Docfranco Samba Member
Joined: June 04, 2017 Posts: 5 Location: Redondo beach
Posted: Fri Sep 22, 2017 10:28 am Post subject: 1.6 diesel screech...water pump? |
Hi
I have a 1982 1.6 westy, it has developed a screech I can hear most in mornings and not at idle but just off idle under load then goes away after about 2500rpm (guess)
I'm guessing the water pump is on way out. I see rock auto has them for 25$
Is it worth the trouble to replace it myself? Meaning, it a simple R&r?
I do intend to source and put a 1.9td in but not ready yet.... |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8535 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Sep 22, 2017 10:53 am Post subject: Re: 1.6 diesel screech...water pump? |
Check/adjust all your belts. A loose alt belt "tends" to squeal, but a bad water pump "tends" to leak...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10484 Location: Orbiting San Diego
Posted: Fri Sep 22, 2017 11:18 am Post subject: Re: 1.6 diesel screech...water pump? |
Carefully watch the alternator light on the dash when you start the engine. If the squeal doesn't begin until the light turns off then it is probably a belt that is making the noise.
Mark
| Docfranco wrote: |
Hi
I have a 1982 1.6 westy, it has developed a screech I can hear most in mornings and not at idle but just off idle under load then goes away after about 2500rpm (guess) ..... |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12177 Location: Port Manteau
Posted: Fri Sep 22, 2017 12:06 pm Post subject: Re: 1.6 diesel screech...water pump? |
Try loosening the belt enough to be able to spin the pulleys on the H2O pump and alternator. They both should spin fairly easily with no rough spots in the rotation. That might allow you to determine if either are the source for your belt noises _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
Posted: Fri Sep 22, 2017 6:44 pm Post subject: Re: 1.6 diesel screech...water pump? |
Thank you. I think it’s the belt.
It’s loose, but there is only one, it appears the
Alternator is adjusted to the end of its range,
I could not find a belt size for the single belt
Arrangement..
Should I just take my belt in and get a few mm
Smaller?? |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1520 Location: Wisconsin
Posted: Fri Sep 22, 2017 7:11 pm Post subject: Re: 1.6 diesel screech...water pump? |
All diesel Vanagons used a two-belt setup, though many previous owners believed they could simplify and 'improve' upon it by using a single longer belt. The problem is that this may not provide the proper belt tension and rotational speed for both water pump and alternator. The three pulleys aren't even in the same plane of alignment without some rather hinky modifications.
I suggest you source two new correct belts (plus a couple of spares); the belt specs and more info on the topic can be found here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=7301536
Good luck! _________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
kaalualu Samba Member
Joined: June 09, 2011 Posts: 288 Location: Big Island, Hawaii
Posted: Fri Sep 22, 2017 7:43 pm Post subject: Re: 1.6 diesel screech...water pump? |
My timing belt tensioner made some screeching when it was on its way out, be careful. _________________ '84 Transporter 16" CLK's/LED's/ AT's/Mansi injectors
'86 Wolfey Weekender Westfalia AT's/otherwise stock
Sold-'82 TinTop Diesel |
Posted: Sat Sep 23, 2017 7:34 am Post subject: Re: 1.6 diesel screech...water pump? |
So upon closer examination the water pump only has one pilot
So it was modified from stock.
I may just get a smaller belt and see if the will charge and not
Screech |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17322 Location: Brookeville, MD
