gti72 Samba Member
Posted: Fri Feb 03, 2017 3:18 pm Post subject: 1990 Westfalia: No reverse |
| hi my reverse stop working on my vanagon,,,,could that be internal or somethings else...thanks |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2717 Location: Missoula MT
Posted: Fri Feb 03, 2017 3:23 pm Post subject: Re: no more reverse westfalia 1990 |
| If it came on suddenly, likely something in the linkage. Either where the shifter meets the floor (common) or under the van in the shifter box or center shifter connection. First step is t see if you can manually put it in reverse at the trans selector shaft to make sure its nothing internal to the trans. If that checks out, then you will need to work your way back to the shifter. Without many details or history on this, i put my money on linkage needing adjusting |
kamzcab86 Samba Moderator
Posted: Fri Feb 03, 2017 4:22 pm Post subject: Re: 1990 Westfalia: No reverse |
Does this van have a manual or automatic transmission? _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Posted: Fri Feb 03, 2017 4:32 pm Post subject: Re: 1990 Westfalia: No reverse |
| kamzcab86 wrote: |
| Does this van have a manual or automatic transmission? |
Good point. |
gti72 Samba Member
Posted: Fri Feb 03, 2017 6:05 pm Post subject: Re: 1990 Westfalia: No reverse |
| sorry guys auto trans |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1173 Location: SF Bay area, CA
Posted: Fri Feb 03, 2017 7:06 pm Post subject: Re: 1990 Westfalia: No reverse |
Maybe the switch down below the shifter needs adjustment? _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
