kooper271 Samba Member
Posted: Thu Aug 17, 2017 3:30 pm Post subject: Re: Need some help: FI hard start, dies on idle |
| vwwestyman wrote: |
Though it shouldn't be a big player in warm weather, it doesn't appear that your cold start valve is plugged in. |
I dont think his harness is installed yet in that photo. But it is worth triple checking all of the connections |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5874 Location: Wamego, Kansas, USA
| furgo wrote: |
| vwwestyman wrote: |
Though it shouldn't be a big player in warm weather, it doesn't appear that your cold start valve is plugged in. Way back when I had the FI motor in my '78, the clip for the cold start valve plug was missing so sometimes it would slip off.
I always new that had happened because it would take a good bit more cranking to start it up. |
Thanks for the reply. I mentioned it below the picture, but the harness was not connected yet when I took it. Before I tried to start the engine, I connected the harness, vacuum hoses, and everything else.
I shall take another picture with the full connections and upload it soon, as it seems to be a source for confusion. |
Ha ha, and I didn't even notice the disconnected fuel injectors! I did have a vague thought of how organized or clean looking the engine seemed, but didn't occur to me that this was because there were less wires than normal on it! _________________ Dave Cook
1973 Wild Westerner
My Thing |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53222 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Aug 17, 2017 3:35 pm Post subject: Re: Need some help: FI hard start, dies on idle |
The spoonfull of gas trick will expose a no fuel condition, if it's not getting any fuel at all it'll run a few seconds, if it's getting fuel but too lean to start it'll start almost instantly.
A small squirt bottle works well for this test, pop a breather hose out of the side of the S boot and give the bottle a squeeze so ~ a tablespoon (15ml) of gas gets into the plenum, then replace the hose and attempt to start it.
A trigger sprayer also works, or even a length of fuel or vacuum line dipped deep into a gas can, seal the other end with your thumb and release it when you have it aimed into the boot.
If it makes it even harder to start it's likely you have a rich condition or bad spark. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
furgo Samba Member
Joined: September 06, 2016 Posts: 944 Location: Southern Germany
Posted: Thu Aug 17, 2017 5:42 pm Post subject: Re: Need some help: FI hard start, dies on idle |
Perfect, thanks for the clarification. I now understand much better the spoonful of gas trick. So as you said, with it I can determine one of the 3 conditions:
1. No fuel (I don't think it applies here, as I could eventually start the engine and get it running for a bit)
2. Lean
3. Rich
Say if I manage to determine if it's lean or rich, what can I do with this information?
I could think for instance it would help me determine which direction I should turn the idle speed screw to, correct? What else I should be looking at, armed with this knowledge?
One more related question:
| busdaddy wrote: |
| Try unplugging and grounding the TS2 wire first, then try disconnecting a small vacuum line and leaving it open, the TS2 will lean it and the open line will add air, see if it's worse or better. |
Is this an alternative way of doing the spoonful of gas trick, or a separate test? _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate |
Posted: Thu Aug 17, 2017 7:12 pm Post subject: Re: Need some help: FI hard start, dies on idle |
| furgo wrote: |
I could think for instance it would help me determine which direction I should turn the idle speed screw to, correct? What else I should be looking at, armed with this knowledge? |
Don't adjust anything until you have fixed whatever is wrong. |
Posted: Thu Aug 17, 2017 7:48 pm Post subject: Re: Need some help: FI hard start, dies on idle |
| furgo wrote: |
2. Lean
3. Rich
| busdaddy wrote: |
Is this an alternative way of doing the spoonful of gas trick, or a separate test? |
Determining lean or rich tells you which path to take for further diagnosis, lean points towards a vacuum leak or weak fuel supply, rich could be a kinked return line or a sensor problem.
Unplugging the TS2 and grounding the ECU wire puts the system in fully warmed up lean mode, if the mixture is too rich grounding sometimes leans it enough to run. It's the opposite of the spoonful of gas test.
And as WT's says, don't go playing with adjustments until you find out what it wants. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
furgo Samba Member
Posted: Fri Aug 18, 2017 12:50 am Post subject: Re: Need some help: FI hard start, dies on idle |
Thanks. Ok, so to recap the tests in my head:
• Grounding TS2 test => leans the mixture
• Unplug (manifold?) vacuum line => enrichens the mixture
• Spoonful of gas test => enrichens the mixture
Some further questions on the fuel pressure regulator to see if I can rule it out:
• Given that a) while I was manually actuating the pump, the pressure was 2.7 bar solid (39 psi), b) there was no pressure build up, and c) it's rated at 2.5 bar, I assume that it's doing its job in terms of regulating the pressure, correct?
• In terms of its vacuum function: how much vacuum should I apply for it to return fuel to the tank? As mentioned before, I applied 15 inHg without apparent drop of pressure (and the vacuum held). I can go up to 30 inHg with my manual vacuum pump, but I wasn't too sure if that was too much and if I could damage the membrane.
Or otherwise, how should I be testing the FPR? _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Posted: Fri Aug 18, 2017 3:28 am Post subject: Re: Need some help: FI hard start, dies on idle |
| furgo wrote: |
Unplugging a vacuum line will create a vacuum leak and lean the mixture
Or otherwise, how should I be testing the FPR? |
If the pressure doesn't drop as you apply vacuum your FPR is not functioning properly. Maybe its time to replace it. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42958 Location: at the beach in Northern Wokistan
Posted: Fri Aug 18, 2017 4:51 am Post subject: Re: Need some help: FI hard start, dies on idle |
If you haven't done it already please glance at the two pages 10 & 20
https://www.thesamba.com/vw/archives/manuals/afc_f...Manual.pdf _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
furgo Samba Member
Posted: Fri Aug 18, 2017 8:31 am Post subject: Re: Need some help: FI hard start, dies on idle |
| Wildthings wrote: |
Unplugging a vacuum line will create a vacuum leak and lean the mixture |
Ah, thanks for the correction.
| Wildthings wrote: |
Right, that was a thought. I wanted to understand if it's indeed broken or if perhaps I did not apply enough vacuum. As the actuator mechanism (membrane + spring) for the vacuum port is essentially the same one as for the fuel pressure port, I thought that it could not have been broken. But it does puzzle me.
Thanks. Indeed, I've looked at the AFC manual and in fact I followed the test there. That's where I got the specs from. Unfortunately, it does not say anything about vacuum testing. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
furgo Samba Member
Posted: Fri Aug 18, 2017 11:49 am Post subject: Re: Need some help: FI hard start, dies on idle |
I admit defeat. For now. It'll have to be plan B for holidays this year :/
But I didn't go down without a fight, and I'll be back to it after vacation.
TL;DR:
• I narrowed down the symptoms: hard (cold) start and rpms creeping down until the engine dies
• I think they're two separate issues, the decreasing RPMs being the one to worry about. I've now learnt to temporarily work around the hard coldstart by half-depressing the gas pedal while cranking. I found some references with others having a similar issue. Unfortunately, I could not find a report of whether it was ever fixed.
• I did the spoonful of gas, TS2 grounding and vacuum line removal tests. See below for the results, but none of them made the situation worse. Removing the vacuum line seemed to make the engine happier by slightly increasing the idle RPMs
• Timing is off by 5.5°: it's 2° BTDC when it should be 7.5 BTDC
• Contact breaker point gap is narrower than spec: ca 0.15 mm vs the expected 0.4 mm
Pics
The previous pictures of the fuel line replacement seemed to confuse some folks as connectors and other bits and pieces were missing at the time of taking them. Here are some pics of what the engine actually looks like:
Initial test
I wanted to have a baseline to compare against, so I tried to just start the bus first. I also connected my multimeter to the engine speed signal (coil -) that goes to my analog tacho, as the digital multimeter has a better resolution (10 rpm vs. 200 rpm). I could then see a more accurate figure for rpm and dwell. So here's what I did:
1. First start with gas pedal half depressed. Went well, not too much cranking or too hard a start.
2. Revs idled to ca. 800 rpm for a bit. A bit on the low end, but still within spec.
3. After a minute or two revs started creeping down to 700 rpm and gradually to 600 rpm. Then the engine died
I also noticed there that a steady foot on the gas pedal helps keeping the engine alive, but sudden acceleration results into a quick engine death once the foot is off the pedal and rpms go down.
4. Second start, without depressing the gas pedal. Much rougher, more cranking was required.
5. Same as before, after a minute or two revs start creeping down. You can feel the engine struggling when it gets down to 740-760 rpm. It all goes downhill from there.
6. Third start much rougher, I couldn't get the engine to start and gave up for the time being.
7. Checked the battery: still 12.6 V
As a note, I did hear a loud hissing sound while the engine was running, but I believe that's normal.
This one is supposed to enrichen the mixture by adding extra fuel.
I used this:
To put some gas in here:
I essentially unplugged the crankcase breather hose and then squirted the contents of the pipe twice into the S-Boot.
Results:
• It seemed to start better as before, in any case, not worse
• Revs around 800 rpm, but still creeping down after a minute or two
• I happened to look at the fuel pressure while running: 2.5 bar, higher than the usual 2.3 bar I had measured and higher than spec with engine running
Vacuum line removal test
This one is supposed to lean the mixture by creating a vacuum leak. I figured it would be better to use a manifold vacuum line, so I unplugged the decel valve's vacuum control pipe:
Results:
• It started and ran much better
• Higher revs: around 900 rpm, engine gives a much more confident feeling
• It holds the revs up for longer than before, but eventually they will creep down to the critical 740 rpm point where the engine starts to gasp for breath.
TS2 grounding test
This one is supposed to lean the mixture by bringing the ECU into thinking that the engine is warm and does not require extra fuel for coldstart.
I grounded the ECU wire (terminal 13) to the free connector on the FI star ground below the 3/4 intake runners (the purple wire on the picture).
Results:
• It also started better (no need to depress gas pedal)
• Revs slightly below 900 rpm
• But they creep down quicker than in the vacuum line removal test
Test conclusions
• Revs creeping down seems to consistently happen in all tests. To me, that's the critical part. The hard start not so much.
• In all tests a sudden acceleration has the effect of revs going up as expected, but afterwards going down much quicker than gradual changes in acceleration. Most of the times it leads to revs going as down as to kill the engine.
• None of the tests apparently made things worse, which makes it difficult to tell the state of the mixture. As such, I'm not sure if they're too conclusive.
• Regarding the improvements in starting, it might just have been that the motor was warm already when I started the tests. This engine has chronically not started well cold (but also not so roughly as now), but it has always started well when warm. So any improvements to cold start might have gone unnoticed.
• The vacuum line removal test seemed to give the best results. Does it then mean that the mixture is too rich?
Measurements
• TS2 resistance at the ECU connector, pin 13: 550 Ohm (ok, the motor was warm)
• Double relay and series resistor connector pins ok (e.g. not pushed out)
• ECU connector pins ok (no pushed-in pins)
• Dwell over 50°, i.e. longer than spec. It was ca. 53°, but difficult to tell, as the values in the meter were a bit jumpy.
Timing
It was the first time for me to do this at all, so I tried static (test lamp) and dynamic (strobe light) timing. I only did the measurements, I did not do any adjustments at this point.
Note to self: remember to turn the ignition on before wondering why the test light does not turn on
This one puzzled me a bit, I might have not done it the right way round (CW or CCW)
The first time, turning the engine CW, the light was turned on at 4° ATDC:
When turning the engine CCW, the light stayed on until reaching ~1° BTDC
I then did the dynamic measurement with the stroboscopic light, and the timing was at 2° BTDC. That means:
• Nearly same measurement as CCW static timing
• 5.5° off from the expected 7.5° BTDC
The strobe light did not turn on at times. I'm not sure if due to a crappy lamp (it was the first time I used it) or if this had something to do with an uneven spark.
Contact breaker points
As mentioned before, the dwell was ca. 53°, outside specs (47°+/- 3°). The breaker points were quite tight: 0.15 mm instead of the expected 0.40 mm. However, one thing that I just realized later was that the points were slightly misaligned: I was expecting them to be more or less parallel when open (I double-checked this with a set of new points), but the opening was slightly larger at one end:
Time to replace the points, I guess.
While I was in there, I cleaned up the rotor contacts and added 3 drops of engine oil to the pad at the top of the shaft. I actually have an overhauled distributor at home I want to replace the one on the bus with as a spare, but I didn't get to swap them yet.
What next
• I'm wondering if I should adjust the points and timing at this point, or if I should just leave as they are to keep the baseline until I've figured out the actual problem. I assume the advanced timing does not have an effect on the decreasing rpms
• Do the 5.5° additional advance have got a significant impact on the ignition timing? I'm asking as I don't have a feel for which type of figures start having a noticeable effect.
• Any ideas on possible causes for the decreasing revs? _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate
Posted: Fri Aug 18, 2017 2:51 pm Post subject: Re: Need some help: FI hard start, dies on idle |
Get the points set correctly to 0.16-0.20". They can't have any little tits if you are setting them with feeler gauges, you need either new points or to file the tits off the old ones. Now set the timing to 7.5° BTDC when turning the engine CW. It should now be very close to being properly timed. Having your timing set 9-10° too far retarded is going to cause starting and running problems.
If you buy new points DO NOT BUY BOSCH, but go to NAPA and buy Echlin. Make sure you lube the wear block and cam for the points with the supplied lube. |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10804 Location: the past
Posted: Fri Aug 18, 2017 3:17 pm Post subject: Re: Need some help: FI hard start, dies on idle |
replace the points and set them to the correct dwell. i almost never use feeler gauges to set the gap, and almost always a dwell meter, points set to the lower end of dwell spec, because dwell will increase as the rubbing block wears. then set correct timing.
also make sure your vacuum canister is working (no leaks) and that the points plate is actually moving freely and not gummed up. |
furgo Samba Member
Posted: Fri Aug 18, 2017 3:47 pm Post subject: Re: Need some help: FI hard start, dies on idle |
| Wildthings wrote: |
| Get the points set correctly to 0.16-0.20". They can't have any little tits if you are setting them with feeler gauges, you need either new points or to file the tits off the old ones. Now set the timing to 7.5° BTDC when turning the engine CW. It should now be very close to being properly timed. Having your timing set 9-10° too far retarded is going to cause starting and running problems. |
Thanks. I've got new points, so I'll just use those and adjust the gap and the timing. Alternatively, my spare distributor has a Compu-Fire module, so I might actually give that a go.
| Wildthings wrote: |
Interesting, would you care ellaborating on that? The ones I've got are Beru, but I also recently found some Bosch ones from the PO that might well be 20 years old and still packaged. They were made in Brazil.
| hazetguy wrote: |
| replace the points and set them to the correct dwell. i almost never use feeler gauges to set the gap, and almost always a dwell meter, points set to the lower end of dwell spec, because dwell will increase as the rubbing block wears. then set correct timing. |
Great info, thanks. I initially measured dwell instead of the gap, but the reading was a bit all over the place. I'll check again if I can get some more steady readings with new, flatter points.
| hazetguy wrote: |
Indeed, both mechanical and vacuum advance are fine, including a freely moving plate. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Posted: Fri Aug 18, 2017 3:53 pm Post subject: Re: Need some help: FI hard start, dies on idle |
The reason that you don't want the Bosch points anymore is because the rubbing block is an L shape piece of plastic that is riveted to the points arm. The plastic is prone to breaking-I had a brand new one break within maybe 5 hours of install in my '73. I had forgotten that I had the exact same issue with points in my '78 6ish years prior TWICE on the same trip. (First pair broke, and I installed the spare pare and it broke in short order.)
The ones I got from Autozone (whatever their house brand is-Duralast I think) in both instances (coincidentally both from the same store in Nebraska, as I was near it both times) had a pyramid shaped rubbing block that can't break in the same manner. _________________ Dave Cook
1973 Wild Westerner
My Thing |
furgo Samba Member
Posted: Fri Aug 18, 2017 4:11 pm Post subject: Re: Need some help: FI hard start, dies on idle |
| vwwestyman wrote: |
The ones I got from Autozone (whatever their house brand is-Duralast I think) in both instances (coincidentally both from the same store in Nebraska, as I was near it both times) had a pyramid shaped rubbing block that can't break in the same manner. |
Bummer, both sets of points I have (Beru and Bosch) have the L-shaped piece. That said, the points on the bus also had it and they seem to have lasted for quite a few years.
In any case, thanks a lot for the clarification, I'll bear that in mind!
At this point I've run out of ideas. After adjusting points and timing I'll do a volume test to see if the pump delivers. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Posted: Fri Aug 18, 2017 4:21 pm Post subject: Re: Need some help: FI hard start, dies on idle |
| furgo wrote: |
| vwwestyman wrote: |
In any case, thanks a lot for the clarification, I'll bear that in mind! |
20 years ago Bosch was a good way to go. A $1 set of Bosch points would last for 40K miles with one cleaning. Somewhere about 2005-2008 things changed and Bosch points became the worst out there while at the same time Bosch started charging a lot more for them.
Nothing wrong at all with setting points with a feeler gauge if you have new points or have filed the old ones flat (actually slightly convex). Point gap is the same for most all engines out there 0.016-0.020" because that is what is needed to dependably break the arc across the points. gap.
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13629 Location: West Coast, USA
Posted: Fri Aug 18, 2017 7:08 pm Post subject: Re: Need some help: FI hard start, dies on idle |
| furgo wrote: |
| Wildthings wrote: |
Interesting, would you care ellaborating on that? The ones I've got are Beru, but I also recently found some Bosch ones from the PO that might well be 20 years old and still packaged. They were made in Brazil. |
I installed new Bosch points ONCE and they literally came apart on the freeway. Luckily the car kept running, but my fuel economy took a HUGE hit and the tach was fluttering. That was how I knew something was wrong…
(The upper piece came off of the lower piece…)
Since installing Echlin (NAPA) points in July of 2016, I drove 300 miles, regressed/reset them, and did not see a dwell change for 27,084 more miles. Last week I saw my timing was down 2° from when I set it that long ago, and I laughed a little; as I have gone nearly FOUR TIMES VW's recommended points check without needing an adjustment. They're THAT good. And they come with free rubbing block grease!
(For the nerds out there, Echlin seems to have purchased the Standard Motor Products "Blue Streak" points manufacturing equipment. So while the Blue Streak's aren't for sale any more, the Echlin's are the same thing.)
Good luck,
Robbie _________________ WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23531 Location: Oklahoma City
Posted: Fri Aug 18, 2017 8:41 pm Post subject: Re: Need some help: FI hard start, dies on idle |
[quote="asiab3"]
| furgo wrote: |
| Wildthings wrote: |
Good luck,
Robbie |
Not quite......but close enough. The better Echlin points are made by SMP.....Standard Motor Products. Same company that made blue streak, Standard and Echlin among others. They are not all the same......but virtually everything in NAPAs points line up is far better than Bosch these days.
I did a pictorial in the high performance forum months ago showing all of the differences. Nothing SMP makes is exactly like BlueStreak......but at least a couple of their part numbers have some of the more important features like larger electrodes and vented centers which prevents the burning and pitting.
I think this is it.
https://www.thesamba.com/vw/forum/viewtopic.php?t=659700&highlight=blue+streak
Ray
