Driver seat- bottom cover installation question
Juan
Juan is offline
PostPosted: Sat Jan 07, 2017 4:07 pm    Post subject: Driver seat- bottom cover installation question Reply with quote
What is the proper way to attach the sides of the bottom seat cover to the bottom of the frame UNDER the seat rails?
Image below for reference of what specific part I'm referring to:
I ask 1. because I see the spikes under the rail but there doesn't seem to be space to do much with them due to the seat rails being there. And 2. because in mine (which I just removed) they were glued onto the seat frame piping when it came to the sides. And I'm pretty sure that's not right.
Pic below is of my seat. Like I said, I see the spikes under there, but would love some guidance as to how the covers are correctly installed under there without interfering with the seat rails.
If it makes any difference, it's a non-walkthrough bus.
Instagram: @juanskombi
1967 Velvet Green/Pearl White Kombi
1964 Pearl White Ghia Coupe
1969 BMW 2002
1959 Ford F100
busdaddy
busdaddy is offline
PostPosted: Sat Jan 07, 2017 4:19 pm    Post subject: Re: Driver seat- bottom cover installation question Reply with quote
The side spikes tap down over the bead formed by the wire, the wire tension does most of the work, the spikes keep it from getting caught in the slider and the tips trap the wire.
Слава Україні!
PostPosted: Sat Jan 07, 2017 4:42 pm    Post subject: Re: Driver seat- bottom cover installation question Reply with quote
Yes, it sort of just sits in the channel with tension from the wire and cover.
The spikes do not go through the material.
There is a thick piece of wire on each side though, poked through the cover so it goes around the wire inside the cover and through those pairs of holes you see in the frame.
Examples:
Wires - As far as I know there was one wire on each side even though there are 2 sets of holes. Both sides of an original seat are shown below.
Adjuster side, wire is coming undone here
Other side:
Seat cover sort of stuffed into the channel, you can see the wire used poking out a little here:
Juan
Juan is offline
PostPosted: Sat Jan 07, 2017 4:53 pm    Post subject: Re: Driver seat- bottom cover installation question Reply with quote
Thank you both for the responses.
I'm using WW/TMI replacement seat covers. Should I be looking for a wire inside the old seat covers? Or do the new seat covers come with something already sewn in?
Thanks again for the help!
1969 BMW 2002
1959 Ford F100
PostPosted: Sat Jan 07, 2017 5:02 pm    Post subject: Re: Driver seat- bottom cover installation question Reply with quote
New covers come with twine in the seat cover edge.
The twine is good for using as a pull string to run wire through the channel when you get it.
hitest
hitest is offline
PostPosted: Sat Jan 07, 2017 5:30 pm    Post subject: Re: Driver seat- bottom cover installation question Reply with quote
Occasionally the string will get sewn in place- and can't be used to pull a wire, so... Remember when you were a kid- and the knot on your hoodie's hood came loose? Feeding a wire through is kind of like that- you pinch and pull it through inch by inch if you don't have a pull string. I always bend the end of the 16 g wire over in a tight loop before pulling it through- to prevent snagging. It goes pretty smoothly.
FU#5
BarryL Premium Member
BarryL is offline
PostPosted: Sat Jan 07, 2017 7:29 pm    Post subject: Re: Driver seat- bottom cover installation question Reply with quote
Examples:
My originals had wire through both sets on both sides. Looking from underneath is a shot of a redone one and how to get it tight by twisting.
Showing both wires twists on one side.
You make a tight long U shape wire and poke it from the outside in over the seat perimeter tightening wire.
PostPosted: Sat Jan 07, 2017 9:34 pm    Post subject: Re: Driver seat- bottom cover installation question Reply with quote
Examples:
Ok, that is very possible too.
The seat above looks like they only did one, maybe someone was sloppy.
Juan
Juan is offline
PostPosted: Sat Jan 07, 2017 10:30 pm    Post subject: Re: Driver seat- bottom cover installation question Reply with quote
This is all super helpful. Thank you!
1969 BMW 2002
1959 Ford F100
Juan
Juan is offline
PostPosted: Tue Jan 17, 2017 9:13 pm    Post subject: Re: Driver seat- bottom cover installation question Reply with quote
Just wanted to say thanks! Came out great.
1969 BMW 2002
1959 Ford F100
Z
Z is offline
PostPosted: Wed Jan 18, 2017 11:38 pm    Post subject: Re: Driver seat- bottom cover installation question Reply with quote
Juan wrote:
Looks great!
hitest
hitest is offline
PostPosted: Thu Jan 19, 2017 7:50 pm    Post subject: Re: Driver seat- bottom cover installation question Reply with quote
Beautiful work sir!
FU#5
