LAGrunthaner  Samba Member
Joined: March 18, 2007 Posts: 5598 Location: 1st Coast
Posted: Sat Oct 07, 2017 2:46 pm Post subject: Re: 67 Westy |
Finally got my 3 jalousie windows in, not crazy about them and did minimal polishing adding stainless screws & putty but they are original to my westy so I felt I needed to put them back in. I prefer pop outs or the other camper style best. Tweaking needed for to small areas on the rubber but that's for another day.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25986 Location: Olympia Wash Rinse & Repeat
Posted: Sat Oct 07, 2017 3:20 pm Post subject: Re: 67 Westy |
Looks good. Do keep in mind that mixing aluminum and stainless steel does cause increased corrosion problems. Might want to go with chrome plated brass fasteners later. _________________ In Stereo, Where Available! |
Posted: Sat Oct 07, 2017 7:22 pm Post subject: Re: 67 Westy |
Thanks Eric&Barb good to know, I'll look for some chrome on brass or chrome on steel.
Eric&Barb wrote: |
Looks good. Do keep in mind that mixing aluminum and stainless steel does cause increased corrosion problems. Might want to go with chrome plated brass fasteners later. |
Maui Roadsters
Lind wrote: |
Posted: Sat Oct 07, 2017 7:30 pm Post subject: Re: 67 Westy |
I tried to get this last section of pop top frame in but I can't figure out how to get it in. Should I remove the two other pieces I already bolted up or is there a way I can get this in another way I don't see?
I can't fit it in
See doesn't fit
Should I remove these sides to get the front in?
Maui Roadsters
Lind wrote: |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19829 Location: Land of Whine and Phonies
Posted: Mon Oct 09, 2017 9:51 am Post subject: Re: 67 Westy |
Flip it around , that looks like the rear piece
You may have to put one side in and walk the other in from rear to front.
_________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Mon Oct 09, 2017 11:38 am Post subject: Re: 67 Westy |
crofty wrote: |
Flip it around , that looks like the rear piece |
crofty I donβt think so as per jeremy57ride image
And bugboy63
Maui Roadsters
Lind wrote: |
Posted: Mon Oct 09, 2017 12:59 pm Post subject: Re: 67 Westy |
Those both look weird to me. all three hoops should sit in the inner gutter _________________ Your Vanagon sucks, Stop waving at me.
jeremy57ride Samba Member
Posted: Mon Oct 09, 2017 1:24 pm Post subject: Re: 67 Westy |
Mine was never taken out from original. Linda- you should be able to slide that in from the rear on one side, by removing one of the side pieces that you previously mounted. _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
Posted: Tue Oct 10, 2017 1:42 am Post subject: Re: 67 Westy |
jeremy57ride wrote: |
Mine was never taken out from original. Linda- you should be able to slide that in from the rear on one side, by removing one of the side pieces that you previously mounted. |
Got it jeremy57ride I'll try just removing this one and see if I can get it in.
Maui Roadsters
Lind wrote: |
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5476 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Fri Oct 27, 2017 3:40 am Post subject: Re: 67 Westy |
Thanks DONGKG, yesterday I got back from my former students shop and he hooked me up with a guy to pull a ding out of the rear bumper and media blast both front & rear bumpers in November. Pretty happy to finally get that done and on the bus.
DONGKG wrote: |
Look at that Westy, it's looking cool each day. Keep us posted, buddy! Congrats! |
Maui Roadsters
Lind wrote: |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23905 Location: NYC/Upstate/ROW
Posted: Fri Oct 27, 2017 4:58 am Post subject: Re: 67 Westy |
Stumbled into this thread and your build thread. Totally awesome
I thought it was hilarious, reading all the advice to walk away from a $2000 split in 2008 when you are a welder. Had we known we would have all bought ten of them. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Mon Mar 26, 2018 2:19 am Post subject: Re: 67 Westy |
OMG yes agreed Abscate, once this garage queen becomes a daily curbside bus I'm going to start a pressed bumper project preferably a 56 (my birth year). I have a few welding projects I'm working on now but non VW. Looking back I am still glad I sold the 66 because I prefer older although I think it was parted out and it really wasn't that bad.
Abscate wrote: |
I thought it was hilarious, reading all the advice to walk away from a $2000 split in 2008 when you are a welder. Had we known we would have all bought ten of them. |
Maui Roadsters
Lind wrote: |
Posted: Mon Mar 26, 2018 2:36 am Post subject: Re: 67 Westy |
As some of you know I replaced my 67 engine lid with a 66 lid and the opening for the latch is different therefore my 67 catch would not fit (thanks Clara for that advice). Well I purchased a 66 latch from a samba member, ekimikem who I highly recomend for super speedy shipping, accuracy and very fairly priced. I installed it in seconds but I'm not sure if I need to replace the 67 strike plate/catch because it doesn't grab the plate. Now when I had the bus painted I also replaced the 67 apron with what I believed was a 67 april added the original catch and I could use some advice to get the 66 latch to fit the 67 strike plate. Are they different strike plates 66 to 67 or is there any other adjustments to make? I could always weld up my original rear engine lid and paint it but that take too much effort.
Old 67 engine lid:
Replacement 66 engine lid:
66 replacement latch:
67 apron and 67 strike plate/ catch:
66 latch on my 66 lid:
Maui Roadsters
Lind wrote: |
junichi Samba Member
Joined: September 12, 2005 Posts: 776 Location: brentwood bay, bc
Posted: Tue Mar 17, 2020 8:48 am Post subject: Re: 67 Westy |
Your bus is looking great! Quite a transformation from page 1! This is great inspiration for me and my project. Keep up the great work. _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Sold: 1985 Transporter Doka,1978 Westfalia, 1975 bay x 2, 1986 syncro vanagon, 1965 beetle, 1980 vanagon, 1967 deluxe bus, 1988 golf |
Posted: Sun May 24, 2020 4:04 pm Post subject: Re: 67 Westy |
First time out of the garage for 2020.
I installed my 2 spare door windows/ frames because I'm still not done with my repainted set.......soon. They work fine just not painted. While cleaning the garage I also found this ugly plastic wide angle back up mirror adapter and oddly it works so well I'm keeping it, I can see out all the windows! I also fixed my rear hatch after 3 years of it stuck. Labor of love and sometimes frustration.
Look with this adapter I can see out all the windows.
Temporary door windows ugly but works.
Portable carport is very useful I had bought it last fall and now using it for the bus so I can get work done.
Waiting for the pearl white paint to arrive for the lower nose.
The floor arrived the other day.
Now that I fixed the hatch after 3 years of it stuck I should be able to more a little faster. It was the bolts on the hinge that loosened.
Here it was stuck and catching on the left side.
Opens & closes now.
These bolts loosened.
The hardest part was the vent seals and now they are in, I just have to take my time with the rest of the assembly.
Done
Done
Maui Roadsters
Lind wrote: |
srfndoc Samba Member
Posted: Sun May 24, 2020 5:22 pm Post subject: Re: 67 Westy |
Slow and steady. My rear hatch was the same way when I bought my Westy. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Peter T. Samba Member
Joined: October 09, 2006 Posts: 268 Location: Long Island, New York
Posted: Tue May 26, 2020 8:53 am Post subject: Re: 67 Westy |
LAGrunthaner wrote: |
Eric&Barb wrote: |
I went with zinc coated screws to use on my windows. Supposedly the zinc inhibits corrosion between the 2 metals.
Its looking great Linda! |
Posted: Tue May 26, 2020 2:19 pm Post subject: Re: 67 Westy |
Yes Peter T. I'm planning on replacing the stainless screws with sink as well.
BTW your westy is looking great.
Peter T. wrote: |
Eric&Barb wrote: |
Maui Roadsters
Lind wrote: |
