Lowering with T-1 spindels.
Page: Previous  1, 2, 3  Next
djfordmanjack
djfordmanjack is offline
PostPosted: Thu Aug 13, 2009 3:25 pm    Post subject: Reply with quote
Scotty wrote:
I will admit from the side they look to be very similar, but you'll only know for sure when you look in plan view.
Now I don't know if a barndoor is set up like this or not, but just speaking from my experience of running late spindles on a barndoor with barndoor steering is that it got messed up.
I think it's not that much of a problem ! see as first the wheelbase of a bus is the same as on a bug ( 2400mm) and more important the idler arm of the front axle ( the lever converting the draglink steering to the tie rods) is in more or less the same position as on a bug, means closer to the drivers side. ( compared to a later bus having this idler arm in central position) means the short driversside tierod connects to a similar point of geometry on BD bus and bug.
maybe if you use later bus spindles connecting tierods to the offset idler arm on a BD beam, this could give you the trouble you found Question Exclamation
i do not know for spindle/kingpin inclination and or camber/caster difference in the late to early bus spindles, but I know that early bug spindles are damn close to the BD setup for sure, except for a 5" drop or so Wink
streetwagens
streetwagens is offline
PostPosted: Tue Aug 18, 2009 8:28 am    Post subject: Reply with quote
Just for reference, ball joint bug tubes are 10mm further apart than barndoor tubes.
To catch a fish, you must first think like a fish....
AlteWagen
Troll
AlteWagen is offline
PostPosted: Mon Aug 24, 2009 4:21 pm    Post subject: Reply with quote
HOLY CRAP!!! Shocked I accidentally clicked on the BD forum and saw this thread, too cool!
Will this only work on pre 55 beams or can a similar conversion work on a 55-63 beam as well? I have an early 63 with the expensive as hell brakes and link pins (im afraid to even look for the king pin sets) and this would keep my bus running safely and not trash it in the process.
Thanks
GERMANAIRE
GERMANAIRE is offline
PostPosted: Thu Aug 27, 2009 1:45 pm    Post subject: spindals Reply with quote
Hello, I am building a 65 walkthru and wanted to know if this set up would work on my bus. Can I use 65 beetle disk Brake spindles also. Thanks, Peter
BeaterBarndoor
BeaterBarndoor is offline
PostPosted: Fri Aug 28, 2009 8:54 am    Post subject: Reply with quote
Thanks
i would imagine you could run this set up on 55-63 but it would have to be modified for the tierods to be mounted to the spindle.the tie rod arm off the spindle sits high like barndoor where the arm for 55-63 bus sits low.you would have to cut and weld(or adapt it but im wondering if the arm is left where it is,it may tend to hit the frame rails on turns.something to keep an eye on) that arm to drop it down in the correct position for later bus for it to track correctly in the front. same idea that i had to deal with when i had 63 spindles on my BD. i had to make an adaptor to reposition the tierod arm in order to track properly.
im not so sure that this would work for 64-67 though as the link pin is larger and may not leave enough "meat" in the spindle . having never done this method yet, i dont really know.
the best way to avoid those expensive 55-63 brakes is to have a set of "63 only" spindles built. a half year only spindle that uses early 20mm link pins and just as they changed to later "cheap" brakes. this is what i used to adapt to my BD when i installed the late bus spindles.
hope that helps understand some.
www.thebustransfer.com
Whaaaaat?
sled
sled is offline
PostPosted: Fri Aug 28, 2009 9:39 am    Post subject: Reply with quote
can it physically be done? yes. Will it perform well? no. Like discussed, the beam tube spacing is different from barndoors to non barndoors, and from beetles to buses. putting linkpin beetle spindles on a non barndoor beam would be the furthest mismatch of the possible combo's.
depending on what your ride height is, it may track and handle alright, but its when the suspension is deflected or extended that you run into issues of castor change. You have to look at the torsion arms as a parallelogram, if they are not parallel then the non-fixed end (spindle) is going to change in angle. How radically depends on how far 'out of wack' the parallelogram is. Ideally you would set the castor in the beam itself (bottom tube forward of the top tube slightly) and have the torsion arms perfectly parallel.
then you have the issue of the steering arm as Mark covered above.
lastly, ackerman angle is an important consideration, you would need to modify the steering arms on the beetle spindles to be correct.
drive your split.
BeaterBarndoor
PostPosted: Sat Aug 29, 2009 10:17 am    Post subject: Reply with quote
maybe i am missing something here ,and if i recall correctly, yes beetle beams are different in tube distance. I dont have anything but my own beam on my bus currently to compare anything but after a quick gander at trail arm/spindle combos, it doesnt seem all that far off visually throughout.
stock barndoor set up
stock post BD
BD running 63 dropped spindles(doesnt appear to have any change in arm angle)
BD running beetle linkpin(no visual angle change)
BD running balljoint beetle(definate arm angle change)
i have drivin thousands of miles on both the BD with 63 spindles as well as the BD with BJ beetle spindles and i have never found either to be squirrelly or have any abnormal tire wearing. in fact with the BJ spindles,being the most extreme change in angle of all the above, i have to note that my tires have perfect wear still and i probably have close to 10k miles on them. no "intentional" caster changes but my bus is lowered,possibly enough to escape any issues? it drives great for me.
just by the photos of running 63 spindles on a BD beam, i would say there is little to no real difference in the tube spacing from BD to late beams. but from memory, there is definately a difference from bus to beetle.but those link pin beetle spindles sure look pretty uniform.
i only speak from my experiences. i cant vouch for the technical writings ,which would all make sense in theory.
without having each style beam in front of me ,i cant voice anything else other than what i have run on BD.
Whaaaaat?
Hebster52
Hebster52 is offline
PostPosted: Wed Sep 16, 2009 11:40 pm    Post subject: Reply with quote
I quote myself with some facts about the two beams/spindles:
(From this thread)
Hebster52 wrote:
I have now compared Type-1 spindles with my barndoor spindles:
Linkpin c-c measurement:
Type-1 spindles, 132mm
BD spindles, 138mm
Beam tube c-c measurements so far:
Type-1, 120mm
Barndoor, appr. 139mm
Difference on linkpin distance is then 6mm and torsionbar pivotpoint distance is 29mm...
Strange geometry on the type-1.... Not parallell as stock either...?
The Barndoor seems to be parallell though..
I've done this comparison because I'm doing the opposite and will fit Barndoor spindles to my -51 split bug.
~Kris~
"The Hebster52" my Hebmuller replica build
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
Scotty
Scotty is offline
PostPosted: Thu Sep 17, 2009 5:33 am    Post subject: Reply with quote
I'm pretty sure they're the same
Hebster52
PostPosted: Thu Sep 17, 2009 6:25 am    Post subject: Reply with quote
Yes, they are exactly the same.
~Kris~
The 912ST
The KidVRod project
Scotty
Scotty is offline
PostPosted: Fri Sep 18, 2015 3:47 am    Post subject: Reply with quote
Can anyone tell me exactly how much narrower bug k&l spindles are than bus 64-67 spindles?
EmpiGT
EmpiGT is offline
PostPosted: Fri Jul 14, 2017 12:17 pm    Post subject: Re: Lowering with T-1 spindels. Reply with quote
I don't have any early bug link pin beams handy to look at. But someone here probably knows. Can t-1 trailing arms fit onto a barndoor beam. So not having to machine anything to use t-1 spindles? That seems too eazy, but to me looks like it can be done. Are the springs bigger in a barndoor beam?
mr. warehouse
mr. warehouse is offline
PostPosted: Fri Jul 14, 2017 12:28 pm    Post subject: Re: Lowering with T-1 spindels. Reply with quote
T1 arms will not fit into a BD beam
Here's the way I did it.
Early bus link pins with the heads turned down to fit in side the T1 carriers.
Needle bearing bushings turned down to also fit into the T1 carriers
Spacers made to fill the gap.
Not shown are the T1 sims I opened up the ID to use on the bus link pins.
No need to machine the carriers going this route
EmpiGT
EmpiGT is offline
PostPosted: Fri Jul 14, 2017 1:42 pm    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Thanks Greg,
I just got a spare barndoor beam missing the tailing arms out. Was hoping I could do something with type 1's. Guess I'll be on the hund for another set of barndoor arms. Thanks for the info on the spindles.
Rusting Hulk
Rusting Hulk is offline
PostPosted: Sun Jul 30, 2017 4:19 am    Post subject: Reply with quote
Busfarmer wrote:
Made a collar for the other side.
Can anyone help with the size of this spacer? From memory its 7mm thick, but i can't find it posted anywhere.
Cheers
Simon
64 356 C Coupe
Hellberg
Hellberg is offline
PostPosted: Tue Aug 01, 2017 3:58 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
7mm thick
outer diameter: 34mm
inner diameter: 20mm
this is what I have with beetle spindles, beetle bushings and barndoor linkpins
Type 2 -53 smooth Gate SC (o\!/o) Type 1 -50 |o\ /o| Type 2 -55 Barndoor kombi
...........Driving barndoor to HO 2017............
Rusting Hulk
PostPosted: Tue Aug 01, 2017 10:21 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Many thanks, just what I was looking for Very Happy
64 356 C Coupe
mr. warehouse
PostPosted: Tue Oct 16, 2018 2:51 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
edit to replace missing photo and add a photo of a set done with 356 spindles.
Early bus link pins with the heads turned down to fit inside the T1 carriers.
Terry Gaudet
Terry Gaudet is offline
PostPosted: Sun Feb 02, 2020 4:44 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Thanks for posting the picture Mr. Warehouse. It helps me see the mods.
So these will fit on 55-63 bus front beam arms?
Terry Gaudet
1950 Beetle Standard
1955 Canadian Custom
1956 Kombi w/SO23 kit
1965 Kombi walkthrough
1965 Double Cab
Terry Gaudet
PostPosted: Sun Feb 02, 2020 4:55 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Oh, and one more question. What is the overall width difference between the stock barndoor beam and a beetle k&l beam? I am also going to consider modifying an early beetle beam to fit barndoor chassis so I can use beetle spindles to mount my 356 brakes.
Terry Gaudet
1965 Double Cab
Page 2 of 3
