Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12168 Location: Port Manteau
Posted: Wed Nov 23, 2016 1:49 pm Post subject: The EV Wheel Thread |
I looked but didn't see anything, so I thought I'd start a wheel thread.
I'm curious about what kinds of alternative wheels can be fitted onto the EV. I've seen some MB rims, but I'm specifically curious about Audi. I have a set of 16 x 7 ET49 five spokes from my '94 C4 Avant. I'd like to use them as winter rims with Blizzaks.
Any tips or concerns? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Wed Nov 23, 2016 4:56 pm Post subject: Re: The EV Wheel Thread |
you'll want to lift it and crank the torsion bars up if you put 16s on it.
cavevan.com has awesome lifters. about to get a grip of them for our vans. _________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com |
Posted: Wed Nov 23, 2016 5:32 pm Post subject: Re: The EV Wheel Thread |
It's a 2001, so it already has 16" rims from the factory. I'm not entirely clear on what the offset is for those, though. I've seen figures from 35mm to 49mm _________________ Casey--
y u rune klassik? |
BALDY & BLONDIE Samba Member
Joined: July 12, 2013 Posts: 14 Location: United Kingdom
Posted: Thu Nov 24, 2016 6:33 am Post subject: Re: The EV Wheel Thread |
mine fitted with mercedes steels 7 x 16 et31 with 215/70 16 bfg at's, this is a '95 syncro multivan, with 2 x extra spring seats fitted to the rear, and front torsion bars wound up to suit, later vans may not suit this offset, cheers baldy |
llilibel03 Samba Member
Joined: February 03, 2008 Posts: 777 Location: Redondo Beach California
Posted: Thu Nov 24, 2016 1:15 pm Post subject: Re: The EV Wheel Thread |
Love the look of the BFG's but how do they work on the street (where I drive 95% of the time)? How many miles do yo expect to get out of them? |
d-9 Samba Member
Posted: Fri Nov 25, 2016 2:52 am Post subject: Re: The EV Wheel Thread |
Lots of wheel options, almost anything with a 5x112 pcd from a VW/Audi will bolt up, and lots of aftermarket options. 2000s Passat, A4, A6, mk5 onwards golf, etc should be a straight fit. Don't go too wide or you will scrub the arches on compression.
You should consider the load rating of the wheel, in the UK it is illegal (but not strictly enforced) to use a wheel that is not rated beyond the max weight of the vehicle. People get very upset about this online, but just be sensible. Chinese eBay replica wheels do have a habit of cracking thou. |
50Splitman Samba Member
Posted: Fri Nov 25, 2016 6:28 am Post subject: Re: The EV Wheel Thread |
How does one check the load rating of the rim from another VW or Audi? Is there a code on the back of the rim and a way to decode it? I've seen a picture of an EV with 2012 and later Beetle heritage rims (which I think looks great) but I'm worried that those rims would have nowhere near the load rating required for an EV. Thx |
fkahlert Samba Member
Joined: September 30, 2016 Posts: 57 Location: Connecticut
Posted: Fri Nov 25, 2016 8:36 am Post subject: Re: The EV Wheel Thread |
on my Borbet wheels I had on the Passat, the actual max Kg rating was imprinted on the wheel. I believe (without looking now) the same was true on OEM steel wheels for the EV that I use on the snows.
In any case, any wheels that are also sold in Germany for example should with it or on the manufacturer site have a copy of the ABE (Allgemeine Betriebserlaubnis) which should state the max load of the wheel.
Same is true for the ET.
Florian 03 MVWK |
Posted: Fri Nov 25, 2016 8:43 am Post subject: Re: The EV Wheel Thread |
Also, speaking of offset. Unless I am mistaken, the OEM wheel has an offset of 49mm. That's quite a bit more than most aftermarket wheels have (many I've seen have 32-35mm). Unless I get this totally wrong, the lower the ET, the further the tires will stick OUT, reducing clearance to the fender.
Florian 03 MVWK |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3509 Location: Charleston, SC
Posted: Fri Nov 25, 2016 9:03 am Post subject: Re: The EV Wheel Thread |
16x6.5" et42 steel wheels that TireRack sells for the Audi A4, 225/65r16 tires.
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Joined: August 31, 2013 Posts: 13326 Location: North Carolina
Posted: Fri Nov 25, 2016 10:23 am Post subject: Re: The EV Wheel Thread |
No issues, I'm running a set of 15x7 forged Fuchs alloys from a UR Quattro.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Dec 22, 2016 11:29 am Post subject: Re: The EV Wheel Thread |
Zeitgeist 13 wrote: |
Any tips or concerns? |
They fit like a glove, and the center caps pop right in...but are a little loose, since the detents in the rims are in a different place.
y u rune klassik? |
wildenbeast Samba Member
Posted: Thu Dec 22, 2016 1:07 pm Post subject: Re: The EV Wheel Thread |
Mine are 16-inch alloy MK5 2006 VW Jetta wheels, 7.5" wide, 5x112 with a 57.1mm center bore, ET50.
_________________ - Bill, '93 Eurovan Syncro Weekender (2.5 manual ACU) |
WagenWerks KS Samba Member
Posted: Sun Sep 24, 2017 4:21 pm Post subject: Re: The EV Wheel Thread |
18x8.5 et35 Alzor style 081.. yokohama 245/40/18 tires
fit like a glove with no rubbing at all.. a little stiff due to the sidewall though
they are now flat green though
17x7 et43 OEM Beetle Heritage wheels.. Hankook 215/55/17 tires
THESE ARE AN ABSOLUTELY PERFECT FIT AND RIDE
EverettB  Administrator
Joined: April 11, 2000 Posts: 71606 Location: Phoenix 602
Posted: Sun Sep 24, 2017 5:25 pm Post subject: Re: The EV Wheel Thread |
WagenWerks KS wrote: |
This is a cool look. Interested in seeing the flat green look too _________________ How to Post Photos
gavin. Samba Member
Joined: August 14, 2016 Posts: 18 Location: Washington DC Metro Area
Posted: Tue Sep 26, 2017 6:46 pm Post subject: Re: The EV Wheel Thread |
Holy shit-on-a-stick, they look nice. |
VAEV1993 Samba Member
Joined: January 17, 2014 Posts: 153 Location: Harrisonburg, VA
Posted: Tue Oct 03, 2017 5:25 am Post subject: Re: The EV Wheel Thread |
16x6.5" et42 steel wheels - same vw steel wheels that others have gotten from Tire Rack, though I got these used.
225/60/16 - Nokian entyre 2.0
_________________ 1993 Weekender - Hula
2002 Golf TDI
2017 Golf Alltrack |
gest24 Samba Member
Joined: August 15, 2017 Posts: 11 Location: Escondido, CA
Posted: Tue Oct 03, 2017 4:29 pm Post subject: Re: The EV Wheel Thread |
Here is our 99 EVC on some B5 Passat "Sport Alloy" wheels (VW used to really lack creativity when naming wheels) wrapped in 235/60/16 Kuhmo Crugen HT51s. The suspension is still stock height (for now). Seat center caps added for the super OEM+ look.
[/img] |
Chi-town Samba Member
Joined: February 06, 2017 Posts: 22 Location: Disneyland
Posted: Fri Oct 13, 2017 8:47 pm Post subject: Re: The EV Wheel Thread |
16" Tiguan wheels with BFG A/T KO2's |
greenlaker Samba Member
Joined: December 26, 2016 Posts: 74 Location: Sebastopol, CA
Posted: Sat Oct 14, 2017 3:03 pm Post subject: Re: The EV Wheel Thread |
Chi-town wrote: |
How's the ride quality and noise with the KO2s? _________________ '15 Mercedes-Benz Sprinter Crew 144 hi roof
'10 Toyota Prius iii
'01 Honda S2000
'92 Mercedes-Benz 400E |
