Alaskaberrys  Samba Member
Joined: June 19, 2016 Posts: 1079 Location: SE Alaska
Posted: Sun Jan 08, 2017 12:12 pm Post subject: To invert or not to invert? |
Happy Vangon new year all!
The previous owner of our '91 Westy installed a nice 1000 watt AC inverter (Moto Master Eliminator) along with the GoWesty auxiliary battery set up under the drivers seat. We've added a GoWesty portable solar panel set up and controller. All is mounted on the sink/stove partition behind the drivers seat.
We've enjoyed about six weeks of VW time in the six months we've owned the van and only ever used the inverter once - for our electric coffee grinder, which is now replaced by a nifty hand grinder - and am wondering if the inverter is worth keeping. I'd like to install a batter charger/tender as the van sits for a month or two at a time at the in-laws and am eying the inverter location....
I can see off-roaders utilizing small compressors and such so I imagine they're indispensable for some folks, but it does not seem to be for us. Perhaps I'm not thinking of a future use? All our power uses are 12v or USB it seems.
So, my question to you all; what do you use your inverted for? Those without, is it high on your wish/to do list?
Mark, of the inverted _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
chachi Samba Member
Posted: Sun Jan 08, 2017 12:18 pm Post subject: Re: To invert or not to invert? |
same story here, PO installed inverter. we don't use it but probably won't get rid of it cause, enh, you never know. also we have a nice hand crank coffee grinder and it does a better job than our bigger AC powered grinder anyway, less silt and resultant bitterness. _________________ '74 transporter panel
'91 vanagon carat NAHT |
campism Samba Member
Joined: September 07, 2007 Posts: 4682 Location: Richmond VA
Posted: Sun Jan 08, 2017 12:19 pm Post subject: Re: To invert or not to invert? |
We carry one but our approach is normally kinda casual and slapdash. We have not installed a second battery or solar and do not do much boondocking but got this to power a laptop for the times when my wife needed to bring her work along and have had it for most of the ten years we've owned the Westy. _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
Posted: Sun Jan 08, 2017 12:24 pm Post subject: Re: To invert or not to invert? |
campism wrote: |
We carry one but our approach is normally kinda casual and slapdash. We have not installed a second battery or solar and do not do much boondocking but got this to power a laptop for the times when my wife needed to bring her work along and have had it for most of the ten years we've owned the Westy. |
Good point campism, we haven't charged our laptop yet...would need it for that. 1 for invert. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
E1 Samba Member
Joined: January 21, 2013 Posts: 8328 Location: Westfalia, Earth
Posted: Sun Jan 08, 2017 12:27 pm Post subject: Re: To invert or not to invert? |
There's a lot to be said for having a smaller, 200-400 watt inverter to save the juice of running a bigger one.
We had a 400 for minor-draw tasks like recharging AA and AAA charging, but it recently failed and are about to get another. It's up front running off the cig lighter DC socket.
But our main inverter is an 1100-watt from GoWesty hard-wired into our solar system and that bigger one is good for quicker laptop charges, powering our 24" monitor, charging a drill quicker when you need it now, and to run a blender for smoothies that the 400 wouldn't run at all.
But your shortcoming is the too-small GW wiring that slows down charging times and alternator throughput. I'd start with real wiring. _________________ 1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
Subtracting weight makes you faster everywhere." — Colin Chapman
Jonathan Weisheit, Race in Peace:
https://www.youtube.com/watch?v=z3dS7xiFn7I&t=500s |
rowan Samba Member
Joined: March 18, 2007 Posts: 133 Location: Knoxville, Tennessee, USA
Posted: Sun Jan 08, 2017 12:29 pm Post subject: Re: To invert or not to invert? |
Alaskaberrys wrote: |
Mark, of the inverted |
I'm a special case (aren't we all) as both my wife and I need a CPAP to sleep so we have to have AC. Other than that I really can't remember ever using an inverter.
r _________________ Rowan
89 Syncro - Juniper Mackenzie
09 Honda Fit - Finnie
17 Ram ProMaster - John Hordle |
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Sun Jan 08, 2017 12:45 pm Post subject: Re: To invert or not to invert? |
I use one to run a Traeger smoker while we hike. Its also been usefull to run power tools for projects when 5 extention cords were not available. A friend showed up to the lake with kids, floaties and a 110v blower instead of a 12v. My lungs were glad we had the inverter. We could easily get along without it, but nice to have in case we need it. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17171 Location: Brookeville, MD
Posted: Sun Jan 08, 2017 12:50 pm Post subject: Re: To invert or not to invert? |
FWIW I would not recommend running a laptop off an inverter. You get a lot of lost power going thru the inverter. It is better to find a 12V power adapter for your laptop. Much easier, BTDT. (It is better to convert only once, 12V to 19V, than twice, 12V to 120V to 19V)
We have an inverter and the only thing that we need it for is to power the 40" TV at our tailgate outings. Other than that everything we use is OK with 12V. YMMV.
BTW the Iota DLS-30/IQ4 is a great power supply/charger...
http://www.iotaengineering.com/dls30.htm _________________ Dave O
The Western Syncro build
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10497 Location: Sunshine Coast B.C.
Posted: Sun Jan 08, 2017 12:51 pm Post subject: Re: To invert or not to invert? |
Some years ago, I installed a modest imverter. 300 Watts? Anyhow...
Useful for:
Quick measure of aux. battery voltage
Soldering iron ($4 harbour freight)
For a while, charging my LG cell phone. (Long story)
Useful to help others when I have surplus solar (will be charging a friends MacBook soon)
Future uses: cordless drill or other batteries? I used to carry a cordless drill. Have found occasion for one on this recent longer trip.
Mostly though, it serves as a + junction for a bunch of other wires.
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
fxr Samba Member
Joined: December 07, 2014 Posts: 2654 Location: Bay area CA
Posted: Sun Jan 08, 2017 12:52 pm Post subject: Re: To invert or not to invert? |
campism wrote: |
Good point campism, we haven't charged our laptop yet...would need it for that. 1 for invert. |
12V DC-DC laptop chargers are cheap enough. Much more efficient than using an inverter to 110V AC then an adapter back down to 19V DC. _________________ Jim Crowther
Vespa GTS 300 |
hans j Samba Member
Joined: May 06, 2006 Posts: 2741 Location: Salt Lake City UT
Posted: Sun Jan 08, 2017 12:59 pm Post subject: Re: To invert or not to invert? |
There are specific inverters that have the correct sine wave for laptop charging. That's all we use ours for. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
1621 Samba Member
Posted: Sun Jan 08, 2017 1:12 pm Post subject: Re: To invert or not to invert? |
I bought an 1100w inverter years ago and set it up behind the driver's seat. Seemed like a great idea - and it probably still is. I've used it on a couple of occasions, but certainly not enough to justify its purchase. Honestly, I can't recall using it at all in the last several years. Forgot that I had it until this thread. So unless you really know you need it, I'd consider passing on the inverter. _________________ '85 Westy |
E1 Samba Member
Posted: Sun Jan 08, 2017 1:50 pm Post subject: Re: To invert or not to invert? |
dobryan wrote: |
http://www.iotaengineering.com/dls30.htm |
I had to edit my post as I thought you were referring to a DC laptop charger... until seeing your link.
Cool item it seems! And your conversion comments are well appreciated.
Obvious to us who have a system, but still worth noting is charging from a house battery is always best -- if you have one. All our starter battery does is start the bus, we installed exterior jumper posts if needed, or can jump the starter with either house battery with a four-foot cable. _________________ 1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
E1 Samba Member
Posted: Sun Jan 08, 2017 1:58 pm Post subject: Re: To invert or not to invert? |
Vanagon Nut wrote: |
Useful for:
Neil. |
Great post Neil, just pointing out our 400-watt inverter did NOT work on our soldering iron.
It remains the only time we used anyone else's power for 38 solid road-months... until plugging into shore power for the first time it ever came with a campsite. _________________ 1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6932 Location: Fort Lauderdale, Fl.
Posted: Sun Jan 08, 2017 2:10 pm Post subject: Re: To invert or not to invert? |
uther wrote: |
r |
F.Y.I. I just got my hands on a Philips System One Acpap and it has a 12v power cord as an option which I bought for the road trips. _________________ This free advice is worth exactly what you paid for it.
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12340 Location: Santa Cruz, CA
Posted: Sun Jan 08, 2017 2:37 pm Post subject: Re: To invert or not to invert? |
RV stores are full of items that will run straight off of 12v dc. I have a Lind 12v adapter for my toughbook that works great.
You can buy a soldering iron that runs off of butane as well as 12v chargers for battery operated tools like my 18v drill, sawzall, metal shears, 3/8 impact or circular saw. You can even get 12v compressors to run air tools off of pretty easily.
I have never come up with a need for a inverter myself. |
Timwhy Samba Member
nocreditnodebt Samba Member
Joined: September 28, 2012 Posts: 332 Location: Socal
Posted: Sun Jan 08, 2017 3:36 pm Post subject: Re: To invert or not to invert? |
Some people view an inverter as the answer to all wheeled life's electrical needs.
Fact is they are noisy Audibly and electrically, and inefficent.
Recently barrell connector cord on my laptop DC to Dc car adapter failed, and I reverted to my inverter powering the ACDC power brick.
Being able to measure wattages at a minimum the inverter powering ACDC brick used 9 watts more and at a maximum 22 watts more than my recently repaired DC to DC car adapter.
They also have 12v Cpaps.
I carry 2 inverters, Pure sine wave and a larger sine wave, and both rarely every get used.
A necessary evil, but place one anywhere near a person who has no idea about electrical consumption, and they become battery torturing devices. |
SCM Samba Member
Joined: January 26, 2011 Posts: 3400 Location: Bozeman MT
Posted: Sun Jan 08, 2017 7:17 pm Post subject: Re: To invert or not to invert? |
We think of our Westy as a REALLY fancy tent. It's amazing enough to have a cushy bed and some dome lights. Can't think of a single use for a power inverter that we would welcome into our camp scene. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Sun Jan 08, 2017 8:16 pm Post subject: Re: To invert or not to invert? |
dobryan wrote: |
Ha! Not sure I could talk Diana into a 40" for the van..
Thanks for the Iota link, will look into it as the more I read here keeping batteries healthy pays off. I'm a 12v novice and don't want to mess up on the overall end result, which seems like it's pretty easy to do if no pre planning goes into it. I've found a ton of good threads on the subject - slowly getting an idea of what we want/need.
E1 wrote: |
But your shortcoming is the too-small GW wiring that slows down charging times and alternator throughput. I'd start with real wiring. |
Good point, we've taxed the GoWesty little aux battery set up with a Propex heater and small Dometic fridge/freezer already. Last cold night the Propex cut out on low voltage Considering moving to larger batteries under the bench seat down the road.
SCM wrote: |
We think of our Westy as a REALLY fancy tent. It's amazing enough to have a cushy bed and some dome lights. Can't think of a single use for a power inverter that we would welcome into our camp scene. |
Ha! I think we look at our Westy the same way. When someone asks "what about the bathroom" we're saying "bathroom? We're stoked about the comfy dry bed! With heat. And tunes. And we can carry beer!"
It's great to read the posts on power usages. Does seem like it would be hard to justify buying an inverter for our uses, but having one already - could come in handy. We do carry a 12v drill with two batteries and would be handy to be able to charge it up - hadn't thought about that senerio either. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
