1972 super beetle tough time starting up/ takes long to get warm
Chrissteve22
Chrissteve22 is offline
PostPosted: Mon Nov 28, 2016 3:26 pm    Post subject: 1972 super beetle tough time starting up/ takes long to get warm Reply with quote
So I've been having this problem for a little while now and can't seem to fix it. Whenever I start my bug, it will start very slow and have a tough time getting warm and staying on so it will just stall out either right away or after a minute or 2. This gets worse when it is cold which is understandable but it will also happen when it is pretty warm too. I changed both fuel filters, a tune up is done, we adjusted the carb so it will run a little richer to try and get hot quicker but it doesn't help much at all. I am wondering if putting a thinner oil in would make a little difference like 5w-30. I'm running 10w-30 right now. But, I just can't figure out what the problem may be to get it running and stay idling when I first turn the car on. When the car is hot, it runs fine, but the problem is getting to that point.
hotsam
hotsam is offline
PostPosted: Mon Nov 28, 2016 4:02 pm    Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm Reply with quote
Check and see if you have a thermostat installed.
1968 Beetle
Chrissteve22
PostPosted: Mon Nov 28, 2016 4:04 pm    Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm Reply with quote
Where would that be located if I have one?
hotsam
hotsam is offline
PostPosted: Mon Nov 28, 2016 5:48 pm    Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm Reply with quote
Underneath, passenger's side.
1968 Beetle
hitest
hitest is offline
PostPosted: Mon Nov 28, 2016 8:24 pm    Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm Reply with quote
We can't make guesses until you tell us what carb you have and whether you have a working choke on it.
This so far gives me Weber Progressive goosebumps...
FU#5
andydlc
andydlc is offline
PostPosted: Tue Nov 29, 2016 2:55 pm    Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm Reply with quote
This could be a distributor issue, have you got points in the distributor or have you got an electronic Ignition ? Is your timing correct?
View user's profile Send private message Send e-mail MSN Messenger Classifieds Feedback
AngelDeVille
AngelDeVille is offline
PostPosted: Tue Nov 29, 2016 3:49 pm    Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm Reply with quote
Running rich/fouled plugs?
Sent via two tin cans connected by a string and a jailbroken Atari 2600...
Suck it up, Buttercup!
[email protected]
john@aircooled.net is offline
PostPosted: Tue Nov 29, 2016 5:17 pm    Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm Reply with quote
begin by posting a picture of your engine. We can often find issues just from that.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
