Can't disconnect hand brake cable from backing plate.
licketysplit
licketysplit is offline
PostPosted: Tue Aug 08, 2017 7:30 am    Post subject: Can't disconnect hand brake cable from backing plate. Reply with quote
First post, so sorry if this topic has been covered, but I couldn't find info for busses. Anyway, trying to remove my backing plate on my 1966 bus. I can't figure out how the Hand brake cable disconnects from the backing plate. There is no bolt on the back side. Do I have to disconnect from the hand brake itself?
Thanks,
Toby
Clara Premium Member
Clara is offline
PostPosted: Tue Aug 08, 2017 7:53 am    Post subject: Re: Can't disconnect hand brake cable from backing plate. Reply with quote
Thanks,
Toby
pull spring away from backing plate.
remove U shaped clip
then cable should pull through backing plate.
don't lose U shaped clip.
licketysplit
PostPosted: Tue Aug 08, 2017 8:25 am    Post subject: Re: Can't disconnect hand brake cable from backing plate. Reply with quote
Thanks Clara,
So I started pulling on the u-shaped clip and noticed it cracked a little bit. I wasn't pulling on the spring at the time. Just worried that when I pull the spring, then the clip, that it might break or not be able to go back on. Do you have any advice on what to do if the clip does break?
thanks
sgellis
sgellis is offline
PostPosted: Tue Aug 08, 2017 8:29 am    Post subject: Re: Can't disconnect hand brake cable from backing plate. Reply with quote
Mine did not have clips when I took it apart so it didn't get any when I assembled it. The rust had seized the cables in there quite well and took a bit of work to slide them out.
Another thing to add on the list.
Clips...
https://www.thesamba.com/vw/forum/viewtopic.php?t=656985
My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings)
licketysplit
PostPosted: Tue Aug 08, 2017 8:57 am    Post subject: Re: Can't disconnect hand brake cable from backing plate. Reply with quote
Thanks sgellis
I looked at that thread, but it didn't say where he got that clip. I pm'd GLHTurbo, he's the one that posted the pic of the clip. Do you happen to know off hand where to pick one up?
Thanks
sgellis
sgellis is offline
PostPosted: Tue Aug 08, 2017 9:05 am    Post subject: Re: Can't disconnect hand brake cable from backing plate. Reply with quote
licketysplit wrote:
Thanks sgellis
Thanks
Don't think they are available. Those in the thread were hand made. Think I will try using a slotted finish washer for mine.
VWLady
Crazy VW Lady
VWLady is offline
PostPosted: Tue Aug 08, 2017 9:44 am    Post subject: Re: Can't disconnect hand brake cable from backing plate. Reply with quote
I've made them out of spring steel. The metal bands used on packing crates can also be used to cut one out.
hazetguy
hazetguy is offline
PostPosted: Tue Aug 08, 2017 9:53 am    Post subject: Re: Can't disconnect hand brake cable from backing plate. Reply with quote
use a horsehoe clip that is originally used for holding the e-brake arm mounting post to the brake shoe. crimp it slightly, enough to fit in the backing plate opening, and enough for the spring to set on it well, but not tight on the cable. fast, easy, inexpensive, works great.
licketysplit
PostPosted: Thu Aug 10, 2017 2:18 pm    Post subject: Re: Can't disconnect hand brake cable from backing plate. Reply with quote
So I followed Clara's advice, but the cable would not come out of the backing plate. I was able to pull on the backing enough to get it around the spindle. Hopefully I didn't ruin the adjustment on the hand brake. Confused Fortunately I was able to preserve the metal clip on the cable. But I bought a pack of horseshoe clips just in case.
Question Any other ideas on getting the cable through the backing plate?
Thanks for all the help
sgellis
sgellis is offline
PostPosted: Thu Aug 10, 2017 5:32 pm    Post subject: Re: Can't disconnect hand brake cable from backing plate. Reply with quote
I was replacing mine so I cut the cable and drove the casing out with a large punch.
Maybe try penetrating oil and a small punch to drive it out. Carfull not to hit the cable though. Unhooking the cable at the front will allow you to get the spring out of the way.
VWLady
Crazy VW Lady
VWLady is offline
PostPosted: Thu Aug 10, 2017 5:38 pm    Post subject: Re: Can't disconnect hand brake cable from backing plate. Reply with quote
The end of the cable is metal and that slips into the hole on the backing plate. They often get rusty and are hard to pull out with out some persuasion like a tap on a drift from the inside to push it out or at least loosen it. Heat or a good spray penetrate like kroil is another option.
The whole works including the spring on the cable will come out.
hazetguy
hazetguy is offline
PostPosted: Thu Aug 10, 2017 5:55 pm    Post subject: Re: Can't disconnect hand brake cable from backing plate. Reply with quote
it's also a lot easier to work with if the backing plate is still bolted to the reduction box.
grizpdx
grizpdx is offline
PostPosted: Thu Aug 10, 2017 6:25 pm    Post subject: Re: Can't disconnect hand brake cable from backing plate. Reply with quote
I swear by this stuff. Far better and far faster results than PB Blaster.
Begins buying stock in deep creep.
