67 Westy
Page: Previous  1, 2, 3 ... , 42, 43, 44  Next
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Sat Oct 07, 2017 2:46 pm    Post subject: Re: 67 Westy Reply with quote
Finally got my 3 jalousie windows in, not crazy about them and did minimal polishing adding stainless screws & putty but they are original to my westy so I felt I needed to put them back in. I prefer pop outs or the other camper style best. Tweaking needed for to small areas on the rubber but that's for another day.
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
Eric&Barb
Eric&Barb is offline
PostPosted: Sat Oct 07, 2017 3:20 pm    Post subject: Re: 67 Westy Reply with quote
Looks good. Do keep in mind that mixing aluminum and stainless steel does cause increased corrosion problems. Might want to go with chrome plated brass fasteners later.
In Stereo, Where Available!
Eric&Barb
PostPosted: Sat Oct 07, 2017 3:43 pm    Post subject: Re: 67 Westy Reply with quote
Here is more info:
http://www.aluminiumdesign.net/design-support/aluminium-corrosion-resistance/
PostPosted: Sat Oct 07, 2017 7:22 pm    Post subject: Re: 67 Westy Reply with quote
Thanks Eric&Barb good to know, I'll look for some chrome on brass or chrome on steel.
Eric&Barb wrote:
Here is more info:
PostPosted: Sat Oct 07, 2017 7:30 pm    Post subject: Re: 67 Westy Reply with quote
I tried to get this last section of pop top frame in but I can't figure out how to get it in. Should I remove the two other pieces I already bolted up or is there a way I can get this in another way I don't see?
I can't fit it in Crying or Very sad
See doesn't fit Crying or Very sad
Should I remove these sides to get the front in?
Lind wrote:
crofty
Judas of the North
crofty is offline
PostPosted: Mon Oct 09, 2017 9:51 am    Post subject: Re: 67 Westy Reply with quote
Flip it around , that looks like the rear piece
You may have to put one side in and walk the other in from rear to front.
PostPosted: Mon Oct 09, 2017 11:38 am    Post subject: Re: 67 Westy Reply with quote
crofty I don’t think so as per jeremy57ride image
And bugboy63
Lind wrote:
crofty
Judas of the North
crofty is offline
PostPosted: Mon Oct 09, 2017 12:59 pm    Post subject: Re: 67 Westy Reply with quote
Those both look weird to me. all three hoops should sit in the inner gutter
jeremy57ride
jeremy57ride is offline
PostPosted: Mon Oct 09, 2017 1:24 pm    Post subject: Re: 67 Westy Reply with quote
Mine was never taken out from original. Linda- you should be able to slide that in from the rear on one side, by removing one of the side pieces that you previously mounted.
"If you don't do it this year, you'll be one year older when you do." -Warren Miller
PostPosted: Tue Oct 10, 2017 1:42 am    Post subject: Re: 67 Westy Reply with quote
Got it jeremy57ride I'll try just removing this one and see if I can get it in.
Lind wrote:
DONGKG
The Araneta Boys
Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
DONGKG is offline
PostPosted: Thu Oct 26, 2017 3:58 am    Post subject: Re: 67 Westy Reply with quote
Look at that Westy, it's looking cool each day. Keep us posted, buddy! Congrats!
'67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20
PostPosted: Fri Oct 27, 2017 3:40 am    Post subject: Re: 67 Westy Reply with quote
Thanks DONGKG, yesterday I got back from my former students shop and he hooked me up with a guy to pull a ding out of the rear bumper and media blast both front & rear bumpers in November. Pretty happy to finally get that done and on the bus.
Lind wrote:
Abscate Premium Member
Abscate is offline
PostPosted: Fri Oct 27, 2017 4:58 am    Post subject: Re: 67 Westy Reply with quote
Stumbled into this thread and your build thread. Totally awesome
I thought it was hilarious, reading all the advice to walk away from a $2000 split in 2008 when you are a welder. Had we known we would have all bought ten of them.
PostPosted: Mon Mar 26, 2018 2:19 am    Post subject: Re: 67 Westy Reply with quote
OMG yes agreed Abscate, once this garage queen becomes a daily curbside bus I'm going to start a pressed bumper project preferably a 56 (my birth year). I have a few welding projects I'm working on now but non VW. Looking back I am still glad I sold the 66 because I prefer older although I think it was parted out and it really wasn't that bad.
PostPosted: Mon Mar 26, 2018 2:36 am    Post subject: Re: 67 Westy Reply with quote
As some of you know I replaced my 67 engine lid with a 66 lid and the opening for the latch is different therefore my 67 catch would not fit (thanks Clara for that advice). Well I purchased a 66 latch from a samba member, ekimikem who I highly recomend for super speedy shipping, accuracy and very fairly priced. I installed it in seconds but I'm not sure if I need to replace the 67 strike plate/catch because it doesn't grab the plate. Now when I had the bus painted I also replaced the 67 apron with what I believed was a 67 april added the original catch and I could use some advice to get the 66 latch to fit the 67 strike plate. Are they different strike plates 66 to 67 or is there any other adjustments to make? I could always weld up my original rear engine lid and paint it but that take too much effort.
Old 67 engine lid:
Replacement 66 engine lid:
66 replacement latch:
67 apron and 67 strike plate/ catch:
66 latch on my 66 lid:
Lind wrote:
junichi
junichi is offline
PostPosted: Tue Mar 17, 2020 8:48 am    Post subject: Re: 67 Westy Reply with quote
Your bus is looking great! Quite a transformation from page 1! This is great inspiration for me and my project. Keep up the great work.
1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Sold: 1985 Transporter Doka,1978 Westfalia, 1975 bay x 2, 1986 syncro vanagon, 1965 beetle, 1980 vanagon, 1967 deluxe bus, 1988 golf
PostPosted: Sun May 24, 2020 4:04 pm    Post subject: Re: 67 Westy Reply with quote
First time out of the garage for 2020.
I installed my 2 spare door windows/ frames because I'm still not done with my repainted set.......soon. They work fine just not painted. While cleaning the garage I also found this ugly plastic wide angle back up mirror adapter and oddly it works so well I'm keeping it, I can see out all the windows! I also fixed my rear hatch after 3 years of it stuck. Labor of love and sometimes frustration.
Look with this adapter I can see out all the windows.
Temporary door windows ugly but works.
Portable carport is very useful I had bought it last fall and now using it for the bus so I can get work done.
Waiting for the pearl white paint to arrive for the lower nose.
The floor arrived the other day.
Now that I fixed the hatch after 3 years of it stuck I should be able to more a little faster. It was the bolts on the hinge that loosened.
Here it was stuck and catching on the left side.
Opens & closes now.
These bolts loosened.
The hardest part was the vent seals and now they are in, I just have to take my time with the rest of the assembly.
Done
Done
Lind wrote:
srfndoc
srfndoc is offline
PostPosted: Sun May 24, 2020 5:22 pm    Post subject: Re: 67 Westy Reply with quote
Slow and steady. My rear hatch was the same way when I bought my Westy.
Peter T.
Peter T. is offline
PostPosted: Tue May 26, 2020 8:53 am    Post subject: Re: 67 Westy Reply with quote
Eric&Barb wrote:
Here is more info:
I went with zinc coated screws to use on my windows. Supposedly the zinc inhibits corrosion between the 2 metals.
Its looking great Linda!
PostPosted: Tue May 26, 2020 2:19 pm    Post subject: Re: 67 Westy Reply with quote
Yes Peter T. I'm planning on replacing the stainless screws with sink as well.
BTW your westy is looking great. Cool
Peter T. wrote:
Eric&Barb wrote:
Here is more info:
Page 43 of 44
