transmission input shaft question
dennismafo
dennismafo is offline
PostPosted: Tue Aug 23, 2016 8:59 am    Post subject: transmission input shaft question Reply with quote
1975 bay window
I have pulled the upright engine that the last owner put in
poorly i might add
and i am installing a new 2.0L
i have a question about the input shaft
anyone know what it should measure?
is there anyway he could have put that upright in and not replaced the shaft?
I see you can cut them down 11mm to get it in but this one does not look cut
if i need one any leads on where to find one?
he had it hanging off the transmission with 3 bolts no support bar no tin
thanks
SGKent Premium Member
SGKent is offline
PostPosted: Tue Aug 23, 2016 9:41 am    Post subject: Re: transmission input shaft question Reply with quote
weddle has them
George Carlin:
Skills@EuroCarsPlus:
Tcash
Tcash is offline
PostPosted: Tue Aug 23, 2016 10:18 am    Post subject: Transmission input shaft length Reply with quote
To link to this post copy and paste.
Code:
[url=http://www.thesamba.com/vw/forum/viewtopic.php?p=8187129#8187129]Transmission input shaft length[/url]
Type I 002 input shaft protrusion from face of bell housing
aeromech wrote:
mranker wrote:
OK engine out and the input shaft clears the mating surface of the transaxle by 9/16".
I called Eric over at Transworks this morning. He measured an input shaft and came up with the same length you have, 9/16. Looks like you are ok with the one you have.
Wildthings wrote:
A quick check in the bone yard shows that the Type 4 shaft sticks out about 1" from the bellhousing while the Type 1 shaft sticks out about 9/16, so there is about a 7/16" difference in length.
kreemoweet wrote:
That input shaft looks a little long. The later (72-on in the U.S), longer shaft sometimes works OK on earlier engines ... and sometimes not. Forcing
the engine and trans to mate with the mounting bolts/nuts is just begging for unnecessary damage.
aeromech
aeromech is offline
PostPosted: Tue Aug 23, 2016 10:54 am    Post subject: Re: transmission input shaft question Reply with quote
Even if yours is cut I'm not sure it would matter. Maybe someone else knows
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent is offline
PostPosted: Tue Aug 23, 2016 11:24 am    Post subject: Re: transmission input shaft question Reply with quote
I BELIEVE that it has to do with the depth of the pilot bearing. On a T4 engine the pilot bearing is in the crankshaft - that puts it deeper than the flywheel. On a T1 motor the pilot shaft sits farther out in the flywheel gland nut.
I would thing the easiest way to tell is hold a line between the edges of the bell housing and see how far out the nose of the input shaft sits. Then measure the depth of the pilot bearing from the surface of the engine case with the flywheel off.
There is also a ring that goes in the flywheel and a felt washer between it and the pilot bearing to keep in grease and dirt out. Those are built into the gland nut on a T1 engine.
George Carlin:
sodbuster
sodbuster is offline
PostPosted: Tue Aug 23, 2016 11:41 am    Post subject: Re: transmission input shaft question Reply with quote
If I am reading this right the input shaft you have now is to accommodate the installation of a type 1 engine in your '73 bus. And now you are going get rid of that engine and return to a type 4 engine like it is supposed to have.
If this is the case you need to replace the input shaft back to the longer style input shaft that came on the '73 transaxle originally. If the input shaft you have now was cut down or replaced with the shorter version for the type 1 powered buses (68 to 71) it matters not. It is still too short to be supported correctly if at all by the pilot bearing in the end of the type 4 engines crankshaft, and will have bad effects on the operation of the clutch.
No shortcuts or tricks in this case. Just strait out replace it with the right part. Smile
busdaddy
busdaddy is offline
PostPosted: Tue Aug 23, 2016 11:48 am    Post subject: Re: transmission input shaft question Reply with quote
I have seen pilot bearings pressed directly into the flywheel when a type 4 is used in a Beetle, it's nothing that comes off the shelf though, requires a skilled machinist to fabricate and install.
Easier to measure yours and replace it if it's short.
Слава Україні!
Wildthings
Wildthings is offline
PostPosted: Tue Aug 23, 2016 12:02 pm    Post subject: Re: transmission input shaft question Reply with quote
On a Bus Type 4 engine and tranny the pilot bearing runs out near the end of the pilot shaft. If the shaft is for a Type 1 engine it will be too short to run with with the Bus Type 4 engine. You will either need to get a longer pilot shaft or have the flywheel machined to accept the pilot bearing as per some other uses of these engines. Not sure that that is a good idea if you have a cast flywheel though as you would not be leaving a lot of meat around the bolt holes.
dennismafo
PostPosted: Tue Aug 23, 2016 12:16 pm    Post subject: Re: transmission input shaft question Reply with quote
ok i will measure it tomorrow thanks for all the great info
Here is a couple before after shots of my bus
enjoy
dennismafo
PostPosted: Tue Aug 23, 2016 12:18 pm    Post subject: Re: transmission input shaft question Reply with quote
on a side note any info on installing the new one if we have to replace it?
also any other other seals parts etc for swapping this out?
thanks a lot guys its been years since i sold my last 3 vw bus's
and i am a bit rusty
I am gonna guess i have to open the trans up...
SGKent is offline
PostPosted: Tue Aug 23, 2016 12:59 pm    Post subject: Re: transmission input shaft question Reply with quote
it is a simple task after you get the correct input shaft. You will also want to look at the bell housing to be sure it is the correct one for the flywheel you are installing with the 2L. You may have the wrong Bell housing for a 2L. Weddle has those too. Photos of the flywheel side of the engine and the transmission would be helpful.
George Carlin:
dennismafo
PostPosted: Tue Aug 23, 2016 1:33 pm    Post subject: Re: transmission input shaft question Reply with quote
ok great
I will get pictures tomorrow the bus is sitting a hour away from me
I have a diesel tech helping me finish this off
but he is not a VW guy he will get it running if i can figure out the rest
thanks for that hook up on the part i found the shaft i will go find the housing now
i assume i can just swap out the housing as well
the trans runs great don't want to replace it just yet
Tcash
Tcash is offline
PostPosted: Tue Aug 23, 2016 3:22 pm    Post subject: Re: transmission input shaft question Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?p=7987475#7987475
dennismafo
PostPosted: Tue Aug 23, 2016 4:48 pm    Post subject: Re: transmission input shaft question Reply with quote
oh man thanks!! this looks like a breeze
think i am ready to tackle this
thanks everyone for the help
and wish me luck lol
Wildthings
PostPosted: Tue Aug 23, 2016 6:08 pm    Post subject: Re: transmission input shaft question Reply with quote
I replace the tranny input shaft seal pretty much whenever I have access to it. You should also check that the oil slinger is still fitting tight.
dennismafo
PostPosted: Wed Aug 24, 2016 10:23 am    Post subject: Re: transmission input shaft question Reply with quote
This is what i am working with
any thoughts does it look like this will work the shaft is out past the bell housing..
SGKent is offline
PostPosted: Wed Aug 24, 2016 10:30 am    Post subject: Re: transmission input shaft question Reply with quote
my instinct is that is an early 002 transmission and if so it won't play well with a 2L.
The flywheel on your 2L needs cleaning or surfacing depending on how deep the rust is.
Below is an 091 transmission which was used on the 2L motors. If you count the ribs there are 6. You will also notice two ears at the top of the bell housing closest to you in the photo. See if how many ribs your transmission has and check to see if it has ears on it.
George Carlin:
Wildthings
PostPosted: Wed Aug 24, 2016 10:46 am    Post subject: Re: Transmission input shaft length Reply with quote
dennismafo
PostPosted: Wed Aug 24, 2016 11:44 am    Post subject: Re: transmission input shaft question Reply with quote
Here is the transmission
I have no clue if this is right for the 2L i have to go in it
SGKent is offline
PostPosted: Wed Aug 24, 2016 12:44 pm    Post subject: Re: transmission input shaft question Reply with quote
to me that looks like a 5 rib. Does the bell housing have the two ears on it at the top as mentioned?
George Carlin:
