Roof Rack
Hank Montura
Hank Montura is offline
PostPosted: Fri Mar 31, 2017 9:53 am    Post subject: Roof Rack Reply with quote
Hello all,
I am contemplating getting a roof rack to haul two kayaks and I am looking for recommendations.
1984 Westfalia "Trogdor"
2013 Beetle
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Fri Mar 31, 2017 10:07 am    Post subject: Re: Roof Rack Reply with quote
Artificial rain gutters and either Thule or Yakima.
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
dobryan Premium Member
dobryan is offline
PostPosted: Fri Mar 31, 2017 10:19 am    Post subject: Re: Roof Rack Reply with quote
Here is some good reading.
https://www.thesamba.com/vw/forum/search.php?searc...=titleonly
Dave O
The Western Syncro build
jimf909
jimf909 is offline
PostPosted: Fri Mar 31, 2017 9:25 pm    Post subject: Re: Roof Rack Reply with quote
Hank Montura wrote:
Hello all,
Assuming this is for the Westy? Do you own any rack parts now? Are they Yakima or Thule? If so, continue with what you've got. If not, choose one brand and stick to it. It doesn't matter which one, it's like choosing between ford/chevy, Toyota/Nissan: the difference is inconsequential.
Next, are you buying new or used? Used? Troll CL to find some towers, bars and mounts that bolt to the Westy op. New? Never pay full retail. REI should have them at 20% off at the Anniversary sale at the end of May.
Next, plastic boats or composite? Plastic? Toss em up there and strap em down, Composite? Get some proper saddles or rollers.
With a bit of research it's easier than it looks.
The kayak in this picture is inflatible...
- Jim
Butcher wrote:
Guilty as charged.
ThankYouJerry
ThankYouJerry is offline
PostPosted: Sat Apr 01, 2017 9:23 pm    Post subject: Re: Roof Rack Reply with quote
Once you have your rack... don't forget the Jack Bombay pop-top lift assist struts!
https://www.thesamba.com/vw/classifieds/detail.php?id=798951
1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD
jfu057
jfu057 is offline
PostPosted: Sun Apr 02, 2017 7:40 am    Post subject: Re: Roof Rack Reply with quote
Yeah! these are awesome. I can lift the pop-top with two kayaks loaded on the HD struts. And like everything else you buy for a vanagon one purchase generally leads to several more Smile
I'll just say that if you plan on using J-style cradles, the square bars will not spin while you are trying to load the boat. I had that issue with the round bars no matter how much I cranked them down. My boat is 65 pounds though.
Also, that collapsible ladder is also very useful and fits in the closet.
Hank Montura
PostPosted: Sun Apr 02, 2017 11:28 am    Post subject: Re: Roof Rack Reply with quote
Lots of good information here. I got a lead on a place in Portland that has new and used racks and does the install. A hundred bucks or there about for the Jack Bombay lifts seems like a needed investment too as I am getting older and that pop top is not getting any easier to pop. That collapsible ladder looks handy too. My closet is full of bedding but will one fit under the bed? Cans somebody recommend a decent one?
2013 Beetle
Multiman mv
Multiman mv is offline
PostPosted: Sun Apr 02, 2017 5:38 pm    Post subject: Re: Roof Rack Reply with quote
I have three Yakima round bars mounted on my van. I also have a gary lee small cage mounted. The three bars allows me to carry anything from a short surfboard to a long board, paddle board and sea kayaks. I often use the front and rear bar with kayak cradles to transport a sea kayak and then I put padded foam on the front and rear bar of my roof cage to carry shortboards at the same time. I find that the system is pretty versatile. The side ladder from Rocky Mountain westy is a big help when it comes to loading or unloading. A stowable ladder like a previous poster has is a good solution too. I would definitely recommend lift assist springs if you don't have them already. Possibly use two per side. Hope this helps. Good luck finding what you're looking for.
kourt
kourt is offline
PostPosted: Sun Apr 02, 2017 7:38 pm    Post subject: Re: Roof Rack Reply with quote
Two Thule load bars on 387 feet, attached to ARGs on the poptop. The load here is two sea kayaks, each weighing 55lbs. I drove from Austin to Key West and back in this config with no problems. You'll need help opening and closing the poptop, even with struts.
kourt
Hank Montura
PostPosted: Tue Apr 04, 2017 10:12 am    Post subject: Re: Roof Rack Reply with quote
I like the low profile of this set up. May I ask how much those three Yakima bars cost for installation?
2013 Beetle
vanagonjr
vanagonjr is offline
PostPosted: Tue Apr 04, 2017 10:25 am    Post subject: Re: Roof Rack Reply with quote
You can go to rack attack and go through the website. Choose, ah heck, I'll do it
$194 for each set of towers that does two cross bars, $89 for two cross bars (all sizes) (Note Yakima).
You'll have to call them for the single set, or go through the website looking for options, or find a friend to split up a set.
Fake gutter mounts are approx $35 for set of pair. You will need 3 pairs.
Locks are extra.
Or Craigslist...
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
WestyWanter
WestyWanter is offline
PostPosted: Tue Apr 04, 2017 4:20 pm    Post subject: Re: Roof Rack Reply with quote
I'm a new owner an not to this point yet because I'm saving for if my engine goes boom, but is there any roofracks that work without drilling into my top?
RichBenn
RichBenn is offline
PostPosted: Tue Apr 04, 2017 6:40 pm    Post subject: Re: Roof Rack Reply with quote
With the westy pop-top, no, unless you want to remove the rack every time you lift the rack. Then the lonf towers work.
BTW, there are many used tower racks out there.
Rich
Multiman mv
PostPosted: Sun Apr 09, 2017 4:34 pm    Post subject: Re: Roof Rack Reply with quote
Locks are extra.
Or Craigslist...
Thanks for answering. Yes, that's about what I paid. Gowesty does sell a single bar, gutter mounts and towers. You might pay a premium for only one set up but I didn't see another option.
katstan
katstan is offline
PostPosted: Fri Jul 21, 2017 8:44 am    Post subject: Re: Roof Rack Reply with quote
Does anybody know if one of these sets would work on the Westy?
I'd like to get a roof rack and will be passing through this area this weekend.
https://oneonta.craigslist.org/pts/d/thule-roof-rack/6204872072.html
"I also have a set for tracks or truck caps, and a set for veh/ truck caps / campers with old style rain gutters;; ford, chrysler, chevy trucks, Jeeps, land rovers, volvos, bmw,, Mercedes, VW ect ....also a Thule roof rack specificaly for VW Beatles 1998-2010 $95 and a Thule specificaly for VW Passat / Golf 98-99 $95 also a Medium size Thule Ascent 1100 roof top carrier box,,, long narrow design fit nicely beside a kayak or a couple bicycles ;;; (88" x 23" x 13") / ( 220cm x 58cm x 33cm ) ( volume =aprox (12 cubic ft ) / (340 liters ) ,"
or these: https://nwct.craigslist.org/pts/d/yakima-car-roof-carrier/6224169597.html as I could pass through that area next weekend.
"Two Yakima car roof carrier racks. Model 8000101 rain gutter model. 58" length. Fits older style cars with rain gutters. Includes canoe gunwale brackets. These are high quality and very durable - zytel nylon. This system goes for $300 new. Selling for $50 cash."
or this if I just got the fake rain gutters? https://hudsonvalley.craigslist.org/pts/d/roof-racks-for-scion-xb/6226180517.html
Thanks all!
1990 White Vanagon Westfalia since Feb. 2017
ironpotsthevanagon.wordpress.com
davevickery
davevickery is offline
PostPosted: Fri Jul 21, 2017 9:20 am    Post subject: Re: Roof Rack Reply with quote
This is the kind you want. That is a great deal and may not stick around until another weekend. Thule makes a version too with square bars, either of them is what you always see on a westy You'll need the "artificial gutter mounts" but they are cheap and you just bolt them to the side of the poptop and those legs just go in them. The 58" cross bar is good too. 50" is common and just a little short for a westy. You can buy longer and cut down too but 58 is just about right. The standard height legs are what you want too. The high rise legs make the roof rack stick way up. Don't drill holes in your poptop for the artificial rain gutters until you know which rack and uprights you have and figure out where it will sit.
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Fri Jul 21, 2017 9:21 am    Post subject: Re: Roof Rack Reply with quote
That first ad is free-verse gibberish, so it’s hard to parse out exactly what he has for sale (dude, press the Return key every now and then)!
I can tell you that if he indeed has this Thule setup for truck caps & extended roofs (like a Westy), and 58” bars, it will work well. I'm currently using this on mine to haul kayaks.
The Yakima setup in the second ad should work too, if you added Yakima-compatible artificial rain gutters like in the Thule pic above. And as mentioned, is a very good deal.
Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com
katstan
katstan is offline
PostPosted: Fri Jul 21, 2017 9:50 am    Post subject: Re: Roof Rack Reply with quote
You're right... called him and somebody is supposed to pick them up tomorrow but if it falls through he has my number. thanks for the feedback!
katstan
katstan is offline
PostPosted: Fri Jul 21, 2017 9:57 am    Post subject: Re: Roof Rack Reply with quote
Yeah, hard to figure out exactly what he has. I emailed him though... so we'll see.
