Recommended fuel sender for 70 bus? Vendor/brand?**Update**
aeromech
aeromech is offline
PostPosted: Wed Nov 01, 2017 10:55 am    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
I'd just go with an original that's had the Telford Dorr repair
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Nov 01, 2017 11:28 am    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
I would too but I can't find any... got one laying around?
Robbie
www.airschooled.com
aeromech
aeromech is offline
PostPosted: Wed Nov 01, 2017 11:34 am    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
Robbie
Kevin Hernandez sent me an original VDO last week. Telford was here helping me install my new engine last Thursday and now has that sender. Contact him and see if you can get it. Better hurry, his wife is having surgery on 11/3 so he may be busy after that.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Wed Nov 01, 2017 3:19 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
http://www.eisparts.com/211919051VDO.html?gclid=CLaC4Yry3MECFcVhfgodnYUA6w
Just saw this. Wonder if it's the legit one now made in Europe?
The Samba member since 2004.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Nov 01, 2017 8:16 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
I'd want a measurement before i spent that kind of loot. otherwise, RoBbie's solution would work for me. either way, I'd still zip a hole to access it. like a wet fart, i don't trust the new stuff
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Wed Nov 01, 2017 8:21 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
Don't Jinx me! I'm on year 3 of my Brazilian VDO sender!
telford dorr
telford dorr is offline
PostPosted: Wed Nov 01, 2017 8:33 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
The sender is all repaired and ready to go. Looks like it sat in a mostly empty tank for a long time. The float was stuck on a corrosion layer on the center rod. Scraped that all clean and lubed it with a shot of teflon spray. The rod looks OK. Don't know where the corrosion came from (plastic float, and all). It also needed the ground to the brass spring fix. Seems to measure up correctly now.
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
pantone149
pantone149 is offline
PostPosted: Sat Mar 03, 2018 7:56 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
This unit is 210 mm, which is about a half a MM too long. They also sell 190mm.
If you zoom into the picture the yellow sticker reads in German and English. Cost is $57. I wonder if it's worth a try.
https://www.egauges.com/8-3-210mm-90-0-Ohms-p/224-221.htm
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Mar 03, 2018 9:20 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
that looks like the same chineseium piece of shit that made me make an access hole in my bus.
fwiw...if anyone gets a sender with that red gasket, put it thru a shredder before anyone can use it
Jake Raby wrote:
Brian wrote:
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sun Mar 04, 2018 5:00 am    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
I'd refurb an original VDO German made unit before gambling on any of the new Chinese junk.
I don't see the higher quality VDO's being sold anymore? I wonder if VDO discontinued them.
VWSunny72
VWSunny72 is offline
PostPosted: Tue Jun 12, 2018 12:10 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
Ran out of gas yesterday with 1/4 tank...my sender had been on the fritz lately and figures just before we head out on a 1,200 mile trip! The gauge has been going from 1/4 to empty very quickly over he past few months. Yesterday was the first time it showed 1/4 and was actually empty. I filled it up last night and the gauge correctly reads full. To boot, a little plastic cap fell into my tank from the jerry can’s built in funnel. It’s like a top to a water bottle. I will try to fish that out once the tank gets half empty. Yeah me. I guess it’s 200 mile fill-ups for this trip.
FWIW, the sender above from egauges.com is a made in Brazil VDO according to the owner.
I am owned by a 1972 Westy named Sunny. She has a 1979 2.0L engine w/ dual Weber IDF 40s.
pantone149
PostPosted: Tue Jun 12, 2018 1:21 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
I bought a sender that fits split bus and Ghia, which is about an inch too short. Works great and more accurate than anything I'd ever had. Gives me a huge reserve this way, but for one dollar (yep, got it for a buck) I am not gunna complain.
j10nbom
j10nbom is offline
PostPosted: Fri Nov 04, 2022 10:34 am    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
airschooled wrote:
Folks, we have here a near exact replacement for the stock sender, made by VDO. 90 ohms empty and 0 ohms full, means your gauge should be accurate. It is less than a half inch shorter than the stock sender that Skills measured. We can't all have our tubes as long as him apparently……… $70 here:
https://www.summitracing.com/parts/vdo-224-220
In the next few weeks, I should have test results back on a NEW brand of sender that hasn't hit the market yet. Several hours of phone calls might have paid off… We'll see……
Robbie
Bumping an old thread...is this one ^ definitely going to work in an early bay? I am going to change my cheapo sender soon and am looking at the options since my OG sender was kaput and obviously the cheapo didn't last long.
Seems like the sending unit options haven't changed much in the last few years.
CIP1 sells a Brazilian one they claim is made in the same factory as VDO:
https://www2.cip1.com/vwc-211-919-051-at/
...or EIS says they have "the VDO" one to get:
https://eisparts.com/product/fuel-sending-unit-bus-68-72-vdo/
Being that part quality is hit or miss these days, I'm having a hard time justifying the $ on that last link. But the VDO from Summit is economically appealing...
SGKent Premium Member
SGKent is offline
PostPosted: Fri Nov 04, 2022 12:15 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
Unless the old one is totally rotted out. Having Telford repair the old one is a really good solution. I can remember replacing the tube style senders on my 1971 back in the 1970's. Even with a genuine VW replacement from the dealer, those new senders only lasted 2 to 4 years before getting goofy as corrosion built up in the crimps.
HarryFD
HarryFD is offline
PostPosted: Fri Nov 04, 2022 5:35 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
I installed a Czech made VDO level sender in 2015. Still working fine.
1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1971 Jaguar XKE 2+2 V12 Coupe
1973.5 911 Targa
2009 MB C300
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat Nov 05, 2022 6:11 am    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
X2
Rebuilding/refurbishing the original sender is the way to go. Telford is the man for the job!
j10nbom
j10nbom is offline
PostPosted: Mon Nov 07, 2022 12:07 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
wcfvw69 wrote:
X2
If mine wasn't absolutely rotted out junk I may go that route. I ended up buying that VDO one from summit so we'll see how it goes.
SGKent is offline
PostPosted: Mon Nov 07, 2022 12:31 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
If it reads correctly out of the tank, and you should check it, unless the connections are soldered at the factory now, I would send it to Telford to have him permanently solder them so you aren't doing it again in 2 years. The issue will be once gasoline oils and corrosion gets into it, it is nearly impossible for the average person to solder without 100% knowing what they are doing. And, it the temperature isn't controlled while soldering correctly, the insulators melt.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Nov 07, 2022 7:12 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
As I noted back then, I bought the new VDO gauge made in Brazil. It tested fine out of the bus but once installed, it measured 1/4 tank low or when the fuel tank was full, it showed 3/4 full. The ground going to it at the tank was solid with good clean connections. I also made sure where it was grounded was clean under the connector too.
I never did figure out why it was reading 1/4 off..
SGKent is offline
PostPosted: Mon Nov 07, 2022 8:33 pm    Post subject: Re: Recommended fuel sender for 70 bus? Vendor/brand?**Update** Reply with quote
cause none of the replacements work right. The swing arm ones do the same thing. Just think of all the old senders that went into the junk pile that today would be worth a small fortune repaired... .
Page 4 of 5
