Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL
Page: Previous  1, 2, 3 ... , 17, 18, 19  Next
xoo00oox
xoo00oox is offline
PostPosted: Wed Feb 08, 2017 6:57 pm    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
Here's a better view of that flex piece. Again, only three months and three thousand miles on it.
199254 miles on the van and 93 hours on the engine, let's see if this one can hold up to the northeast salt.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu Feb 09, 2017 12:06 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
does the left rear tire kick up water and road salt toward that bushing?
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
xoo00oox
xoo00oox is offline
PostPosted: Thu Feb 09, 2017 6:56 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
Neil.
yes it does, still that braided piece should not have crumbled apart like it did.
jberger
jberger is offline
PostPosted: Thu Feb 09, 2017 9:00 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
xoo00oox wrote:
Neil.
Depending on the grade of Stainless, a salt spray that hits a very hot object will certainly turn that coupling to mush real quickly. Maybe wrap it with header tape to keep the salt from penetrating the loose weave and packing the internal ribbed space. I feel that is bound to happen again.
Vanagon Nut
PostPosted: Thu Feb 09, 2017 9:14 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
xoo00oox wrote:
Neil.
Though its a somewhat "apples to oranges" comparison, the outside of the bushing on my ABA NA engine still looks ok after at least 10K miles. But then its located higher (closer to manifold) than the bushing you show. But only 3 months and 3000 miles on the bushing you show? I agree. It shouldnt be failing so soon.
(VW Gas I4)
VE7TBN
xoo00oox
xoo00oox is offline
PostPosted: Thu Feb 09, 2017 10:26 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
jberger wrote:
xoo00oox wrote:
Neil.
I have a feeling it is too. A lot of cars have flex sections like this on the very bottom of the car, Audi for example. They are right before the catalysts. These cars are only a about 6 inches off the ground and get this part dragged through salt and slush for about 10 years before they go bad. I think it was just inferior metal used on the mesh part of this one.
Wangta
Wangta is offline
PostPosted: Wed Sep 06, 2017 1:41 pm    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
Andrew - your van still alive and killin it on the roads? Forgo to ask - did you have to cut the crossmember at all to mount the Audi 5 speed (I believe you do for the Subi covnersions). Oh and when can you do this to my van? Razz
point003
point003 is offline
PostPosted: Mon Dec 04, 2017 12:29 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
xoo00oox wrote:
With the new engine, I need to go to drive-by-wire rather than throttle cable. This is the best solution we have found. I use the late VW accelerator pedal and use a CAT 5 cable to run the data from the cable to the ECM. I also run the OBD2 data through the same cable from the ECM to the diagnostic port we install under the dash.
best to you, please, tell me where this pedal? perhaps you know the part number? or exactly where to use this? or where exactly you bought it?
PS.. sorry for my English Embarassed
point003
point003 is offline
PostPosted: Tue Nov 12, 2019 2:54 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
Hi,
the same thing I managed to do with the Audi engine, only with a one-way camshaft.
look-
https://youtu.be/h5e_3isdy5Y
4Gears4Tires
4Gears4Tires is offline
PostPosted: Tue Nov 12, 2019 7:25 pm    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
Well that was a fun read! What a great build!
elizer
elizer is offline
PostPosted: Tue Nov 12, 2019 8:33 pm    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
2006 jetta have those pedals I believe
xoo00oox
xoo00oox is offline
PostPosted: Mon Dec 02, 2019 11:14 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
SyncroBouree
SyncroBouree is offline
PostPosted: Mon Dec 02, 2019 11:30 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
Looks Hella frosty there-
Best wishes for keeping warm and safe as the next storm heads your way.
p.s. Tho' mine still twists -normally- Thank you for your 1.8T counter-twist university online course...
p.p.s. Love the Audi insignia as well
--Liam
1990 Vanagon GL Syncro Westy VW1.8T Triple-Knobber
1975 911S Widened Turbo/RSR Hybrid
1979 Harley Lowrider -- Donated to a good home
1969 Ford Bronco Half-Cab 351W, Toploader, Dana 44 FE, Detroit Locker, Duffy’s Suspension – wish I still had it
1962 GMC 3/4T Fleetside, V6<-Chevy 409 w/factory headers, Camper/Tow Rig – ditto
cptgreenvalley
cptgreenvalley is offline
PostPosted: Sat Jul 18, 2020 10:24 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
Wow! Such an interesting read of an impressive build!
Any idea if this would work with A6 quattro as well?
I guess it is time to measure my A6 1.8t drive train😊
BR
Magnus
1979 T2 Camper 2.0FI - Sportsman Conversion ( US import)
1987 T3 Syncro Vanagon 1.9TD ( Decoupler, Double Diffs, Westfalia conversion)
1991 Golf MK2 Country Syncro 1.8
2010 BMW 330xd & 320xd
xoo00oox
xoo00oox is offline
PostPosted: Tue Jul 06, 2021 5:09 pm    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
Quattrosyncro is still running like a top! I had to move my boat and the trailer I'm building is not ready yet so....
Just fits!
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue Jul 06, 2021 5:53 pm    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
Awesome!
Casey--
'01 Weekender --> full camper
y u rune klassik?
fleet_maintenance
fleet_maintenance is offline
PostPosted: Tue Jul 06, 2021 9:44 pm    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
Just fits!
Like something out of a Bond movie.
4Gears4Tires
PostPosted: Wed Jul 07, 2021 6:13 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
That's a beautiful little boat.
xoo00oox
xoo00oox is offline
PostPosted: Wed Jul 07, 2021 6:40 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
Thanks! Learning woodworking was my Covid project. I started in February '20 with little wooden boxes and worked my way up to building the boat. Just got it in the water for the first time this past weekend.
It was a happy surprise to find that it fits inside the Vanagon.
Jake de Villiers
Jake de Villiers is offline
PostPosted: Wed Jul 07, 2021 9:05 am    Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
I agree, that's a lovely little boat. Well done, Andrew!
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
Page 18 of 19
