corythosaurus Samba Member
Posted: Wed Aug 31, 2016 6:38 am Post subject: Cory's 72 Squareback |
Long time lurker finally taking the plunge to start my own thread. I own a 1965 Karmann Ghia (long-time project car) and recently purchased this 1972 Squareback from a neighbor who purchased it off a farm in Colorado for $100.
Virtually no history on the vehicle it seems relatively in decent shape for sitting in a field for a couple decades. I know that it was originally a California car, but ended up in Colorado.
The plan is to get it running and stopping and comfortable to ride in. Definitely get all the mechanical/electrical working properly, which at first inspection, may not be too difficult. Give her some new shoes and adjust her stance a bit and then just enjoy the experience of cruising it around.
There is great knowledge on this site and I am impressed with the camaraderie and enthusiastic members. Hopefully you'll all assist on my Type 3 journey. _________________ '65 Karmann Ghia
'72 Squareback |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35919 Location: Conejo Valley, CA
Posted: Wed Aug 31, 2016 10:05 am Post subject: Re: Cory's 72 Squareback |
Great info, thanks. Had the car for about a month and a half and have already started most of what's included on that page. _________________ '65 Karmann Ghia
'72 Squareback |
KTPhil  Samba Member
Posted: Wed Aug 31, 2016 10:21 am Post subject: Re: Cory's 72 Squareback |
More photos, please!
Still FI? |
Posted: Thu Sep 01, 2016 7:45 pm Post subject: Re: Cory's 72 Squareback |
Here are a few more photos of when i pushed her from my neighbors side of the street to my side of the street.
'72 Squareback |
Posted: Thu Sep 01, 2016 7:46 pm Post subject: Re: Cory's 72 Squareback |
Here is what the power plant looked like.
'72 Squareback |
Posted: Fri Sep 02, 2016 6:01 am Post subject: Re: Cory's 72 Squareback |
I learned to drive with a ’72 Squareback. My parents had one when I was in high school and I was surprised by the sentimental connection when I actually sat in this one some 30+ years removed. The first car I bought was a ’63 Bug, then a ’72 Super Beetle, then a ’67 Ghia. Always had a deep affection for the air-cooled V-Dubs.
So, I’ve actually had this ’72 Square for a couple months now and have been able to get quite a bit done.
Drained and cleaned fuel tank
Replaced bad fuel lines
Removed EFI and replaced with dual carbs. Kept all the EFI parts; it may go back at some point, but in order to maintain a happy household this needs to run “now” as I already have a ’65 Ghia occupying garage space, and old school carburation was in my current wheelhouse.
New battery
Oil change and tranny check
Replaced rear brake cylinders
Replaced front and rear brake lines
New 4-1/2” stock rims w/Wolfsburg chrome caps
New 155/60R15 front shoes and 185/65R15s in the rear.
Checked all electrical, few gauge issues, but all lights are working. Need to replace the turn signal switch.
This is how she currently looks. She runs and stops well.
'72 Squareback |
Posted: Sat Sep 03, 2016 2:11 pm Post subject: Re: Cory's 72 Squareback |
Working on an old car always has it's challenges. I had to replace the turn signal switch so I figured I'd replace the cracked brittle ugly steering as well. The wiper switch on the opposite side worked fine. With new wheel turn switch in hand. a quick change was in order. as I went to remove the switches the wiper switch, brittle for decades of sitting, broke apart upon removal.
Not having one on hand (because it worked) I had to search for one. After finding a new one and getting it shipped, everything went back together like a charm.
As the journey continues I am nervous and curious about what lies ahead. _________________ '65 Karmann Ghia
'72 Squareback |
Posted: Sat Sep 03, 2016 2:17 pm Post subject: Re: Cory's 72 Squareback |
DOH!
'72 Squareback with '73 seats. Ugh, Shame on me for not paying closer attention.
'72 Squareback |
Posted: Sat Sep 03, 2016 2:39 pm Post subject: Re: Cory's 72 Squareback |
Went to adjust the stance on the front end yesterday and could not break the allen bolt free, any suggestions? _________________ '65 Karmann Ghia
'72 Squareback |
Posted: Mon Sep 05, 2016 10:21 am Post subject: Re: Cory's 72 Squareback |
Her new wheels.
'72 Squareback |
Posted: Wed Sep 07, 2016 6:50 pm Post subject: Re: Cory's 72 Squareback |
OK,
Need the experts. Anyone have a clue which visor i need to order to get the correct length?
'72 Squareback |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23394 Location: Kimball, Mi
Posted: Wed Sep 07, 2016 7:55 pm Post subject: Re: Cory's 72 Squareback |
corythosaurus wrote: |
OK,
Try adjusting it first. By that I mean pull the rods out of both ends unti you get it to fit. The hinge/pivot end should be the end to start with first. The sellers really need to include instructions with these things (you're not the first with this problem).
Do a search on lowering, as it's pretty common. You're mainly looking at removing the shock bottom, getting a 5" long M10x1.5 threaded bolt, and removing the short bolt and clip from the opposite side. You'll need to remove the bottom ball joint thru bolt (use a jack to take the tension off it so you don't strip it) first, then wedge a screw driver into the slot so the ball joint will slip out of it. Now remove the opposite side bolt and clip, insert the long bolt you bought and you can now index the other end by pulling out the arm, rotating it up 2 clicks or whatever you're lowering it to. Now slide the arm back in, and remove the long bolt,replacing it with the short 1. Now you can do the other side. Keep in mind that you'll have to reset the toe in, as it'll be off. I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Sep 08, 2016 5:10 am Post subject: Re: Cory's 72 Squareback |
Bobnotch wrote: |
Do a search on lowering, as it's pretty common. You're mainly looking at removing the shock bottom, getting a 5" long M10x1.5 threaded bolt, and removing the short bolt and clip from the opposite side. You'll need to remove the bottom ball joint thru bolt (use a jack to take the tension off it so you don't strip it) first, then wedge a screw driver into the slot so the ball joint will slip out of it. Now remove the opposite side bolt and clip, insert the long bolt you bought and you can now index the other end by pulling out the arm, rotating it up 2 clicks or whatever you're lowering it to. Now slide the arm back in, and remove the long bolt,replacing it with the short 1. Now you can do the other side. Keep in mind that you'll have to reset the toe in, as it'll be off. I hope this helps. |
Thanks so much Bob! _________________ '65 Karmann Ghia
'72 Squareback |
Posted: Fri Sep 09, 2016 5:35 pm Post subject: Re: Cory's 72 Squareback |
Had the Squareback running great. Nice and steady; then driving home from a quick trip to a store suddenly no sputtering, no hesitation, no missing, just off. She just stopped. Pulled over, checked a few things and called the car ambulance.
Took a few minutes this morning to check to see if I could figure out the issue. I verified it wasn't a fuel issue; I figure I would work my way from the coil to the plugs. Coil checked out fine. When I open the distributor, this is what I found.
The little plastic part which makes contact with the distributor rubbing block failed. Put an old set in I had, and boom! Back and running great. _________________ '65 Karmann Ghia
'72 Squareback |
bluebullseye Samba Member
Joined: November 30, 2009 Posts: 64 Location: Chantilly, VA
Posted: Sun Sep 11, 2016 5:06 pm Post subject: Re: Cory's 72 Squareback |
This is looking great! I have the motor to my '72 Square getting rebuilt right now, has fresh paint on from two months ago. Will hopefully be back on the road soon. Keep moving along with yours! _________________ -------------------------------------------------------
2018 VW Tiguan SE | Black with Golden Oak seats
1972 VW Type III Squareback | Kasan Red
Writer and Independent Publishing Consultant in the DC suburbs: www.johnhmatthews.com |
Posted: Sun Sep 18, 2016 1:25 pm Post subject: Re: Cory's 72 Squareback |
With the help of Bobnotch and a few threads on here, I was able to lower the front two inner splines and replace the 40+ year old shocks in about 90 minutes.
This is a proper front stance.
'72 Squareback |
FullFender Samba Member
Posted: Sun Sep 18, 2016 1:39 pm Post subject: Re: Cory's 72 Squareback |
Love it!!! Stance is perfect, looking forward to more updates!!! |
Posted: Sun Sep 18, 2016 9:17 pm Post subject: Re: Cory's 72 Squareback |
Looks good. Did you reset the toe in? If not, you need to get after it, or it'll eat the front tires off it.
I normally do it with a piece of 2by4, and mark where the centers of the tires are on the back side first, then move my board to the front and see which way I need to move the tie rods.
You could also just take it to an alignment shop, and have them re-set the toe. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
69 Notchback Samba Member
Joined: September 12, 2011 Posts: 714 Location: Bailey Co
Posted: Thu Sep 22, 2016 6:53 am Post subject: Re: Cory's 72 Squareback |
Looking good cory, can't wait to see it at the next show! |
