1969 Karman Ghia Build (UK)
Page: Previous  1, 2, 3 ... , 9, 10, 11  Next
scotty timmerman
scotty timmerman is offline
PostPosted: Wed Mar 16, 2016 11:54 am    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
i had the same problem when i installed the traction bar. i was able to trim the plastic fan shroud on the oil cooler enough to squeeze it in. also my oil thermostatic bi-pass valve goes on the oil filter mount.
71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
84 vanagon westfalia wolfsburg edition
carl4x4
carl4x4 is offline
PostPosted: Wed Mar 16, 2016 1:56 pm    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
I like the idea of the bi-pass going on the oil cooler mount thanks
1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight=
carl4x4
carl4x4 is offline
PostPosted: Thu Mar 17, 2016 9:07 am    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
Just like to state that two of the most annoying things about refitting an ACVW engine is re-threading the accelerator cable (by feel rather than by sight) and a replacement starter motor that doesn't have the little notch on top, to stop the 'D" shaped bolt from endlessly spinning! Twisted Evil
mcvick
mcvick is offline
PostPosted: Sat Apr 09, 2016 4:32 pm    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
A very valuable, well done documentary of a sharp ride
carl4x4
carl4x4 is offline
PostPosted: Tue Apr 26, 2016 1:52 pm    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
Cr@p Spring washer broke on 3,4 luckily it stayed in the rocker cover. Should replace with solid shaft in the long term but the standard ones will go back on for now
c21darrel
c21darrel is offline
PostPosted: Tue Apr 26, 2016 1:58 pm    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
Yes, stock ones fall apart with anything more than a stock motor. Keep an eye on them.
GhiaBuild
1967 DC build
carl4x4
carl4x4 is offline
PostPosted: Wed Apr 27, 2016 2:30 pm    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
Rebuilt the rocker assembly with a new spring washer, then stumbled onto the next problem. When I took the rocker cover off, all but one of rockers were closed completely. I tried to open the gaps but the adjusters wouldn't move enough. On closer examination there were some pedestal shims in place but not it seems the right amount. I added another 0.015" and the adjusters now gap up to 0.006" nicely.
It seems there's still plenty for me to learn new things about ACVW every time I tinker with mine Smile
Who knows, if the rockers didn't have any clearances then the valves may not have been sealing fully when closed at higher revs. It'll be interesting to see if this makes a difference now.
carl4x4
carl4x4 is offline
PostPosted: Thu May 19, 2016 3:30 am    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
In a true case of "a little knowledge his a dangerous thing" it turns out that I have chromoly pushrods (steel) which need to be adjusted to 0" free when cold (no gap but pushrods can still spin). Add this to a dodgy starter motor causing an interesting noise that needed hunting down, plus some impromptu open-tunnel surgery to re-weld the front and mid clutch tube welds Crying or Very sad and it's been an interesting few weeks.
Finally all tucked up and back on the road
Mellow Yellow 74
Mellow Yellow 74 is offline
PostPosted: Thu May 19, 2016 5:15 am    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
Did you butt weld those windows in the tunnel closed again? If not you have taken a fair bit of strength out of the chassis in the event of a serious crash.
1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon)
carl4x4
carl4x4 is offline
PostPosted: Thu May 19, 2016 10:41 am    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
Yes they've both been welded up again !
carl4x4
carl4x4 is offline
PostPosted: Thu Sep 01, 2016 5:00 am    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
Just a quick update, in a short while the Ghia will be going up for sale. Just need to do a couple of odd-jobs like replace a tempremental relay and adjust the steering stops on the rack before advertising it.
It's been a blast and I've enjoyed Ghia ownership greatly but it's time for a new challenge - not straying too far as I've started the hunt for Porsche 914 Smile which I can use to compete in Autocross so I will still be hanging around TheSamba Smile The hardest part will be coming up with a price for my Ghia !
carl4x4
carl4x4 is offline
PostPosted: Sun Sep 04, 2016 2:47 pm    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
Poppet is now up for sale in the Samba classifieds: http://www.thesamba.com/vw/classifieds/detail.php?id=1967377
mcdonaldneal
mcdonaldneal is offline
PostPosted: Sun Sep 04, 2016 11:41 pm    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
This is a great car, and in th UK the price is a bargain!
Good Luck!
1978 marino yellow Bay Dormobile camper
1969 signal orange Karmann Ghia convertible
1976 martini olive Bay Dormobile camper
Stop dead photo links! Post photos to The Samba Gallery!
John Moxon Premium Member
John Moxon is offline
PostPosted: Mon Sep 05, 2016 12:04 am    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
Yes...the price looks all the better for the weak value of the GBP against other foreign currencies...more will be looking for a UK Ghia.
Good luck Carl. Smile
John.
sputnick60
sputnick60 is offline
PostPosted: Mon Sep 05, 2016 12:30 am    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
Hmmm, below $29K Aussie plus freight & tax. A viable proposition indeed compared with other cars I've seen.
Good luck Carl.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
carl4x4
carl4x4 is offline
PostPosted: Mon Sep 05, 2016 1:29 am    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
Thanks guys, happy to assist in shipping to Australia / NZ / South Africa etc. if needed, interestingly a lot of the old UK sports cars have been making thier way over to Japan (also a Right hand drive market) in the last few years.
carl4x4
carl4x4 is offline
PostPosted: Thu Sep 15, 2016 1:44 am    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
Well it looks like I'm going to be around this forum for a while longer Smile the family have pursuaded me to keep the Ghia and put her into storage for a time Smile
sputnick60
PostPosted: Thu Sep 15, 2016 5:31 am    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
That's good news, I think? Very Happy
63 vwnotch
63 vwnotch is offline
PostPosted: Thu Sep 15, 2016 6:32 am    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
never been to Japan but I know a LOT of VW's have left the U.S. and gone over their, I think my beloved bus is their now....
excellent car you built there.... I hope someone in the U.S. snatched it Smile
LCDR O
LCDR O is offline
PostPosted: Fri Jun 29, 2018 7:25 pm    Post subject: Re: 1969 Karman Ghia Build (UK) Reply with quote
What's the colour paint code?
Page 10 of 11
