline
PostPosted: Mon Apr 27, 2020 10:39 pm    Post subject: Re: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
To revive an old thread for clarification....
The bottom sleeve is from the old shock and should be removed?
I know obvious question. I just wanna make sure befor I break something.
Thank you.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Mon Apr 27, 2020 10:46 pm    Post subject: Re: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
Picture please. Since you are asking, let’s be sure you get the correct answer!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
ZENAK
ZENAK is offline
PostPosted: Tue Apr 28, 2020 9:59 pm    Post subject: Re: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
On closer inspection. I have realized I’m an idiot. After heat and lots of it, I was able to remove the old shock sleeve.
Note to all. Search and READ.
Sorry 😑
joebsa
joebsa is offline
PostPosted: Tue Jul 28, 2020 9:36 am    Post subject: Re: "Lowered" front shocks...how to remove the lower metal bushing? Reply with quote
I successfully removed the lower sleeve from my new shock and destroyed the rubber bushing. Had to order a new shock. My bad. If I had measured the OD of the the new shock sleeve and then measured the OD of the stud at first, I would have realized that the sleeve was still rusted onto the stud. I remember weeks ago removing the shocks and noticing that there were no sleeves in the bushings at the bottom, shrugged my shoulders and proceeded to throw them in the trash. I looked at the lower arm stud and thought that it was part of the stud due to how clean it looked. After heating it up with MAPP gas and putting a pipe wrench on it, off it came. $25 mistake, wasted time, but I will never forget what I learned and hung up that damaged new shock on my wall of shame.
